09-21-2021, 07:00 PM | #617 | |
2427
Rep 11,667
To the best of my knowledge ODB2 is data comms only, not power. |
09-22-2021, 02:08 AM | #619 | |
Rep 744
For the Solo, if you want some ECU data you need to get it from the canbus as the OBD has some kind of lock on it. Search for the Aaron gauge instal or solo install and it should tell you how. If not PM me and I can explain it.
09-22-2021, 08:53 AM | #620 |
Rep 488
My m2 should be coming home tomorrow. The finishing touches are going on
In total I'll have Castrol SRF brake fluid Apex EC-7 ET45 19x10.5 Satin Black x 2 Wheels 295/35/19 Michelin P4S Apex EC-7 ET28 19x9.5 Satin Black x 2 Wheels 265/35/19 Michelin P4S Ferodo DS1.11 front and rear brake pads APEX 75mm M14 BMW 5 Lug Hex Head Stud Kit APEX 5mm BMW Spacer Kit Ohlins road and track suspension 3DM RoadSport spring set using Swift springs: Front: 70 N/mm - Rear 160 N/mm Vorshlag Adjustable Camber plates Corner balanced car Stainless line kit - Front..(13.02.06500) Stainless line kit - Rear..(13.02.06600) CMS Performance Bolt-In Roll Bar for BMW F87 CMS Rear seat delete Schroth Profi II ASM FE Street Legal 4 Point Harness x 2 BMS clutch stop Rennline Heal/Toe pedal |
4
09-22-2021, 05:10 PM | #622 | |
Rep 488
SOOOOOOOOOOOOOOO it doesnt matter if they are able to mount it to the seat or not. I will be ordering race seats and upgrading my 4 point to a 5 or 6 point |
09-23-2021, 04:43 AM | #624 | |
Rep 155
Ordered some nitron r3 now and I think they have caster adjustment from the plate though, not sure. |
09-28-2021, 07:47 AM | #625 |
Rep 488
I'm looking at picking up some race seats since I can't run the 4 point I have with factory seats. I think I've settled on the Sparco Evo XL unless someone says they're junk.
I'm also looking at the easiest way to install them so I'm looking at turn key seat mounts like this? https://machtschnell.com/macht-schne...eat-mount.html Thoughts? |
09-28-2021, 08:17 AM | #626 | |
Rep 155
09-28-2021, 09:56 AM | #627 | |
2427
Rep 11,667
I've used their products before and was leaning that way again. |
09-28-2021, 10:09 AM | #628 |
Rep 488
I don't. Just that my shop said there was some modifications that needed to be made to align properly. I think that was more on the seat delete than anything else. It's nothing that would stop me from getting it. If you drive this to and from events the square bar in the rear and the ability to see out the back window unobstructed is worth whatever additional install time would be.
09-28-2021, 10:23 AM | #629 | |
Rep 340
09-28-2021, 10:32 AM | #630 | |
Rep 488
https://www.bkauto.com/R_9292_Bottom...X_p/r-9292.htm ? |
09-28-2021, 12:45 PM | #631 | |
Rep 340
09-28-2021, 01:00 PM | #632 | |
Rep 488
I just found that the m2c has trouble fitting a sparco evo xl so I'll probably have to go with a OMP HTE-R XL |
M1500Z423.00 |
09-29-2021, 10:52 PM | #633 |
Rep 340
Has anyone thought about running the new Continental ExtremeContact Force—the new 200TW tire that was developed with Hoosier after their acquisition? I'm very curious about this tire from a track-day perspective and there seems to be a dearth of reviews.
09-30-2021, 02:26 PM | #634 | |
4693
Rep 2,541
Definitely let us know how you like them if you try them - on a dry track they definitely look intriguing.
09-30-2021, 08:01 PM | #635 | ||
Rep 3,539
I'm interested in them as something that can withstand a lot more heat cycles than the A052s do.
09-30-2021, 08:14 PM | #636 | |
2427
Rep 11,667
Definitely easy on the wallet if not chasing lowest lap times. How much quicker do the A052s heat cycle out than the RS4s? I was considering them once I get off these big OE brakes and onto some 18" track wheels. |
09-30-2021, 10:27 PM | #637 | |
Rep 3,539
FWIW, the RS4s lasted me 14 track days on my F31 (even heavier car), before I tossed them. A052s on the same car once again were fast for two track days, and noticeably started to fall off on the third. The A052s don't have that great of a heat tolerance.
inTgr8r2426.50 |
10-01-2021, 11:03 AM | #638 |
Rep 5,728
Drives: 2019 M2 Competition
I'll be at Auto Club Speedway on Sunday if anyone else is going lemme know.
