BMW 3-Series (E90 E92) Forum
Pro HU coding issue! Help please!
12-04-2014, 05:29 PM | #1 |
Rep 183
Guys I really need your help!
Please see http://www.e90post.com/forums/showthread.php?t=1064484 Something is wrong with my 2rad trc coding Can somebody help me? |
12-06-2014, 10:33 AM | #6 | |
Rep 1,244
Drives: 2013 F10 M5
It's a lot easier to modify the VO with the appropriate VO options (like removing L7 and replacing HiFi) and default code the modules. There's usually many different lines to modify if you try to do it manually. Plus by modifying the VO, the changes are persistent even if the module is reprogrammed and recoded. |
12-17-2014, 01:18 PM | #9 | |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
12-20-2014, 10:54 PM | #11 | |
Lord Scrip
1823
Rep 3,018
12-20-2014, 11:48 PM | #12 | |
Rep 5,120
12-20-2014, 11:51 PM | #13 | ||
Lord Scrip
1823
Rep 3,018
12-20-2014, 11:57 PM | #15 |
Lord Scrip
1823
Rep 3,018
Nothing can go wrong. Besides like I originally said....if your VO is accurate to the options you want and the hardware present, the car will setup the empty ECU. Only one that is risky with is CAS and DME.
12-21-2014, 12:11 AM | #16 | |
Rep 5,120
I copied this from another post. 1. Load NCSExpert. 2. Load Profile and select Expertmode 3. F1 (VIN/ZCS/FA) 4. F3 (ZCS/FA f .ECU) 5. Choose E89 (for the E9X) 6. Select CAS 7. F6 (BACK) 8. F4 (Process ECU) 9. Select the Module I want to Revert back to Stock. 10. F2->Choose "SG_Codieren->ok 11. F3->to start coding the ecu with factory settings according to the vehicle VO. |
12-21-2014, 12:27 AM | #17 | ||
Lord Scrip
1823
Rep 3,018
12-22-2014, 11:43 AM | #19 |
Rep 183
Guys, I've already tested all of your suggestions.
Please, no offence to anyone but I know how to code Coding the HU to Hifi is not the problem. The problem is that I still get a loud GONG/Voice CTRL even with radio in HIFI mode. (I know it is in HIFI cauze I get a significant drop in sound + hidden menu in the HU) I'm not the only one with this problem. Many faces the same weird issue. I've looked into several forums. No one has found a solution yet. So the way we are coding the car is not the prob. Prob is more about options to enable/disable/set or prob of incompatibility. I just try almost everything without success. I give up for now ... |
12-23-2014, 12:07 AM | #20 | |
Rep 4,121
12-27-2014, 06:39 PM | #21 | ||
Rep 9,097
Now OP, without being rude, I give you two hints; 1- Set your gains right If problem persist, then 2- Code the gongs to come out of speedmeter than speakers. Done on many cars with gladen kits. Don't ask how! Good luck.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
