10-11-2021, 03:48 PM | #661 | |
4693
Rep 2,542
Really like the alcantara knobs - have one with blue stitching on my OG M2 to go with along with an alcantara DTM steering wheel. They did red & blue at the time I got mine - do not think they are really doing them right now though. Stay tuned...
10-12-2021, 08:16 AM | #662 |
Rep 489
Well dang - just got some bad news for the sandlapper event coming up on the 30th
"We have a wait list for our novice/ novice intermediate students, this is not because we have filled the spots, but because we are short on Instructors. If you show up on MSR as waitlisted, we will move you once we have instructors, those of you that registered first will be assigned first." |
10-12-2021, 09:56 PM | #663 |
Rep 489
Any of y'all running brembos and 18's? Monika has a really good deal on a set and if I could figure out if they'd fit I'd consider buying em. Also, don't know if anything changed from 18 to 21 that wouldn't allow me to run these.
Brembo, Eventuri, Fabspeed, VRSF, CSF .. Lots more .. https://f87.bimmerpost.com/forums/sh....php?t=1865691 |
10-13-2021, 09:16 AM | #664 | |
Rep 489
Just need to figure out if its the same parts. It appears to be a direct fit |
hsaguirre72.00 |
10-18-2021, 12:39 PM | #665 |
Rep 155
How much rear toe are you guys running on proper tires <140tw stiff sidewall, stock shocks?
I've got caster and camber down now. 0 toe front and 0.25 (degrees) total toe in rear. |
10-18-2021, 08:34 PM | #666 |
Rep 489
Seats are in woo woo
10-19-2021, 10:41 AM | #667 |
Rep 2,523
10-21-2021, 11:13 AM | #668 |
4693
Rep 2,542
I generally like the 3.12s although I may try the 1.11s next. I love how the 3.12s almost never feel hot at my grip levels and are consistent no matter what—basically they're always better than my 220TW street tires. But I do find myself over-braking and could use a tad more finesse to properly use them.
Regarding ABS, I need to check my data, but I have read differing opinions on ABS with some saying use it to it's maximum and others saying brake right to the cusp of where ABS comes one. Ross Bentley, for example says (paraphrasing) in modern BMW/Porsche ABS systems (i.e. advanced), wait for the last moment and hit the brakes as hard/fast as you can, letting the system do the work for you. He does say that you'll likely need to adapt your driving to this style and still need to make sure you're not in ABS when beginning turn in. So I don't know—I generally use ABS in heavy braking zones and don't feel it negatively effects me. I'm concentrating more on things like managing the weight transfer, trailing in without too much brake, and a smooth release. But there's always that other argument that ideal braking is with a hint of under-rotation and maybe our systems don't allow that. M1500Z if you haven't tried the 1.11s yet - might be worth at least one set. You will not lose any performance or consistency - what you should notice is less initial bite than the 3.12s (will still have quite a bit of bite though). If you prefer the 3.12s then no harm, no foul - you won't lose any performance on the track running through a set and they cost the same. Definitely a good argument on whether or not to get into ABS. I prefer to stay out of ABS - feel like I am overall more consistent with the pedal when I'm aiming to stay below the ABS threshold. The 3.12s on anything not high grip has such a fine line that I get into ABS a little more than I prefer. But hard to argue against the other way though too - probably a lot of merit on what they are saying with today's systems. I will say in the wet though I really do not like getting into abs at all. One beni of the 1.11 is that they are a bit friendlier on the rotors. Both good pads though, really can't go wrong with either.
M1500Z423.00 |
10-22-2021, 02:41 PM | #669 | |
Rep 340
All of this reminds that I should set up a math channel in RaceStudio to try and get an accurate representation of brake pedal pressure. |
10-22-2021, 03:50 PM | #670 |
Rep 155
I changed back to my street setup, which are some crappy apracing apf404 pads front and ds2500 rear on my apracing kit and I can actually modulate the pedal and trail brake now.
This might have shifted some bias to the rear as well, haven't calculated it. Now I can brake immediately off the throttle without putting 1.5Gs instantly on the front of my car. I didn't like how the ds3.12 feel at all. Running AR1s. Going to switch to Pagid or PFC for track pads next. |
10-23-2021, 09:55 AM | #673 |
Rep 489
Anyone have a problem with brake modulation with the 2NH brakes and ferodo ds1.11 pads? When my instructor asks me to brush the brakes I'm getting some pretty significant bite. Maybe it's something I need to get used to but I didn't have this problem in my c7 vette.
10-23-2021, 11:25 AM | #674 | |
Rep 500
One thing you may find necessary is to tap the brakes to set the pads (to take care of "pad knock-back") before going into a braking zone. This will give you a more consistent pedal height when applying the brakes. Have fun out there! |
Anonymoose540.50 |
10-25-2021, 11:52 AM | #675 |
Rep 489
Just got my laptimer installed today. I had a pretty clean run except when I got to the b pillar. I didn't see anyway to not run it across the dash or without drilling a hole. I did consider what it would take to run the cord through the vent but didn't like that idea due to heat.
10-25-2021, 12:17 PM | #676 | |
4693
Rep 2,542
10-25-2021, 05:57 PM | #677 | |
Rep 485
Car has a low 1:40 in it easy. I just need to go to Seca a few more times. It's a very high risk track. 4 Mclarens totaled and towed out!!! |
10-25-2021, 06:14 PM | #678 | ||
Rep 2,526
It's a bit tricky to do if you can't get in your back seat, but it's doable. There may be a way to set it with the mobile app as well. |
10-25-2021, 06:23 PM | #679 | |
Rep 2,526
However, I'm guessing you're using the OBD connector instead of direct to canbus, so that option is probably less ideal. |
10-25-2021, 08:26 PM | #680 | |||
Rep 489
detroitm22428.50 |
10-25-2021, 10:05 PM | #681 | ||||
Rep 2,526
10-25-2021, 11:38 PM | #682 | |||||
Rep 3,408
