M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Custom Intake Snorkel
      05-22-2020, 09:23 PM   #23
flybigjet
Remove Before Flight
flybigjet's Avatar
Drives: M2C & Boeing's light twin
Originally Posted by Malakas View Post
Pieces are printed!
Excellent-- and now, do they fit? And are they installable without taking the car apart?
Waiting with breathless.....anticipation.
(With apologies to Dr. Frank N. Furter)
      05-22-2020, 09:48 PM   #24
Detoxified
Drives: M2C HS
Pieces are printed!
So excited 🙌🏼 these look like they can be finagled in without removing the headlights. With the bumper off there is a lot of room for access.
Appreciate 4
      05-23-2020, 09:34 AM   #25
Alfy
Alfy's Avatar
Lebanon
79
Drives: M2 Competition
It looks amazing!!!!!!!!
      05-23-2020, 01:15 PM   #26
Commanderwiggin
Commanderwiggin's Avatar
2050
Drives: M2C - X3M - Turbo E46 M3 - 45E
Pieces are printed!
Looks great! Is there another piece that transitions to connect to the radiator inlet area?
Also need to block off the hot air inlet hole on the side of the main piece too I think.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration
1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder
      05-23-2020, 01:27 PM   #27
flybigjet
flybigjet's Avatar
I do think you'll need a cover on that-- maybe the BMW one (13718507321) could be made to fit with the modified snorkel?
      05-23-2020, 02:30 PM   #28
Malakas
Drives: 2020 M2c
Will know this weekend - we have a solid install plan, so Im hoping these will slide in without bumper removal. Steve suggested I make the piece that fits into the stock unit a touch smaller just so its easier to fit... I could see that being a barrier to a good install.
As is, once its latched, shes in there solid.
Thanks so much! Getting there!
Just one piece that ideally will snake right into the radiator in let area. I think its hard to see the whole idea without being able to manipulate it in your hands. It will make a lot of sense post install (fingers crossed).
The other side area is an excellent question. I am making up a snap in part for that area and we will test temps with and without it.
I have a screen attachement for it, looks pretty rad... but as is - a lot of work, it would be easier to do it like the BMW one. Easy to do. Will post pics of current version of the screen later today
Ride: 2020 F87 M2C, 6MT Drive: Nine-Four Motorsports
Before:
2013 - 3.8L GTR, first DCT
2012 - 5.2L R8 v10, 6MT
2011 - 4.0L E92 M3, 6MT
      05-23-2020, 02:43 PM   #29
flybigjet
flybigjet's Avatar
Maybe in the interest of the KISS principle, make the snorkel accept the BMW grill?
I've got the M3/M4 parts if it would help you to use as a template.
Of course, if your intake is larger than BMW's all bets are off.
Just a thought as I desperately try to delay replacing an entry door handles and lock.....
      06-19-2020, 08:09 AM   #30
Malakas
Drives: 2020 M2c
... sorry for the delay on this guys. My job got crazy once we stopped the home quarantine, and its been a bit of craziness every day trying to stay on top of it. Then I snuck in a little Champcar (Chump) racing at COTA last weekend in the blazing heat, but...
I do have some great baseline IAT data, and hoping to install the snorkel this weekend - will report back
Before:
Appreciate 4
      07-09-2020, 07:38 AM   #31
Sarg33
Sarg33's Avatar
Drives: 2021 X3M
Bump...Any updates?
Can't or Won't?
Current: 2021 X3M
Gone but not forgotten: 2020 M2C LBB MT
      07-09-2020, 06:43 PM   #32
Malakas
Drives: 2020 M2c
Originally Posted by Sarg33 View Post
Bump...Any updates?
Update coming this weekend... work finally gave me a little break and with wife out of town... lol... will install and test.
Before:
Appreciate 6
      07-10-2020, 06:35 AM   #33
JayHT
Drives: BMW M2 Competition
If this project is successful, and I certainly hope that it is, you may want to look into having your project copyrighted to project your idea/project. If you succeed this could be worth big returns in the form of $$$.
