01-11-2022, 03:58 PM | #1 |
Rep 14
Any suggestions to adjust the height of the Valvetronic EL exhaust tips?
I just got the Valvetronic equal length exhaust installed and I noticed that the left side tips were hanging a bit low. What's the best way to fix this? Should I get new hangers that are shorter? Here are some pictures for reference. Excuse the very dirty car lmao
01-11-2022, 04:13 PM | #2 |
Rep 201
You could bend the hanger up.
2021 M2C, HS, 6MT, ZED, 763M w/spinners, AA single, AA axle back, Turner High Kick, Turner shifter support, M pedals, honeycomb reflector delete, BC Racing DS series
01-11-2022, 07:26 PM | #3 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Glad to see they changed the rear muffler on the latest set of exhausts they built. The easiest way is to loosen the muffler tips and push in the direction you want to adjust and then tighten. Most likely it will be easier to adjust the right side lower.
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid |
01-11-2022, 07:27 PM | #4 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Post more photos of the full exhaust setup if you have them. Would love to see the differences from mine!
-2021 M2C, HS, 6MT
01-12-2022, 08:55 AM | #5 |
Rep 14
Okay awesome I'll try that thank you. Was hoping I could raise the left side because I like the way the right side fit but I'll see what I can do.
01-12-2022, 08:56 AM | #6 |
Rep 14
I didn't take too many pictures but I'll see if I can get some and post them! Your thread about this exhaust was one of the reasons I decided to get it actually.
01-12-2022, 09:07 AM | #7 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Ive been talking to Austin and they are still experimenting w/ this exhaust for the M2C. Trying different mufflers and resonators. I actually welded different resonators and rear muffler on mine. Did your exhaust come with that muffler or did you rotate / weld a new one? Hope youre enjoying the sound though! I sold my REMUS setup and could never go back to a non EL system.
-2021 M2C, HS, 6MT
01-12-2022, 09:47 AM | #8 | |
Rep 14
It came with that muffler. Is that muffler different than the one you got? Maybe that has to do with the fitment issues. I also asked about the midpipe hanging low and they said that will happen since it is the EL design. I'm loving the sound, it is amazing! If I can fix the fitment issues it will be perfect. |
01-12-2022, 10:00 AM | #9 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
I dont know when they fixed it, but the first batch of 5 exhausts did not have the muffler tucked. Ive attached two photos. The M2C photos I believe had the second exhaust they made. The muffler isnt flat, but instead sticks out low and can easily be seen from the rear of the car. Yours looks like they updated it to fit flat like the F80 version (2nd pic).
-2021 M2C, HS, 6MT
01-12-2022, 10:06 AM | #10 | |
Rep 14
Ah interesting I see what you mean now. It does look like I have the updated one. Interestingly enough mine was delayed in shipping and I was told it was because they were updating it to have better fitment. |
02-04-2022, 10:41 AM | #11 | |
Rep 14
It does seem like the midpipe and muffler hang a little low as well but maybe that's normal and there isn't much I can do about that. Here are a bunch of pictures I took. Let me know if there is anything specific I should try to get a picture of and I can try to get that. The only other fix I saw on the forums was this one, https://f87.bimmerpost.com/forums/sh...3&postcount=28, with the Dinan exhaust which seems to have a similar fitment issue. |
02-04-2022, 08:36 PM | #12 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
I think yours look good (looks really even). Do you like the look when its not on a lift? I really like my fitment in person as it is now. If you want to try to adjust it more (With aftermarket or stock hangars), I would try to twist the connecting pipes which will allow you to adjust the angle where the Y pipe is. Its hard because its straight slip ons, but if you take a dead blow hammer you can keep tapping away and adjust slowly. I did have the exhaust tips nearly flush at one point but put them back to how you see in the attached picture. To do that, I put aftermarket rubber hangars on the connecting pipes to make them 1 hole lower. This allowed me to slightly twist the connecting pipes and angle the rear upward. The problem with that is the aftermarket hangars are softer and allowed the exhaust to move more. This made the tips rub against the diffuser on bad roads and scratched both the tips and diffuser. edit: I would do the Dinan fix you mentioned above. Toss on the stock rubber hangars for stiffness, order a new set of rear metal mounts and take it to a shop. Let them align the height, cut the new metal mounts to the appropriate length and weld. Would be quick, stress free and fix the gap.
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid Last edited by CoffeeLife; 02-04-2022 at 08:41 PM.. |
02-09-2022, 03:03 AM | #13 |
Rep 15
I have a similar issue with my Eisenmann and just bought a pair of exhaust hangers from "Evil Energy" which are a few millimeters shorter than stock. Have not tried them yet but should work as you don't need much lift.
02-11-2022, 09:12 AM | #14 | |
Rep 14
On another note what rear diffuser is that on your car? It looks great and goes really well with the carbon tips! |
02-11-2022, 09:14 AM | #15 |
Rep 14
Okay cool thanks I'll check out those hangers. Right now the fitment is with other exhaust hangers which allowed me to make both sides even but I couldn't really get the left side any higher.
02-11-2022, 10:48 AM | #16 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Photos attached for reference.
-2021 M2C, HS, 6MT
02-11-2022, 11:05 AM | #17 | |
Rep 14
One other question for you. Are you running the stock downpipe or a highflow or catless downpipe? I eventually want to get a downpipe and a tune but I didn't see anybody with the valvetronic exhaust and a non stock downpipe. So I was wondering how it would sound with either of those. I've seen some exhausts with a catless downpipe sound terrible on this car but those exhausts were non-resonated and since the valvetronic one is resonated I assume it will still sound good. |
02-11-2022, 11:25 AM | #18 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
My friends out here can already hear me from blocks away with just the valvetronic exhaust on the S55....so I'm happy as is haha.
-2021 M2C, HS, 6MT
06-27-2022, 09:50 AM | #19 | |
Rep 14
I don't think it can get any better because if it got raised any higher the mid pipe would be hitting the sub frame. Also I noticed that after I was talking to the Valvetronic customer support and showed them all these fitment issues they took down the listing for the M2 Competition exhaust off their website. |
CoffeeLife397.00 |
06-29-2022, 02:25 PM | #20 | ||
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Yea idk they started ignoring my messages haha. I'm happy with the exhaust after i spent like $1000 additional to fix it zzzzz. Wish they would have offered to pay some back. I'll keep it on unless a company release something better in the future. I really really don't understand how they still couldnt fix their fitment issues on the version 2 system you got. Especially after all the fitment and production issues on the V1 system.
-2021 M2C, HS, 6MT
chris7197331.50 |
06-29-2022, 07:25 PM | #21 | |
Rep 14
I'll keep mine on as well until something better gets released in the future. It doesn't make any sense to me either as to why they couldn't fix the fitment issues. If the fitment was better it'd be the best option for this car easily. I'm glad they took the listing of the exhaust off their website though so know one else will have these issues. If they make improvements to it they should at least give the new/updated version to customers that bought the older versions. |
CoffeeLife397.00 |
