BMW 3-Series (E90 E92) Forum
I'm a moron need help with FRM
10-19-2014, 07:21 PM | #1 |
Rep 885
Well I was having trouble getting NCS to read. I fixed it read my FRM module and was going to do the corner delete mod. I was following the diy and must have missed something or goofed. When I went to read the FSW_PWS File the SIDEMARKER_US was already nicht_activ was already there. I thought that was weird but looked through and I figured okay I will just write it on as is.
Well the corner delete worked but now my angle eyes are acting funny and the bulb warning light is on my dash. So I read the module again to try and fix it and now I think I wrote over my very first "original" File... I do have a FSW_PSW File from a long time ago from when I coded out headrest airbags. Any guidance on my next steps to undo what I have done?
10-19-2014, 08:31 PM | #3 |
Rep 885
So I get it right this time, can I follow the below to revert my frm module back to stock?
1. Load NCSExpert. 2. Load Profile and select Expertmode 3. F1 (VIN/ZCS/FA) 4. F3 (ZCS/FA f .ECU) 5. Choose E89 (for the E9X) 6. Select CAS 7. F6 (BACK) 8. F4 (Process ECU) 9. Select the Module I want to Revert back to Stock. 10. F2->Choose "SG_Codieren->ok 11. F3->to start coding the ecu with factory settings according to the vehicle VO. -I assume using expertmode makes the program use the VO to code? Do I need to remove the FSW_PSW.man file from my "work" folder so that I do not load the same data again?
10-19-2014, 09:35 PM | #4 |
Rep 885
Hmm it's all fixed, but I am not really sure what I did in the first place to f-it up. I used the above steps to fix what ever it was and now is all good. Corner delete enabled. Nice clean headlights without the yellow turn signal.
