11-24-2021, 06:15 PM | #1 |
Rep 1,328
19" Front Tire Fitment
Options seem to be limited for 19" tires.
I want to run a 265/30 or 275/30 front tire with a 305/30 rear but the only options available seem to be: Falken RT660 (horror stories) Yokohama AD08R (old tech) My other option would be to run this setup: Goodyear Supercar 3R 265/35/19 and 305/30/19 Is this too aggressive for the front? |
11-24-2021, 06:53 PM | #2 | |
Rep 6,937
Drives: 2018 M2 AW DCT
11-24-2021, 07:14 PM | #3 |
Rep 566
11-25-2021, 06:05 AM | #5 |
Rep 3,337
What's your horror story with the RT660?
Current Stable:
11-25-2021, 08:12 AM | #6 |
6637
Rep 4,145
Drives: '18 M2 6MT
Not sure what you're looking for exactly, other than an ultra wide 200 TW tire, and in that regard, the AD08R (aging or not) in 275/30 & 295/30 is your solution. It's a very wide running tire, so forget the 305, and you're have to camber the hell out of the front to make the 275 work.
Your tire is the upcoming RE71RS...but it's unavailable at this point. |
Rundskop148.00 |
12-13-2021, 09:49 PM | #7 |
Rep 76
SportCup2 could work with a 295 and 265.
R888R might be cool. Do you really need the 305 rear given that these are track oriented tires? (weight, cost, fitment etc.) You could run the RT660 but with a 275/30 front and 305/30 rear. It has same overall diameter as OE size PSS. Depending on front wheel fitment even a 265/30/19 MP4S will likely rub at full lock on the fender liner. At least it does for me at -2.5 front camber. |
12-14-2021, 06:52 AM | #8 | |
Rep 1,759
Dry grip and wet grip is obviously higher than the current 08R. A racing driver who tested the AD09 and the A052 at the same time said lateral G is very close to that from the A052 |
CSBM52721.00 |
12-14-2021, 07:38 PM | #9 | ||
Rep 1,328
12-14-2021, 07:47 PM | #10 |
6637
Rep 4,145
Drives: '18 M2 6MT
Um, that's one of the best drive-to-and-from track tires you can get, especially in the wear department. Are you looking for a tire that wears out in one lap? Try the AR1.
Subjected to colder temps? |
Rundskop148.00 |
12-15-2021, 04:59 AM | #11 |
Rep 3,337
Tread splice opened up?
Current Stable:
