09-03-2021, 12:52 AM | #45 |
Rep 594
Drives: M2C
FWIW I've found the midpipe alone (ie with stock muffler) drones with valves open at around that same range. Not terrible, but it's noticeable. And as you guys are mentioning the easy fix is to close valves.
Realistically during city driving I'll leave valves open and if I start hovering around a stable 3k and getting drone then I'll just upshift. If I'm already in 6th and still stuck at 3k then it means I'm highway cruising at 80+ mph. In that scenario I'll either have music on and the road noise + music means it drowns out the drone for me. Or, otherwise without music start noticing the drone and given the highway cruise scenario not mind at all just flipping to Efficient. |
Nicname351.00 |
09-03-2021, 11:38 PM | #46 | |
Rep 1,681
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
09-11-2021, 12:45 PM | #47 |
Rep 180
Started a thread in the regional section for the CT area.
I've heard of CCM and The Shop, but I was wondering if anyone has dealt with any auto shop that they recommend for exhaust/midpipe installs, etc. Would come in handy for the tougher maintenance items in the future.
__________
2020 A/W M2C, 6 M/T, Executive Package, Moonroof Mods: 20% tints, Full PPF and Ceramic Pro, IND A/W reflectors, Remus Sport, AA EL (non-res), BMC Filters, BM clutch stop, ///M tire caps |
09-20-2021, 10:19 AM | #48 |
Rep 1,681
Update:
I have ordered the non resonated section to try out and see if I get that little boost in volume that I want. Hopefully in the next week or two I can compare the tones and volume of the res vs non res version.
Current: ///M2C
09-20-2021, 10:58 AM | #49 | |
2426
Rep 11,667
I would think that drone will get worse. |
09-20-2021, 11:05 AM | #50 | ||
Rep 1,681
Current: ///M2C
inTgr8r2425.50 |
09-20-2021, 11:20 AM | #51 | |
2426
Rep 11,667
I'm not in love with that one sleeve clamp between the AA section & Remus. I'm almost certainly going with this system as well and will likely weld everything except the bell joint between the 2 AA sections. Coming from an E92M3 where there were several joints in the OE exhaust, I was VERY surprised that the M2C OE setup is welded all the way through from the DPs. Can't help but think that they did this for a reason other than ease of assembly. Love your work on this and the write up ! Great resource for the community. |
09-20-2021, 11:25 AM | #52 | ||
Rep 1,681
Thank you for the kind words just looking to help people make decisions since I pretty much jumped in blind with this setup.
Current: ///M2C
09-25-2021, 07:18 PM | #53 | |
Rep 11
Also, could you please record a video driving/shifting hard/open throttle if you get a chance? Appreciate everything so far - thanks again. |
09-27-2021, 12:47 PM | #54 |
Rep 180
Came home from vacation to see my mid-pipe had arrived!!! 🙌🏼
Impeccable packaging from Active Autowerke, unlike Remus on theirs 😑.
__________
Nicname351.00 |
09-27-2021, 01:35 PM | #55 | |
Rep 1,681
That taping in the Remus was done by me after inspection.
Current: ///M2C
Navy Davy220.00 |
09-27-2021, 01:46 PM | #56 | |
Rep 180
I'll most likely be having CCM in Portchester, NY do the install and weld the connection points. They also said they have a pipe extender for any bent ones.
__________
Nicname351.00 |
09-27-2021, 03:45 PM | #57 | ||
Rep 1,681
Current: ///M2C
09-27-2021, 04:06 PM | #58 | |||
Rep 180
__________
09-27-2021, 04:07 PM | #59 | ||||
Rep 1,681
Current: ///M2C
Navy Davy220.00 |
09-27-2021, 07:10 PM | #60 | |||||
Rep 180
Btw could you post what you had in your Remus Box so I can compare?
__________
09-27-2021, 09:06 PM | #62 |
Rep 80
09-28-2021, 07:13 AM | #63 | |
Rep 180
__________
Drew41561.50 |
09-28-2021, 08:48 AM | #65 |
24161
Rep 190,725
