M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Trying to run 11 inch rims at the rear, am i crazy?
      10-16-2020, 05:55 PM   #1
eddymmm
Drives: BMW M2 LCI
Okay guys, so I have wanted these rims for a while but unfortunately they are not available in 10.5 width with proper offsets for our cars. So I have done some research and used the website below to check the following setup. Ive triple checked to make sure it all seems reasonable and I am on completely stock suspension. What do you guys think?
https://www.willtheyfit.com used to check fitment
Wheel specs
Apex SM10
19 x 9.5 +22 265/35/19 PS4S F
19 x 11 +44 (with 5 mm spacer, so effectively +39) 285/35/19 PS4S R
5x120
      10-16-2020, 05:59 PM   #2
eddymmm
Drives: BMW M2 LCI
Also before any one says im completely idiotic for even thinking of this, heres why I think itll work.
https://wheelfront.com/cars/bmw-m2-f87-blue-apex-sm-10/
Another guy did it but hes running stock tore sizes which imo is too much stretch
      10-16-2020, 06:03 PM   #3
ZM2
Drives: 2017 LBB M2
It’ll work but be very tight to the fender under compression.
If it’s too close, just remove the spacer or run a 3mm spacer to set it right in between the fender and suspension.
      10-16-2020, 06:47 PM   #4
No Boost
enthusiasm > practicality
No Boost's Avatar
Drives: 987 CS | G35x
Call Apex and speak to Ryan. They are supremely knowledgeable about all things regarding tires/wheels.
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp
Left lane campers, GTFO!
      10-16-2020, 07:43 PM   #5
mr_lab_rat
mr_lab_rat's Avatar
565
Drives: 2017 M2, 2018 X1
At ET39 you are running about 11-12mm wider than stock. Bunch of people run 10-15mm spacer in the rear so you are not entering uncharted territory. This shouldn't be too difficult to fit with the right tire, camber, and ride height.
But I don't have personal experience with this so contacting Apex would be the safest.
Edit: I just noticed your tire size. No, that's not the right tire. 295/30/19 would be better.
      10-16-2020, 07:47 PM   #6
eddymmm
Drives: BMW M2 LCI
I have and they tell me to look at their recommended fitment guide which doesn't include the setup i have listed. Havent personally spoken to Ryan though so maybe I'll try that
      10-16-2020, 07:48 PM   #7
eddymmm
Drives: BMW M2 LCI
May I ask, what is wrong with my tire choice? Too tall?
      10-16-2020, 08:29 PM   #8
mr_lab_rat
mr_lab_rat's Avatar
565
Yes, it's taller than stock and you are already pushing the limits with the wheel size. It doesn't mean it won't fit but dropping the sidewall ratio should get you close to OEM diameter.
      10-23-2020, 12:44 PM   #9
s1k0ne
Drives: ..
This is correct. you'll need to go 30s in the rear and 35s in the front with that width in the rear.
it'll look a little off with different height tires but this also depends on what type of tires you get
F85 (17) - DG/AB
F87 6MT (20) - Comp - BSM
F80 DCT (18) - Comp - AW
F30 6MT 335i - EBII
      10-23-2020, 01:08 PM   #10
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
The 19 x 11 +44 will work fine with the 295/30 (it's close, but you can camber the difference).
If you MUST use that spacer, I recommend that you go with a 285/30 on the rear, which will crown a bit, but work much easier.
Your front tire size is wrong as well, should be a 265/30 at the widest, but at +22 you're probably going to have issues without dropping it pretty low or cambering it, so consider a 255/35 with a more rounded shoulder.
Just remember this:
Perfection is:
19 x 9.5 +28 w/ 265/30/19
19 x 10.5 +43 w/ 285/30/19
You're not far off those specs.
      10-23-2020, 01:21 PM   #11
eddymmm
Drives: BMW M2 LCI
Just remember this:
Perfection is:
I selected that spacer because effectively itll give me a +13mm over stock which is exactly what i like(currently running +12mm all around and i love it)
The front without a spacer will give me +13mm as well so that's exactly what im looking for
      10-23-2020, 01:25 PM   #12
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
That's aggressive with such big tires...
