BMW 3-Series (E90 E92) Forum
"Unable to contact DME" during BMWLogger
10-06-2014, 09:59 PM | #1 |
Rep 27
I have a K+DCAN INPA compatible USB cable for my 2009 328i. Using BMWLogger to register my new battery, i'm getting to the point where my device is detected but unable to contact DME. I'm stuck.
Here's my steps:
Not sure what else I'm missing??? Using BMWLOgger to install drivers never turns the "FT232R USB UART" into a Port. I've tried also changing com5 to com1. (Sorry, don't know how to embed images inside text) |
10-07-2014, 07:39 AM | #3 |
Guest
Rep n/a
Drives:
If you click the drop down on that Connectivity -> Device menu, are there any other options there to choose from? While trying to register my battery with the software I couldn't get the car to connect either. After I went into that drop down and changed the Device to K+DCAN, or something similar, then it worked like a charm!
10-07-2014, 08:30 AM | #4 |
Rep 27
Sensible: I'll try 1. I tried 8 but didn't make it to 1.
Cobra: My drop down only lists the "F232R USB UART". I was wondering if DEVICE had to say something about "Com port"?? Thanks for the inputs. |
10-07-2014, 11:32 AM | #6 | |
Rep 27
Can someone confirm/verify what device needs to be displayed in BMWLogger?? Last edited by wpetering; 10-07-2014 at 11:37 AM.. Reason: changed a device name. |
02-27-2015, 01:22 PM | #7 |
Rep 1
Same identical problem
I have exactly the same problem. Tried with a Mac OS, tried with Windows XP but no change. Did anybody figure it out? Is it just the cable not working properly?
11-28-2015, 06:17 PM | #8 |
Rep 644
12-16-2015, 07:46 AM | #9 |
A family of bimmers
2757
Rep 7,743
I am about to try this and noticed you have it on COM5. i thought it needed to be COM1 with a latency of 1. Let us know if you figure it out as I am going to register my battery this weekend with this software
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
10-18-2016, 09:45 PM | #11 |
Rep 64
Hi
I searched but couldn't find any useful information on this issue. Has anyone figured out the "Unable to contact DME" issue with the BMWLogger software? I am having the same issue right now.
Thanks |
10-31-2016, 08:23 AM | #12 |
Rep 27
Still same issue. My cable and software is from BMWLogger. I'm using Windows 10 as well.
Only change is that I can read codes from the DME but when I try to clear codes, I get a "packet failure unable to connect to DME". I've re-installed software. Need to verify the license key is installed. And check drivers. I may go back to my Windows XP laptop and try it to rule out a bad cable. Cheers. |
11-01-2016, 11:32 AM | #13 | |
Rep 64
I was able to resolve this issue.
