BMW 3-Series (E90 E92) Forum
Retrofit voice control how to import fsc for non voice control car
09-02-2014, 10:33 AM | #1 |
Rep 328
I've retrofitted a prof. navi with voice control in my E90 2006. The ccc unit is from a 2006 with voice control. ($620)
My car hasn't got option $620 when it left the factory. I've the 2 files from the donor to enable $620. How should I do this and can this only be done with ista-p? I don't think I can get away with it by only changing the vin in the xml file. |
09-10-2014, 01:56 PM | #6 |
Rep 328
09-14-2014, 10:54 AM | #8 |
Rep 328
09-14-2014, 11:00 AM | #9 |
Rep 328
Something else...when someone retrofitted a cic iso a ccc unit can you still calculate map codes?
I've a tool + Icom which calculates map codes but it has to be connected to the car. Will this still work when you retrofitted this? If you want to retrofit speech recognition when you retrofitted a cic unit. Is that possible? |
