2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Coding to disable alarm chirp
      10-30-2014, 09:00 AM   #1
jmctamu98
Drives: 2014 F22 M235i
Question Coding to disable alarm chirp
Does anyone know where to disable the alarm chip? I have tried the ACOUSTICAL_LOCK_CONFIRM, but it appears that has to do with the locks not the OEM alarm. Any ideas would be very appreciated.
F22 w/o NAV
      10-30-2014, 09:19 AM   #2
bimmerbuff
Slightly Less Obsessed
bimmerbuff's Avatar
Drives: Between BMWs
Can't that be done right from within iDrive?
      10-30-2014, 10:17 AM   #3
jmctamu98
Ok found the answer and figured I would share. I got my new cable in the mail and went through cheat sheets like crazy, circling all of the things I wanted to change. When I saw ACOUSTICAL_LOCK_CONFIRM, it seemed logical to disable it.
When you disable ACOUSTICAL_LOCK_CONFIRM, you are disabling the ability to change the setting in the menu, not disabling the sound itself. Since I had not seen it in iDrive, I didn't know it was missing.
Hope this helps someone avoid frustration.
2addicts
