12-23-2021, 09:43 PM | #749 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid |
12-24-2021, 09:40 AM | #750 | ||
Rep 488
I'm running ohlins so the spring perch is bigger. You might not even need the 12mm and can run 10mm or possibly less. |
01-08-2022, 12:44 PM | #751 |
Rep 155
Should I install a m2csR front sway or move to stiffer nitron springs (3way)? I have their softest springs.
Having trouble at some offcamber turns, especially uphill ones. |
01-08-2022, 11:08 PM | #752 | |
Rep 553
01-09-2022, 12:51 AM | #753 |
Rep 3,539
If your spring setup doesn't produce flat ride, you shouldn't only increase the front sway bar IMO.
blitzyo53.00 jason.seki54.00 |
01-10-2022, 08:00 AM | #755 | |
Rep 10
One thing that immediately comes to mind is identifying the onset of over-rotation that's all too common with this chassis. As a general consensus, it seems like most of you guys drive without any nannies on. With music blasting, how can you tell if your roll on throttle is too much at any given point? You mention that the wheel is 'flying all over the place'-- perhaps this is a byproduct of essentially driving with "one hand tied behind your back"? Like, think of it this way, we only receive so much input from a car when driving (feedback through the steering wheel, the seat of your pants, visual references and the audial queues) when you take one of those things away, you limit yourself from being able to accurately interpret what's going on with the car beneath you. You're always carrying the baggage from the previous corner, so your approach, while similar, is never the same. Trying to put yourself in a rhythm, or pump yourself up with music, could be the reason it feels like the car always wants to bite your hand off. When driving at the absolute limit, it should look effortless. It should look like you're on a Sunday drive, you just so happen to be traveling at 140 mph. Ideally, there should be only 1 instance of each input, throughout any given corner. See-sawing at the wheel, on and off throttle multiple times per corner, etc are big no no's and quite dangerous in a car with that can pull as much speed as an M2. I hope this doesn't come off knocking you or anything, just some food for thought.. I always make sure the radio is off when working with students |
01-10-2022, 08:08 AM | #756 | |
Rep 10
I agree with Farkle, that's a loaded question. Could be a lot of things contributing to those feelings. Anecdotally, I installed the CSR front sway bar a few months ago and it made a world of difference and I love it! I don't have any valuable advice for your question, but tinkering with the sway bar seems like a cheap and easy way to find out if it helps. It can easily be swapped out between sessions on track. |
01-10-2022, 08:10 AM | #757 | |
Rep 2,602
I personally try as little steering input as possible mid corner.
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
01-10-2022, 08:26 AM | #758 | |
Rep 10
Driving is rarely ever black and white. So, I can't speak to why some things work in certain situations and why some things don't. But, I will say as a general rule of thumb-- corrections are just that, corrections. It implies a mistake was made (big or small) and you needed to fix it |
01-10-2022, 09:03 AM | #759 | |
Rep 155
I'd just have to experiment, I guess. I have nitron's lightest 685/400 lbin (rear coilover) springs on currently. |
01-10-2022, 10:44 AM | #760 | ||
Rep 3,408
Seesawing the wheel is different than constantly catching the car which is by definition the "limit". So if you're driving around effortlessly than there is no way you're anywhere near the limit. Looking at data the steering inputs and throttle inputs generally should be isolated such that one is at constant at any given point. If your steering is wild and throttle is wild concurrently then yes there's opportunity to smooth it out. EDIT: realize we're largely saying the same thing as it relates to concurrent inputs.
