05-13-2021, 02:18 AM | #1 |
Rep 184
Drives: 2017 BMW M3 Competition (LCII)
What oil should I use for my N55 M2?
Hi all,
My M2 LCI (N55) now has around 8000 miles on it and I'm planning to change the oil soon. The car started life out with BMW Twin Power Turbo 0w30 and continued to do so, after its first break-in service. Fast forward to today: should I stick to this oil, or should I get a different one? The car never gets tracked, I plan to do oil changes each 5000 miles, the car is as good as stock (cold-air intake, boost- and chargepipe and turbo inlet pipe) and I live in a normal European climate. Furthermore, I do not care about fuel saving oil, I just want the best protection and BMW approved oil, with all the right additives. Price is not an issue as well. Look forward to hearing your thoughts, thank you. |
05-13-2021, 08:17 AM | #2 |
Rep 1,485
Go regular LL01 or LL04 oil. You are in Europe and you have access to better oils actually. You can go LL04 too as fuel in EU is probably of the best quality in the world.
I would go this: https://www.shell-livedocs.com/data/...123454fbda.pdf https://d23zpyj32c5wn3.cloudfront.ne...pdf?1492017850 |
05-14-2021, 10:04 AM | #3 | |
Rep 184
https://www.winparts.nl/productpage/...41069.html?v=i This is the one I bought |
05-14-2021, 11:06 PM | #4 | |
Rep 1,485
This Castrol is a bit above average oil, but IMO, not in line with those two. Now, take into consideration this is splitting hairs and your engine won't self-destruct |
05-16-2021, 03:54 PM | #5 | ||||
Rep 184
05-16-2021, 10:18 PM | #6 |
Rep 1,485
LL19 is the latest thing. It just came out. It takes a year usually for manufacturers to reblend, package, change packaging etc.
09-09-2021, 04:13 PM | #7 |
Rep 266
I just noticed that FCP Euro besides Liqui Moly only carries 5W30 Pento High Performance Engine Oil
Approvals ACEA A3/B3 ACEA A3/B4 API SL/CF VW 502.00 VW 505.00 BMW LL-01 MB 229.5 GM-LL-B-025 Any thoughts on how this would compare to Pennzoil euro platinum? |
09-09-2021, 09:12 PM | #8 | |
Rep 1,485
Pentosin is IMO really good oil. It is better than Liqui Moly. It is more traditional oil utilizing high quality Group III and IV base stocks. It is owned by Fuchs now, largest German industrial lubricant manufacturer. If you going FCP bcs. free oil changes, go Pentosin over Liqui Moly. If you want beat performing oil for N55 and out of warranty go Castrol 0W40 or Mobil1 0W40FS or if still under warranty: Motul X-Cess 5W40 GEN2 or Pennzoil Platinum Euro. Another great oil is Valvoline 5W40 European Vehicle. |
tenkies147.00 |
01-08-2022, 06:12 AM | #9 |
Rep 38
Hi Hunter,
Enjoy your youtube vids. I just ordered 20liters of Ravenol VST 5w40 which is LL01 Approved. Reasonably priced at 9€ / Liter. Shell HELIX 5w40 is even better priced, also LL01. (I live in sweden, so i opted for the ravenol which has a lower pour point of -51C) Difficult to ask on forums since many here reside in the US. So seems to be different specs, labels and even manufactures recommendations for different markets. |
TheHunterHofman237.00 |
01-11-2022, 03:00 PM | #11 |
Rep 7,423
He's in Europe so helix is way better priced and essentially the same oil.
///MPhatic13855.50 |
01-11-2022, 03:54 PM | #12 |
The Seeker
13856
Rep 3,317
01-11-2022, 04:01 PM | #13 | |
Rep 7,423
But in the US quaker state euro 5w40 (same thing as PPE) is alot cheaper and easier to find so you might want to switch to that.
01-11-2022, 07:58 PM | #14 |
The Seeker
13856
Rep 3,317
01-11-2022, 08:05 PM | #15 |
Rep 7,423
Yup, shell owns both Pennzoil and Quaker state (under SOPUS) so those oils (Pennzoil platinum euro 5w40 and Quaker state euro 5w40 is a relabeled helix ultra from shell).
///MPhatic13855.50 chris7197334.00 |
01-23-2022, 09:31 PM | #16 | |
Rep 553
https://www.shell.com.au/motorists/o...tra-5w-40.html I've been using Redline ester-based High Performance 5w-30 & 40, changing every 6-8K km. I do around 12 tracks days a year plus a few trips to country/mountain roads where we can be going full-on for 70km stints. The Redline is harder to source & cost isn't a concern if it's better as I'm keeping the car forever |
01-23-2022, 10:31 PM | #17 | |
Rep 7,423
If you track that much make sure your OCI is a but lower, take a used oil analysis to make sure there isn't too much degredation on the oil after track days so you don't run old oil on the street for too long. Also if you're pushing pretty hard on track maybe use some motul sport oil or 300v just for the track, again a UOA will tell you more. But that will depend, I personally think you should be ok with street oil if you're not extremely heavily modified - again a used oil analysis will tell you more.
