01-04-2022, 04:36 PM | #1 |
Rep 112
Drives: 2020 LBB M2C
All Seasons instead of Snow Tires in a pinch?
I just received a promotion and will be moving from Texas to Pennsylvania most likely next week. Things move fast! I'm starting to look for snow tires, and I'm not having much luck locally so far (big surprise in Texas). Since time isn't on my side, would an all season tire, like a Michelin Pilot Sport All Season 4, be a reasonable substitute? I'm not sure I want to drive my PSS's up there during this time of year.
01-04-2022, 05:31 PM | #2 | |
Rep 432
That being said, I run Michelin Pilot Alpin PA4 out of the Philly area due to trips to upstate NY. Summer wheels and tires are Michelin PS4s. Good luck with the move. |
01-04-2022, 05:33 PM | #3 |
Rep 392
A/S tire will be fine unless you intend to actually drive in snow.
Since I never actually drive my car in snow, I'm considering replacing my snows with A/S when the time comes. Seems like A/S will also be better for the changeover periods when it can be 30 one day and 65 the next. |
01-04-2022, 08:38 PM | #4 |
Rep 112
I'm going to Wilkes-Barre. I plan on getting a 4WD vehicle of some type when I get up there, but there's a good chance I'll have to drive in the snow before that can happen. The M2 will turn into the weekend/summer car. I'm definitely keeping it!
01-04-2022, 08:48 PM | #5 | |
Rep 1,644
So really it comes down to area. Not much snowfall = all seasons. Lots of potential snowfall = snow tires. |
01-04-2022, 11:13 PM | #6 |
Rep 7,297
Unless you can work remotely anytime it snows, you'll want winter tires in that area.
01-05-2022, 07:07 AM | #7 |
Rep 1,644
If you only plan on using the M2 this winter, see if you can find some cheap snow tires that will fit on the stock wheels and just swap your PSS back on after winter. Once you have a 4wd winter car you'll just have to be prepared to sit the M2 most of winter due to the temps. You can always switch to all seasons permanently if you wanted to keep driving in the colder weather.
01-05-2022, 07:42 AM | #8 | |
Rep 566
PS: get those Pirelli Winter SottoZero Serie II from TireRack in 245/35/19 + 265/35/19 for the moment and you should be good for most winter conditions you are likely to encounter. Last edited by x233; 01-05-2022 at 07:49 AM.. |
