BMW 3-Series (E90 E92) Forum
Coding HELP for 2URAD with internal BT & USB (Professional HU post 3/11)
10-18-2014, 04:57 PM | #1 | ||||||||||||||||||||||||||||
Rep 4,121
10-18-2014, 10:53 PM | #2 | ||
Rep 4,121
These posts (and the encompassing thread, are also quite helpful and an extension of the above)...
10-19-2014, 08:21 PM | #3 |
Rep 4,121
I am a beginner coder, and have had assistance from ****** (advanced coder) and still no luck.
HU arrived with USB and BT options enabled, but with german voice and 'stereo' DSP instead of HiFi. (successfully used both BT & USB) We must have gotten the car to talk to the radio somehow, because now BT is gone. but we cannot get back. Have tried various production dates. Would anyone be interested in a remote session to code my car? I have all the files already (2.53.3) (NCS expert is mostly german). MY2011.0 335d e90 7/2010 production NO MOST BUS (Whatsoever) Latest dealer update 4/2014 w Daten 2.52. Radio 4/2014 manufacture. HD Radio USB BT SDARS also no most bus Thank you in advance! |
10-21-2014, 04:29 PM | #4 | |
Rep 9,097
Do you have Icom to code this unit? As it would require Icom to code properly.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
10-21-2014, 04:45 PM | #5 | |
Rep 4,121
I don't think you've sold any US-spec head units to the best of my knowledge (what were you charging, for what it's worth) I do not have ICOM, why is ICOM necessary in your opinion? Everyone else has coded this with K+DCAN. |
10-28-2014, 03:29 PM | #6 | ||
Rep 9,097
Or something else. I have sold these units to American lad, Australian, Spanish, French and Italian. All of the units were coded to client's car with ICOM and they worked flawlessly. If you are anal about the dealer number in the unit, I would not bother about that. I tried to do it with K+D cable and it did not work. Tried with Icom and no issues.
10-28-2014, 09:18 PM | #7 |
Rep 4,121
@makkan00
The difference is: 1) HD radio [US] vs DAB [EU] 2) Sirius If a car does not have any MOST port, does ICOM have any advantage in that case? It is not the dealer number, it is the VIN |
10-29-2014, 12:24 PM | #8 |
Rep 26
If you are close to Boston region, I can help you out
I successfully did turn on bluetooth, USB and voice recogntion of a HU with bluetooth and combox module in an non-idrive e90. But you might need BMW special head (OPS/ICOM) to set it.
10-29-2014, 01:53 PM | #10 | |
Rep 26
Brute-force way to turn on bluetooth
I guess that if you can borrow or rent an ICOM head will make the life much easy. Last edited by mhd; 10-29-2014 at 01:58 PM.. |
10-30-2014, 04:14 PM | #11 | |
Rep 9,097
Going back to your question, you only require icom A to code it. Icom B is for most loop. And yes, all HUs have dealers number saved and I am not referring to vin. So lets say if I code Uk unit to work in French car, it will still retain UK dealer number for emergency contact. You can change it by advance coding but nobody bothers it. As in case of emergency, you will be relying on your phone and not HU. If you were in Uk, I would have done it for you without any charges.
10-30-2014, 06:19 PM | #13 | ||
Rep 4,121
But still, you are not selling to us head units |
11-27-2017, 04:01 PM | #14 |
Rep 3
Coding 2RAD from Stereo to HiFi with NETTODAT.MAN
I wanted to change radio configuration because I retrofitted S676 HiFi system but always NCSEXPERT gave me an error when I read configuration (CODIERENDATEN_LESSEN) and I write configuration (SG_CODIEREN) and SG_RESET no changed the config neither.
My radio is original radio. Well, finally I tried the same method with empty FSW_PSW.MAN but with empty NETTODAT.MAN and the radio changed to HiFi system. You only must make a empty file NETTODAT.MAN inside Work folder and to do the same process with NCSexpert and before you choose the job you must push Basic options (F5) then you choose coapiCodeSgByNetttoData and write the empty file name created when show pop-up. The radio autoreset and job done. The diference before and after... well the principal difference was in PDC and Gong volume. When I mounted the hifi system (speakers, tweeters and amplifier) I noticed a great difference in quality and volume but Gong and PDC was too high, after config PDC and Gong have a standard volume and I note a little better quality. I attachement the final result, error and process. |
06-05-2018, 03:34 AM | #15 |
Rep 5
Professional Radio update Coding
I have recently installed an updated professional radio with BT and USB in my 2008 E87.
