M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Custom Intake Snorkel
      05-14-2020, 02:48 PM   #1
Malakas
Drives: 2020 M2c
All,
Ive been feverishly working on coming up with something to suit our cars since this thread illustrated that our poor intakes have no clear path to suck in cold air.
Yes, the stock M4 parts will fit that area, but in that scenario they are pulling in the air at a 90 angle...
My question was whether there was a more elegant solution that would be a less angular path for the air which would ultimately have better flow. I also wanted to be sure that the solution was out of the way of the radiators, and would be cut into the side of the grill plastic in a way that the radatiors would not lose the pressure that is built up in the area by having the space sealed.
So here is the first full protoype. Thanks to Project_F87 for guidance and real engineering support. He suggested I add a piece with some sort of debris protection, which was a great idea.
Below you will see the intake snorkel itself which plugs into the stock piece (already tested) and now (new) snaps on to secure itself. And pictured is an attachment to the front that will hold a screen.
The pieces are being printed as we speak - so I hope to have install pics and IAT measurements soon. I just wanted to drop this teaser ...
As I said on another thread, many questions remain - this may be overkill, or frankly, it might not have any advantage over the M3/M4 part at all. Still it has been a very fun project and we will test IAT before and after and also dyno before and after (with huge fans) to see if a solution like this makes sense.
**Update:
Pieces are printed!
Ride: 2020 F87 M2C, 6MT Drive: Nine-Four Motorsports
Before:
2013 - 3.8L GTR, first DCT
2012 - 5.2L R8 v10, 6MT
2011 - 4.0L E92 M3, 6MT
Appreciate 17
BAN_M2C4180.00
hAxel91.00
Alfy79.00
msdss497.50
hlm2c289.50
6speed_M23633.50
Poochie9104.50
Zuzu2816.00
pz6193278.50
JA-B444.50
omak81148.00
      05-14-2020, 10:27 PM   #2
Commanderwiggin
Commanderwiggin's Avatar
2050
Drives: M2C - X3M - Turbo E46 M3 - 45E
Looking great! Can't wait to see the print and results!
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration
1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder
Malakas469.50
      05-15-2020, 01:57 AM   #3
ashtaron14
ashtaron14's Avatar
Hong Kong
1123
Drives: G80 M3
Happy to see this progressing.
Malakas469.50
      05-15-2020, 04:58 AM   #4
Alfy
Alfy's Avatar
Lebanon
79
Drives: M2 Competition
Amazing work, I can't wait to get a set of these!!
Malakas469.50
      05-15-2020, 07:23 AM   #5
Malakas
Drives: 2020 M2c
Thank you!! Im axious to see how they print.
This took way too long to proceed - but I had issues tearing the car apart for test fits, and also the shape took at least 100 iterations to get smooth
Before:
      05-15-2020, 08:29 AM   #6
hlm2c
Drives: M2C
Nice work!! I'd be interested in ordering a set when they're finally available!
      05-15-2020, 09:30 AM   #7
flybigjet
Remove Before Flight
flybigjet's Avatar
Drives: M2C & Boeing's light twin
For clarity, I understand how/where the M3/M4 snorkel's fit-- and that they have a debris guard of sorts.
While the 90 degree bend may not be optimal (although I'm not certain that you could tell a real-world difference without *serious* instrumentation)-- where do these mount?
Do they come under the bumper/below the lights and mount there?
Two things come to mind: 1) Would they be subject to water ingestion in that location and 2) how would you determine where to cut the plastic? The M3/M4's are buggers in that you have to pull the bumper and headlight, but after that, you have room to work. With these, I'm having trouble visualizing where they go.
NOT trying to beak on you-- just trying to get a clearer idea of how these mount up.
Outstanding work/effort on your part-- I'm *truly* impressed!
Malakas469.50
      05-15-2020, 09:44 AM   #8
Malakas
Drives: 2020 M2c
All good, I agree with all of your comments entirely - appreciate the compliment and the feedback! Im just a car nut like all of you so this has been more of a labor of love than anything.
The idea (that im hoping to show in install pics) is they will mount by removing the radiator support on top and then the grill. These will poke through the side plastic with a hole similar to how you would cut for the m3/m4 piece (slight difference in location).
My goal was to be able to install without removing the bumper, but again this remains to be seen if it is possible. If you look at the OEM piece you see not only does it take a turn but it rises quite a bit too - as do the ones I designed. Per my measurements, having taken everything apart, the intake nozzles themselves should be tucked on the sides of the front grill. Its going to be a tight fit but the install idea is this...
Take off radiator support and front grill.... use the template I made to cut a hole in the plastic with your dremel through the grill opening. Then snake the piece in and snap it to the oem snorkel end. We will see if it works... with the tapering diameter design, it should fit from in the grille inward. Then there will be the issue of how tight of a fit and sealing it (if needed) because the last thing we want is a pressure leak that not only 1) puts air into the engine compartment and under the hood - bad aero, and 2) drops the pressure head that builds at the back of the grill to help the radiator cool.
