BMW 3-Series (E90 E92) Forum
Short Shift knob for E92 - Seatbelt Issue
03-16-2015, 11:33 AM | #1 |
Rep 23
I'm getting my 6-speed 07 335i this week (woohoo) and I have couple of questions:
1-I hate the stock shift knob because of the aluminum feeling, and the tall length. Are there easy replacements that are both, Short in length, and with full leather? I really like the M-Style short shift knob but not sure if this will really make the knob shorted (no intention to change to a short shift kit at this point). do I need to "cut" the shifter to lower some inches? 2- is there any DIY for fixing the seatbelt-sliding handle to catch the seatbelt? that is when the driver side seatbelt assistant moves forward to catch the seatbelt, and it fails to catch it. I had the same issue in my old 328xi. thanks! |
03-16-2015, 11:45 AM | #2 |
Rep 583
For the seatbelt you can use a hair straightening iron on the area of the seatbelt that the arm is supposed to grab. This should flatten it out and stiffen it up a bit so it doesn't flex out of the little grabber arm
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
03-16-2015, 12:12 PM | #3 |
Rep 23
For Seatbelt: Tried this hair iron thingy before and did not help, Since it seems to be a common issue , I thought there may be a better "replacement part" that can replace the stock handle/motor. will try again, but let me know if there are other solutions for that
03-16-2015, 10:32 PM | #4 |
Rep 76
I'm in the same boat with the shift knob. I found this: http://www.e90post.com/forums/showthread.php?t=307607 so i'm buying this: http://www.ecstuning.com/Search/25110406895/ES46480/ . No need to cut, its just simply a shorter knob.
2008 E90 335I | Sport | Premium | Cold Weather | CA | Logic7 | Black/Black |
03-17-2015, 11:38 AM | #5 |
Rep 23
I think based on what I read so far, the ZHP is the best choice.
http://www.ecstuning.com/BMW-E92-335i-N54_3.0L/ES47397/ And found this vid, will try to see if changing the part will fix it: Last edited by BimmerFannn; 03-17-2015 at 12:08 PM.. Reason: adding link for youtube seatbelt fix. |
03-17-2015, 04:05 PM | #6 |
General
17395
Rep 18,786
Momo makes nice gear shift knobs for BMWs. They are affixed to the shaft with set-crews and will not come off. I've had a Momo Atomic leather shift knob on my various BMWs for years. It's the same one, I've moved it from car to car. It's got about 400,000 miles on it and still in good shape.
03-17-2015, 04:29 PM | #8 |
Rep 23
