BMW 3-Series (E90 E92) Forum
Coding Cable
11-29-2014, 03:03 PM | #1 |
Rep 10
Coding Cable
Hey guys,
I have an e90 325i and I want to know if this cable work or not? Any cable recommend for coding? http://www.amazon.com/KCRIUS-TM-Inte...xp_grid_pt_0_1 Btw, I am new to this forums. Thank you for your help! |
11-30-2014, 01:11 AM | #5 | |
525
Rep 1,527
11-30-2014, 11:06 AM | #6 |
Rep 749
Drives: 335i xDrive
11-30-2014, 11:12 AM | #7 | |
525
Rep 1,527
Not all E series stopped production in 2011, so you really just need to pay attention the chassis. |
11-30-2014, 01:37 PM | #8 | |
Rep 10
This is the file I needed right for coding? http://www.dehmicro.com/bmw/ (Got it from xxxjecxxx) |
11-30-2014, 01:45 PM | #9 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
I've purchased several cables for NCSExpert and they've all worked. I don't look at the board color or anything. Each cable came with a rediculous Zip file program. I feel like this is where people get screwed. If everything isn't unpacked and installed perfect....your fucked!
11-30-2014, 04:26 PM | #10 |
Rep 10
There are a couple threads that can help people if they're having troubles in getting started. I found these two are very useful and have tons of info.
http://www.e90post.com/forums/showthread.php?t=480261 http://www.e90post.com/forums/showthread.php?t=451145 |
12-02-2014, 12:40 AM | #11 |
Lord Scrip
1823
Rep 3,018
http://www.ebay.com/itm/like/271476322678?lpid=82
This is the cable I bought and it came with all the goodies I needed to code and update modules. It was $35 and it works great! |
12-03-2014, 04:39 PM | #12 | |
Rep 10
12-05-2014, 12:00 PM | #13 | |
Rep 6
I have an 06 and I wasn't sure which years needed the adapter to switch the two pins around. |
12-05-2014, 12:01 PM | #14 | ||
Lord Scrip
1823
Rep 3,018
12-10-2014, 07:27 PM | #16 |
Rep 6
12-29-2014, 09:10 PM | #18 |
Boosty
55
Rep 325
Will these cheaper cables work to do the BMS back end flash ?
'08 335i AT Alpina Flash~Rob Beck Turbos~Full kittyless exhaust~DCI~5" Intercooler~Chargepipe BOV~BMS meth kit
12-29-2014, 10:16 PM | #19 |
11
Rep 177
01-01-2015, 04:07 PM | #21 |
Rep 87
just to clarify :
Most of cable are made with ftdichip but there is also chinese clone which works without problem. Only one problem in past was when ftdi detected this chip and some driver have locked this but this one driver is not online anymore, also, new driver unlock if this is locked. Chip bi itself is expensive, 20 US$ cable can't be with original chip but clone works good as well. Anywya, beside this all works OK I've got tired of this, going with ICOM soon. |
