BMW 3-Series (E90 E92) Forum
07 335i is acting weird throwing some codes.
10-15-2014, 11:08 AM | #1 |
Rep 27
I was driving the other night and car seemed a lil funny like it had a lil miss to it and gave it a lil gas and started sputtering bad and check engine lights was flashing. Then it just went away and seemed normal. Then it seemed today it was acting a lil funny again. I was running map 4 and switched it to map 2 and didnt notice it as much. Not sure if I have a O2 going bad, fuel pump, plug or coils. Here are the codes i pulled that night.
10-15-2014, 10:01 PM | #2 |
Rep 263
Drives: E46, E91, F21
A faulty ignition coil will cause those symptoms. A way to verify this is to cross-swap it with another coil, say cyl #1, then see if the misfire migrates with the coil in question. If it doesn't then you can start looking at other things. However, it's probably a coil that is starting to fail.
HTH |