OG Shark4692.50 |
01-10-2022, 11:20 AM | #761 | |
Rep 10
Yeah definitely, I can see that. Maybe this is reflective of the way one chooses to ride that limit. At the end of the day, there's no "right" way to do it (all things being fundamentally sound). Steering isn't the only way to introduce motion into the equation. Akin to what you said, what I've found to be really important is the rate at which you introduce inputs to the car. Cars turn better when you let them know what's coming next. Ya know, all of this stuff is relative.. There's only so much you can convey through words over the internet, but I do see where you're going. My point about seesawing was more directed to his comment on the wheel flying around. Like you said, seesawing is different than constantly catching the car. |
01-10-2022, 11:27 AM | #762 | |
4693
Rep 2,541
The wheel flying all over the place was a bit of an exaggeration... yes smooth is the preference but as you know at the limit quick corrections are sometimes necessary (not talking about seesawing the wheel, on/off throttle through corners - that is a whole different discussion beyond yes/no to music). Feel & visual cues are my go to's - I can react much quicker to them than any audio input. That being said - I pick & chose my music time. Obviously when racing there is no music (if only because there is no radio in my race car ) Kidding... but I do actively dampen my hearing like many others to compensate for loud racecar & also to be able to communicate with my crew on the radio. Also if the only way you can tell that you have applied too much throttle is through audible cues then yes you are certainly at a point where music should be off... And if you are in a teaching environment then absolutely no music as well (although I do not really like riding passenger on the track I will often go out with friends/customers that ask me to).
01-10-2022, 12:45 PM | #763 | |
Rep 10
Cheers! That's understandable. When it comes to audial queues, I don't think anyone solely relies on it. But it's definitely there, and a useful part of the equation for sure! It's almost like ripe fruit in my mind. Why not try and take it ya know? Listening to what the car is doing/telling you isn't necessarily a bad thing, is it? Especially when running plugs, comms, etc. I almost feel like it's intentionally blinding yourself in a sportscar like the M2 with very little feedback to give. Listening and distinguishing between unintentional/unplanned events, can not only save you, but I think is a big part of driving to the best of your ability. I like to operate under the premise that something is better than nothing. They're all just pieces to the puzzle. If you can get even 1% better, or 1% clearer information, anything at all.. Then, when you put it all together at the end, you'll have amounted to a noticeable and measurable gain. It's a point from the book Atomic Habits. But there's definitely truth to the madness. If you haven't given it a read, check it out, it's worth the experience Like I mentioned before, it's purely food for thought |
01-10-2022, 01:00 PM | #764 | |
Rep 10
01-10-2022, 01:51 PM | #765 |
Rep 2,602
Plus, I imagine there's a difference between qualifying (getting the fastest lap possible), driving for consistency and longevity (fast but make the tires last) and situational ability (correcting for oil/marbles/traffic/tire wear).
01-10-2022, 02:20 PM | #766 | ||
Rep 3,408
01-10-2022, 03:13 PM | #767 | |
Rep 10
Again, just want to reiterate, I'm not saying you always want one singular input, all the time, always. Driving is rarely ever black and white. Yes I understand and encourage drivers to be sensitive to the occurrences (testing, adapting, rinsing process you mentioned) that happen throughout the span of a corner. EDIT: My last statement applies to drivers in the category you're referring to in your replies-- seasoned drivers, top-tier level competitors in their domain type of people.. 9 times outta 10 you're slowing these guys down, because their default is always faster, deeper, later to try and make the time work for them. Last edited by M2_CircuitHero; 01-10-2022 at 03:23 PM.. |
01-10-2022, 03:55 PM | #768 | ||
Rep 3,408
My point is sure, but "fast isn't always smooth". As of result of these instructors, too many focus on smooth, smooth, smooth, and therefore are uncomfortable with the reality that going faster means getting comfortable with variables moving faster as well. Which means you have to be faster in recognizing what you're feeling and what the inputs are needed to direct the outcome. This won't necessarily be smooth or look effortless. That's it.
01-10-2022, 04:46 PM | #769 | |
Rep 10
Wow, yeah that's a good way to put it-- I'm gonna use that in the future, thank you You are correct fast isn't always smooth and HPDE instructors definitely mindlessly preach smooth is king! I think some context helps here, because it seems like we've strayed very far off the original topic I was shooting for-- we were originally talking about a guy that listens to music while driving at the limit, complaining that the steering wheel is "flying" all about. That seemed like a dangerous combination to me lol FWIW, I've found HPDE Instructors to be uncomfortable with a lot of things too. Engaging kerbs and rumbles immediately comes to mind.. I think it might be a byproduct of "experience" that breeds instructors, more than anything else. You hang around long enough, go to enough events, sooner or later you'll get approached about instructing. Instructing doesn't make you Michael Schumacher, nor does being Michael Schumacher mean you should instruct. Instructors are almost like gate keepers for people that want to begin the journey of driving. So, I see where you're coming from. |
DRLane3988.50 |