Everything worked without coding, but I wanted to change the voice from German to English so carried out coding using NCS Expert by adding #0311, $6FL and $6NN to the VO. SG_CODIEREN failed for the RAD2 ECU, but changing job to SG_RESET was successful and the voice is now English and there is also an additional item on the display called PARKED! The problem now is that the gong and PDC sounds only work when the radio audio is ON. The volume of both can be adjusted with the volume control knob. Before I did coding the gong and PDC sounds were independent of whether the radio was on or off. Is there possibly something in the FSW_PSW.trc file, or any other trace file, that I should configure to correct this? Can anyone help? |
12-30-2018, 04:00 PM | #16 | |
Artist
Rep 5
Mic activation
I have only one question guys please... This coding activate also the microphone ? I have all ok only I cannot be heard by anyone!!! Voice recognition, bluetooth, phone all ok. Please help... |
12-31-2018, 07:58 PM | #17 |
1921
Rep 13,122
https://www.e90post.com/forums/showthread.php?t=687463
my guess is the mike wiring is different above is and extensive thread when this was first done. |
02-22-2019, 05:44 AM | #18 |
Rep 59
Hi all,
I am in the same boat with most I replaced my business radio with professional originally I had Bluetooth and USB came with the radio without any coding. Later I tried to check some options with NCS and realized I still have 1RAD module, which I could not read. Then I add 2RAD which some how deleted the 1RAD automaticly. I tried to read it and still can not read it. While trying to read it I reset it and lost Bluetooth and USB. Thanks to this post I managed to re add the Bluetooth and USB back how ever I still can not read the 2RAD. When I check the TRC or MAN files I got in the work folder that I used to recover the bluetooth it has soo many different lines then what I can see at NCS dummy. I think this might be the reason why when I reed it at NCS I always get an error. Is there anybody who was able to fix this problem for a retrofit radio. All functions are working but not being able to read it at NCS makes me worry. |
10-10-2021, 06:25 AM | #19 |
Rep 257
Thanks to @Jose_JN for the info (and his thread) and to @tainanl for compiling the key parts in this thread. After adding the $6NN and $6FL to my VO (already had $663 professional radio from factory and build date already > 03/11) my eBay bought radio now has Bluetooth and USB activated. It also switched from “Hifi” to “Stereo” which I’m ok with as my car has the base system and I can’t be bothered to upgrade it. I used NCS expert (didn’t really know what I was doing, and got errors when trying to code the 2RAD) and a cheap cable. But after leaving the car overnight, the options appeared.
10-27-2021, 06:29 AM | #20 |
Rep 1
Hi
I'm new to BMW and this forum. I have a question that maybe you in the community can answer? I installed a new head unit which is this link here ->https://www.aliexpress.com/item/1005...5f3f6be4jDnKzZ It says it does not need any coding. I have a BMW E91 2011 318D CIC professional navigation. I have a cord that does not go into the new head unit . The car does not turn off completely even if I lock the car. The Idrive buttons light up for a few seconds and then they turn off. The sound turns off many times and I do not hear the ding dong sound if the door is open. If I install the original head unit back, everything works. What do I have to do. Do I have to code anything? Thanks in advance from a newbie when it comes to BMW |
10-28-2021, 05:59 AM | #21 |
1921
Rep 13,122
This entire thread is about Pro Radio not Idrive
GUSO
This entire thread is about Pro Radio not Idrive. PRO Radio is for a non idrive car. Your idrive question is not relevant to this thread. There is a bunch of stuff about the Android piggy back unit which are in general not well supported on the stereo sub forum. The usual mistake people make with idrive android piggy back untis is not transferring the Most bus connection to the Harness adapter that goes to the connection on the back of the old idrive. They come with no instructions if they are from China. I don't have one but there are threads on them on the stereo and idrive subforums. Last edited by ctuna; 10-28-2021 at 11:59 AM.. |
