04-11-2015, 03:22 PM | #1 |
Rep 130
Change final drive ratio. More fun and thrust?
I am used to changing drive ratios on my motorcycles (very easy with sprockets). It's more fun to rev through the rpm range and you have more thrust. How could I do that on my 235i? Change differential or get an LSD modified?
This has been done in the 3 and 1 series with success apparently. Some really liked going from 3.08 to 3.46 (same as automatic actually) by modifying ratios in the LSD . http://www.vacmotorsports.com/blog/3...no-lsd-really/ Others used the differential (non-LSD) from another model type -- older 3 series cars for example. Looking at all 2 series model types for final drive ratios the diesel 220d for example has a 3.231 drive ratio (comparison table for manual cars are below -the automatic 2 series are all 3.077 I believe). Close but may be not perfect. Or one from a 228i at 3.99 (seems very high). Or would automatic differentials fit from 1 series or 3 series to get a 3.46 ratio? So many unanswered questions. Most important - would I actually like it with an aggressive ratio of 3.46 or more? Hope someone has tried this already or has ideas. Last edited by Heitzer; 04-11-2015 at 04:10 PM.. Reason: corrected error |
04-11-2015, 06:09 PM | #2 | |
Rep 845
04-11-2015, 06:22 PM | #4 |
Rep 2,010
This is a way back experience. I recall people running 4.11 rear-end gears back in the '60's, and those muscle cars were really quick. Problem was, with only 4-speed manuals, the engine was pretty wound out on the freeway. Really impractical at the time.
///M235i | Mineral Grey Metallic | Premium Package | Technology Package | Driver Assistance Package | Dakota Coral Red/Black Leather | Harman/Kardon Premium 360 watt sound system | 8-speed automatic
When writing your life's plan, use a pencil with an eraser |
04-11-2015, 06:37 PM | #5 | |
Rep 845
04-11-2015, 07:16 PM | #6 |
Rep 2,010
Do you have an idea as to the performance increase in numbers? 0 to 60 times, etc.?
And what will your RPM be on the freeway in top gear at say, 70 MPH?
04-11-2015, 08:11 PM | #7 |
Rep 130
The ratio difference between 3.077 and 3.46 is 1.12. So you should have 12% more thrust throughout the rev range if my math is correct.
0-60 improvements should get close to the numbers the automatic pulls. Top speed in first and second gear is 35 and 53mph for the steptronic. The manual car has 41 and 72 stock which goes to 36.6 and 64.3mph with the 3.46 ratio. You have to do only 2 shifts manual but slightly lower gear ratios. At 70mph the stock car runs 2473rpm in sixth gear. Should be 2781 after going 3.46. Not helping gas mileage for sure but not a giant difference either. |
04-11-2015, 08:11 PM | #8 | |
Rep 845
The drive ratio increase gives a 12% torque increase (3.46/3.08 = 1.12337) from mechanical advantage in every gear, so the acceleration increase should be significant. At 70 mph in 6th, you'll be at 2750 rpm. |
amw896582.50 |
06-21-2016, 10:41 AM | #10 |
Rep 1,117
Drives: 2015 BMW M235i
don't mean to thread jack but have you looked at the m performance LSD? Would like to know why or why not? The previous owner of mine had this port installed and I think it's fantastic but I haven't ran a m235i without the LSD or a different brand.
06-23-2016, 06:52 AM | #11 | |
Rep 130
Cost is $3000 before install (Diffsonline keeps the stock differential) . Turner Motorsport here in MA worked on the car and they did the lower control arms also which definitely increase fun during commuting and street driving. Very happy with advice and install from both. This is the best mod for the car in my opinion. I followed LiquidPapers advice and am glad I did. |
BM235iW97.00 |
06-23-2016, 01:27 PM | #12 | |
Rep 845
06-27-2016, 01:25 AM | #13 | ||
Rep 2,364
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
06-27-2016, 02:59 PM | #15 | |
Ne Plus Ultra
88
Rep 264
Drives: Portimao Blue 2022 M240iXdrive
06-27-2016, 03:17 PM | #16 | |
Rep 845
What does cause your car to have an inaccurate speed is wheel/tire size (rolling diameter). The car calculates speed based on wheel revolutions, so if your car has a larger rolling diameter, the wheels dont have to spin as fast to get to a certain speed, and the car will read "low" with respect to speedometer reading.
09-07-2016, 06:38 PM | #19 |
Rep 5,372
I'd love to have the 3.46 rear gear as I feel the M235 gearing is just a tad too long. The M2 comes with a 3.46 gear. Interestingly, the R&T compare between the 228i, M235i, and M2 gives a gear by gear mph break down and I was surprised at the minimal difference in the max mph in gears 1, 2, and 3 between the M235 and M2 (they use the same 6MT and internal gearings). By the seat of the pants though, the 3.46 gear will feel a bit quicker. Will it translate to much improvement in the 1/4 mile? Doubtful. On a road course? Maybe, maybe not
http://www.roadandtrack.com/car-cult...mparison-test/ |
09-09-2016, 03:26 PM | #20 | |
Rep 845
When I had the 3.08 final drive, third gear red-lined at about 109 mph, which was a little too long for me. With the 3.46 final drive, third goes to about 95, which makes more sense. With respect to it being "faster" it really depends. Your "in gear" acceleration will be faster because you have 12% more wheel-torque through mechanical advantage. Downside is that you have to shift "sooner". Some road courses I think the taller gears would be better (I've had to shift right before a breaking zone a few times or just bang into the rev limiter for a bit because of the shorter gearing), but others I think the shorter gears help (more technical courses where your top speed isn't quite as high). Real race cars frequently change their final-drive and differential setup based on the course they are running, so you kind of have to just pick something and stay with it for a street car.
09-11-2016, 12:39 AM | #21 |
Rep 5,372
The 6MT box used is the M235 is the same dry sump ZF unit used in the 1M, M2, M3, and M4 according to GetBMWparts.com and various mags and BMW publicatuons. Internal gear ratios are all the same too among all cars. I wonder why you're only seeing 95mph in 3rd where as the M2 can see 103mph.
09-11-2016, 07:15 PM | #22 |
Rep 130
The difference is due to the larger diameter 19inch tires on the M2 I think. The Supersport tires run 790 revs per mile for the 265/35 ZR19 of the M2 compared to 840 revs on the M235i. That difference would lead to 36.7 mph in first gear instead of the 39 mph if you put the 18inch tires on the M2.
Clearly some of the performance advantage of the M2 is due to gearing. I am still in awe with the changes this made to my M235i. Highly recommend . |
