08-18-2021, 05:39 PM | #1 |
Restless
1332
Rep 1,031
Do I need to polish a new car before applying ceramic?
My M2C is about a week away. My plan in the first few days will be to give it a good wash, iron out, tar remover, plus light clay sponge if needed in certain spots. IPA wipe down next, followed by ceramic coating. My question is do you think I should do a light polish of the paint on the new car prior to the ceramic coat? The color is Hockenheim so I’m assuming I won’t see any glaring defects in the paint. TIA.
08-23-2021, 08:41 PM | #6 | |
Rep 7,252
Foggins1331.50 |
08-23-2021, 09:19 PM | #7 | |
Restless
1332
Rep 1,031
chris7197273.00 |
09-02-2021, 10:52 AM | #8 |
Rep 51
If you’re looking for 100% perfection, it’s best to get some correction done, since the car isn’t perfect when it leaves the factory and gets shipped. However, as others have said unless the dealer has washed it with dirty mitts, you’re likely fine. For what it’s worth, I took delivery of my M2C a few weeks ago. I had PPF installed by the dealer before taking delivery. I’m going to apply a ceramic coating myself this weekend. I plan on washing, decontaminating with clay bar and iron x, use isopropyl alcohol to remove any oils, then apply a ceramic coating. IMO this will suffice for my needs. It’s going to be hard to see any imperfections (swirls), unless you’re closely inspecting with a correction light. I’ve looked over the car with an iPhone flash light and in direct sunlight and the paint looks good. The ceramic coating im applying will only last a few years and the plan will be to get paint correction then and apply a new coating. This way I’m saving layers of the clear coat. There’s a YouTuber by the name Pan the Organizer that does a lot of paint correction and ceramic coating. When he took delivery of his new 5 series a few years ago, he did not do any correction and just decontaminated the paint and added the coating.
Foggins1331.50 |
09-02-2021, 11:22 AM | #9 | |
Restless
1332
Rep 1,031