      10-23-2020, 09:33 PM   #13
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
I am running 285/30 19 on a 10J 34ET rim and the tyre is slightly (1mm) poking out from the fender.
Your 11J 44ET setup will poke out 3mm more than mine and with the 5mm spacer, 8mm pokier.
Add to the fact that you want to go 35 profile which is about 1.5cm taller in radius, 3cm taller in overall height...
I just don't see how it will not rub under heavy suspension compression.
To make a 11J work on a 285/35 setup you need to throw out the spacer and go with a 48+ ET
Perhaps you can camber out the rub but you will lose straight line traction as a result and couple with excessive inner tyre wear if the car is mostly street driven
      10-29-2020, 09:46 AM   #14
ROBM2C
ROBM2C's Avatar
Drives: BMW M2C , DATSUN 260z, Porche
A lot of people are running 11 rears. Just need some stretch and maybe a touch of negative camber depending the offset .
      10-29-2020, 03:38 PM   #15
Expert@ApexWheels
Expert@ApexWheels's Avatar
3523
Drives: M3
I helped a customer a while back with a unique 19"/18" combination. He was running 18x11 ET44 EC-7s in the rear with 19x9.5 ET28 in the front to clear the M2 Comp. brakes. Rear tires were 305/35-18 Nitto NT01s. It fit, but I believe he was running a bit of additional negative camber in the rear to make it work.
VisualEcho makes a very good point about the front fitment as well... 19x9.5 ET22 is a lower than ideal offset and will require camber and/or tire stretching to fit in most cases.
The 19x11 ET44 wheel size can definitely work although running slightly stretched 285 or 295 section tires will definitely make it easier. I would not recommend running a spacer as it's just going to reduce fender clearance. I'll see if I can dig up photos of the 18x11 ET44s on an M2 although if I remember correctly the images weren't the best as far as figuring out rear fitment goes.
Edit: Images added
Specs:
Front: 19x9.5 ET28 EC-7s with 255/30-19 Michelin PS4S (stretched)
Rear: 18x11 ET44 EC-7s with 305/30-19 Nitto NT01s
Not a fitment I would recommend for most people but it worked for this individual. Hope this helps!
-Tom
      10-31-2020, 04:17 AM   #16
Sallysalkeld
Drives: M2Competion
Just remember this:
Perfection is:
Hi mate! would you say those specs are also perfect for 18"??
Trying to find the perfect fitment for track wheels.
      10-31-2020, 07:28 AM   #17
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
18" are a bit different, just as 20" is, so no, I'm not exact on the specs for those sizes. Search for a thread here on Bimmerpost called "max rubber on the m2", I think it'll have the answers you need.
      10-31-2020, 12:25 PM   #18
mr_lab_rat
mr_lab_rat's Avatar
565
The rim diameter shouldn't really change things much.
is very close to (5mm larger overall diameter)
18 x 9.5 +28 w/ 265/35/18
18 x 10.5 +43 w/ 285/35/18
      11-12-2020, 07:55 PM   #19
F80_Katz
F80_Katz
764
Drives: 2020 M2 Competition
2008 Bmw E90 M3  [0.00]
You really shouldn't need the spacer in the rear. Front 22 is also pretty aggressive for a 265/35 and may rub a little.
I ran a 305/30/19 on a 19x11 et40. Was too much poke for me. See below...
      11-15-2020, 11:29 AM   #20
bngcruiser
bngcruiser's Avatar
Drives: '89 Land Cruiser, '18 M2
2018 BMW M2  [0.00]
Would like to know more about this, thinking of running 19x11 et37 with 285/35/19 ... aftermarket coils? Camber? Any advice would be appreciated.
      11-15-2020, 06:48 PM   #21
F80_Katz
F80_Katz
764
Perfect fit for f80/f82 but for the m2, even with the 285 you'd have to run about -4 degrees of camber to fit properly. It's doable if you like that look but pretty aggressive.
      01-17-2022, 05:45 PM   #22
AAW187
Bahrain
Hello sir, could you provide more photos of this wheel and tire setup. Looking to do similar setup for my m2c.
Thank you !!
