2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Any coders in Raleigh/Durham area
      02-24-2015, 09:40 AM   #1
Thescout13
Thescout13's Avatar
Drives: '20 F80 M3CS, %E2%80%9818 GT3
Just got an F22 and am having trouble coding it whereas I had no trouble before on my F30. Looking to see if someone can come help me out.
Thanks!
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE
Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene)
Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017)
      02-24-2015, 10:44 AM   #2
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
can you post the error ?
      02-24-2015, 10:46 AM   #3
Thescout13
Thescout13's Avatar
It was an error reading the coding data of the CAFD files, something like file not found. I think it was just that i don't have the updated pzdata? I messaged Shawnsheridan and he is helping me work through it. Does that sound right to you?
      02-24-2015, 10:51 AM   #4
pikcachu
pikcachu's Avatar
1403
ya you probably have 54.2 on your car....
you probably need this http://www.bimmerfest.com/forums/sho...2&postcount=12
      02-24-2015, 10:58 AM   #5
Thescout13
Thescout13's Avatar
still didn't work here are the errors
      02-24-2015, 11:02 AM   #6
pikcachu
pikcachu's Avatar
1403
what psdzdata version are you using? you need 54.1 most likely
      02-24-2015, 11:04 AM   #7
Thescout13
Thescout13's Avatar
Apparently a really old one, 52.5. How do I replace the psdzdata? I already have a link to download it
      02-24-2015, 11:13 AM   #8
pikcachu
pikcachu's Avatar
1403
ah ya that's the problem...
you just delete what you have (or rename the folder just in case) at C:\BMW\Data\psdzdata
and replace it with the content of the new one from the zipfile... make sure you don't create another psdzdata inside the psdzdata
"EXTRACT PSdZData_Lite or PSdZData_Full .rar ARCHIVE
04) Extract the PSdZData_Lite or PSdZData_Full .rar archive to produce the "psdzdata" folder.
*NOTE: Open only Part1.rar and hit Extract. It will automatically extract all files and folders that are spanned across all parts of the .rar
archive. Do NOT Open and Extract each individual .rar part. There should be no errors during extraction and no prompts to override files.
05) Make sure that there is an empty "dist" folder in each of the psdzdata chassis folders, and if missing, create as needed, e.g.:
⦁ C:\Data\psdzdata\mainseries\F001\F001_xx_xx_xxx\od x\dist
⦁ C:\Data\psdzdata\mainseries\F010\F010_xx_xx_xxx\od x\dist
⦁ C:\Data\psdzdata\mainseries\F020\F020_xx_xx_xxx\od x\dist
⦁ C:\Data\psdzdata\mainseries\F025\F025_xx_xx_xxx\od x\dist
⦁ C:\Data\psdzdata\mainseries\F056\F056_xx_xx_xxx\od x\dist
⦁ C:\Data\psdzdata\mainseries\I001\I001_xx_xx_xxx\od x\dist
⦁ C:\Data\psdzdata\mainseries\K001\K001_xx_xx_xxx\od x\dist
⦁ C:\Data\psdzdata\mainseries\KE01\KE01_xx_xx_xxx\od x\dist
⦁ C:\Data\psdzdata\mainseries\RR01\RR01_xx_xx_xxx\od x\dist
INSTALL PSdZData
06) If existing "psdzdata" folder exists in "C:\Data\" (i.e. "C:\Data\psdzdata") DELETE it.
07) From the PSdZData_Lite or PSdZData_Full extraction, copy the "psdzdata" folder to "C:\Data\" (i.e. "C:\Data\psdzdata")
*NOTE: Do NOT copy new psdzdata folder onto older existing psdzdata folder (merging them) as you end up with corrupt PSdZData as a
result."
      02-24-2015, 11:52 PM   #9
pikcachu
pikcachu's Avatar
1403
Did it work ?
      02-25-2015, 08:29 AM   #10
Thescout13
Thescout13's Avatar
Did it work ?
Yeh I replaced the psdzdata file and it worked perfectly. I used your cheat sheet and coded everything I wanted! Thanks again!
      02-25-2015, 10:23 AM   #11
pikcachu
pikcachu's Avatar
1403
2addicts