Best of luck,
JayHT
      07-10-2020, 07:25 AM   #34
Megator
Megator's Avatar
518
Best of luck,
JayHT
As somone that actually works in IP (intelectual property) and has entrepreneurial exp.
DONT, it wont be worth the hassle and cash of getting any kind of protection on this.
The cost of a design patent (the easiest route in the USA) is 750$. That gives you nothing except a sheet of paper that says this design is mine on date X.
If someone copies you, you still need to take them to court (more $$$) and prove they are copying your design (where a small variation may be enough to be considered different and nullify your case).
AND ANYWAYS, since you have already made the design public it may be hard to protect as you already made it public. (In the EU you would no longer get a patent for it).
hAxel91.00
Brandt51883.00
      07-10-2020, 08:40 PM   #35
Malakas
Drives: 2020 M2c
All good. Appreciate the support!
No plans to get IP... just a fun project to share amongst fellow enthusiasts... will hopefully do a group buy (at cost) so we can all get a break on production even though the prototypes haven't been terribly expensive... but they are SLS, might want ABS or something for a final print. Will see. Data first.
prompt292.00
      07-12-2020, 04:01 PM   #36
Megator
Megator's Avatar
518
Good luck! If the plan is to 3D print them then, good ABS should do. You might have to make it a bit thicker if you use an FDM machine over SLS.
I have a PLA phone holder and now in the dryness and heat it has shrunk to the point my phone doesn't fit. ABS shouldnt have this issue though.
      07-12-2020, 10:08 PM   #37
Commanderwiggin
2050
I also have a Raise3D Pro2 and can print in various filaments...I think Polycarbonate would be perfect.
Malakas469.50
      07-13-2020, 06:06 AM   #38
Megator
Megator's Avatar
518
I found PE to be a pain to print with, but this could be quite OK to print in PE.
The extra flex would also be welcome.
      07-13-2020, 08:49 PM   #39
Malakas
Drives: 2020 M2c
I think once I know it works and fits... (car is apart right now)... then id be happy to share the .stl file and you all can print it up. So many options out there...!
Right now my dam arms are too big to reach in behind the bumper cover and snap off the grill. And its 100 degress in my garage... so even with fans, Ive needed lots of breaks from the heat and the constant swearing
Before:
      07-15-2020, 08:31 PM   #40
Malakas
Drives: 2020 M2c
Ok, update:
The good news - for sure you can install without dropping the front bumper. I was able to remove the radiator support and front grill with only minimal difficulty. Cutting the hole with a dremel was a bit of a process but Im sure I can figure out a way to make it easier.
The bad news - The design was too large in the opening of the inlet to sit properly. So I have another version already printing.
(Also dont mind the ragged hole, I just opened her up to see how much space I would really need. Now I have a template which minimizes the cutting and need to re-seal that area.)
Before:
Appreciate 11
Poochie9104.50
Alfy79.00
hlm2c289.50
Megator517.50
ashtaron141123.00
prompt292.00
Fuji550i389.50
M2_MEDUSA664.00
stefan2349.50
      07-21-2020, 12:46 PM   #41
prompt
Car Designer
prompt's Avatar
292
Drives: M2C
Ok, update:
Very nice!
      07-22-2020, 12:09 PM   #42
Detoxified
Drives: M2C HS
Ok, update:
Awesome! Thanks for the progress update.. can't wait to see the next iteration fitment
      08-23-2020, 08:18 PM   #43
Malakas
Drives: 2020 M2c
Ok, quick update... sorry for slow progress but believe it or not, work has been insane. Secondly, I have a LOT of respect for people / teams who make their own bespoke parts. This can be a total pain, and there are a lot of issues you can not predict until you make the part and try it out.
In this case, these are the revised geometry intakes made out of ABS (instead of SLS nylon). Not to self, they are not as flexible.
Also I thought I had the eyes of a 25 year old and basically made the screen setup so small to put together, that I can barely even see the screws. F that, were going with a new design (in print).
In the pics you see the general idea of a snap on / screw on screen.
Before:
Appreciate 5
      08-23-2020, 08:49 PM   #44
ashtaron14
ashtaron14's Avatar
Hong Kong
1123
Drives: G80 M3
Printing in ABS wooooooo