In terms of water ingestion, I traced the natural flow line of water and placed two holes in the bottom of the snorkel where droplets would likely collect after impacting the back of the snorkel and running down the curvature. I dont think these would impact air flow all that much, with the idea being that this style of snorkel will only like be better than oem at higher intake velocities /pressures ... and as you said - that remains to be proven.
In addition - for now - I am going to keep that side hole open in the oem piece (from the filter to my piece) to see if this helps any water to exit that might still be airborne past the turns. The actual intake filters I had in my GTR were littlerally exposed in the nose, and I never had any issues... but of course this is something to keep an eye on.
The piece pictured above as a screen holder will hold a 0.6mm thick, metal mesh screen that I will cut out, paint, and then further screw in its "frame". This should be a snap on part.
Ideally, all of this will be black so you wont really notice it much and in a very similar place to the eventuri and other branded scoops that sit behind the grill.
(you can see I've been putting likely too much time into this - LOL).
Before:
Appreciate 4
flybigjet6822.00
ashtaron141123.00
Poochie9104.50
      05-15-2020, 09:57 AM   #9
Malakas
Drives: 2020 M2c
Absolutely!
Before:
      05-15-2020, 10:07 AM   #10
flybigjet
flybigjet's Avatar
Honestly, if this works out well, and you can (or are even interested) in scaling up for production, you might just find a nice niche market-- beer money at the very least!
The idea that this would be possible without removing bumper and lights? That in and of itself makes this a better design than the M3/M4 OEM parts!
R.
Malakas469.50
Poochie9104.50
      05-15-2020, 10:29 AM   #11
Conissah
Conissah's Avatar
1576
Drives: 2018 M3
Very cool! Will these be available for sale? Will the STL be available?
      05-15-2020, 10:46 AM   #12
Malakas
Drives: 2020 M2c
R.
Hell yes... paid for beer, is the best beer.
I will be thrilled if it all works and fits - and even moreso if we can generate great data interms of IAT or even horsepower. I mean we all know the engine dies at 6500rpm, and while this is clearly a function of tuning, I dont see how this motor could be happy at high RPM with the stock intake drawing hot air.
We can have it printed in other materials too - even carbon (according to the guys who print for me).
Yes, if it all works as intended, anyone interested in being part of the "test program" should DM me... and if enough people want them - we could even do a group printing for a cheaper price for everyone.
Before:
      05-15-2020, 04:21 PM   #13
Saintjah
Drives: M2C
Where do I sign up?
Malakas469.50
      05-16-2020, 10:54 AM   #14
Malakas
Drives: 2020 M2c
Originally Posted by Saintjah View Post
Where do I sign up?
LOL, let me test them up and then we can print a bunch if people want to try them
Before:
      05-16-2020, 10:07 PM   #15
ashtaron14
ashtaron14's Avatar
Hong Kong
1123
Drives: G80 M3
Tester
I'm okay with having the front bumper removed for this but ideally we wouldn't have to mess with the headlights.
I'm going to get my front bumper removed tomorrow in order to reattach the MP lip. Apparently the Fall-line oil cooler guard has changed the bumper's shape so the lip doesn't sit flush onto the bumper fml
      05-17-2020, 02:00 PM   #16
Detoxified
Drives: M2C HS
I just removed the bumper myself in my garage. It's very easy todo.. now that I know how it would take me maybe 20min tops. The first attempt takes a bit longer since you need to find all the sensors to unhook and bolts to unscrew.
      05-18-2020, 11:38 AM   #17
mike@x-ph.com
mike@x-ph.com's Avatar
https://x-ph.com/sale/
Phone number 702-494-9435
      05-18-2020, 11:43 AM   #18
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
Definitely interested! Would you need to remove the bumper to get this piece into place?
I remember someone put in the M4 part and he said it was a major PITA. Since he had to remove the front bumper cover and I think headlights. Putting everything back together was an alignment nightmare. I think he got it sorted out at the end.
2011 BMW M3 Sedan Alpine White
Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD**
      05-18-2020, 02:22 PM   #19
Malakas
Drives: 2020 M2c
Hopefully not... im hoping to do it via the grill opening. Will know soon * hopefully by end of week! Fingers crossed
      05-18-2020, 04:09 PM   #20
Detoxified
Drives: M2C HS
Took off my front bumper this weekend. Once you find the 2-3 screws behind the wheel well debris plastic shield and the 2-3 sensor plugs it's a breeze. Excited to try this new snorkel on my car once released
Kankles1484.50
      05-18-2020, 05:32 PM   #21
Malakas
Drives: 2020 M2c
Originally Posted by mike@x-ph.com View Post
Thanks Mike
Good to know, the sensor part looked dicey to me on the DIY, but then again I thought drilling into the body panels to mount the lip / diffuser / winglets was nuts until the second or third drill hole... then its no biggie
Before:
      05-22-2020, 03:51 PM   #22
Malakas
Drives: 2020 M2c
Pieces are printed!
Before:
Appreciate 13
