M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Best engine oils
      05-21-2020, 09:29 PM   #111
F87source
F87source's Avatar
Drives: Bmw M2
Originally Posted by tazam2 View Post
I hit 200-250 F much quicker in comfort than with the previous oil.
Then in sport and sports+ it’ll usually run cooler than 250.
From what I understand 200-250 F is optimal temp for the OGM2...correct?
Interesting, in comfort mode cooling is reduced, still not sure why you're heating up faster than other oils.
Yes around that temp range is ok for the n55. 270°F is when power is being cut in a silent limp mode.
      05-29-2020, 04:41 PM   #112
ZM2
Drives: 2017 LBB M2
Just wanted to chime in on this thread for those that didn't note this in my N55 Extreme Engine Cooling thread in the Engine section of the forum.
When I started running Motul 300V (5W-40 for the street, 10W-40 for hot summer track days), I noticed my oil temps running 15-20F cooler in similar driving modes and circumstances vs OEM oil.
I also didn't have to add any oil between changes. This was happening with the OEM oil as soon as I started running an E30 mix & tune, while the 300V held up great.
The stuff isn't cheap and it's not a long life oil, so you're supposed to change every 3-5K miles, but it works damn good for the track and has way better high temp protection.
KevM2721.50
M2RAW121.00
      09-16-2021, 03:18 PM   #113
M2RAW
M2RAW's Avatar
121
Drives: BMW F87 M2 BASE
You think motul 300v(5w-40) would be good for daily? I only gonna track my n55 m2 for like 1-3 every year.. Is 5w-40 fine for track?
      09-16-2021, 06:33 PM   #114
ZM2
Drives: 2017 LBB M2
Motul 300V 5W-40 is probably one of the best oils in the world. It's as thin as the 0W oil spec'ed for our cars so cold start is no issue, but it's base stock and blend is much better on the top end for hot track use. Super high HTHS.
The caveat is it's not an LL oil, so you should change it every 3-5k miles. That's fine for me b/c I don't drive my car much, but if you commute in yours that'll become a pricey oil to use.
The other caveat is I'm now running an E50 mix and the 300V 5W-40 was a little too thin for that high of Emix and I started to have to add a quart between changes. With 300V 10W-40 that's not an issue, and while that sounds thick, 300V 10W-40 is thinner than most 5W-40s that guys are putting in their M2/M2C's.
I will say it's pretty noticeable how freer rev'ing the engine is and the oil temp impact with 300V. Great stuff!
M2RAW121.00
      09-17-2021, 10:52 PM   #115
M2RAW
M2RAW's Avatar
121
The caveat is it's not an LL oil, so you should change it every 3-5k miles. That's fine for me b/c I don't drive my car much, but if you commute in yours that'll become a pricy oil to use.
How about MOTUL 8100 X-CESS 5W-40? It's LL-01 and for warranty purposes.Should be good for daily and track right? Im planning on changing oil every 5k miles.
      09-17-2021, 10:56 PM   #116
ZM2
Drives: 2017 LBB M2
I’m the wrong guy to ask. edycol F87source
      09-17-2021, 11:43 PM   #117
F87source
F87source's Avatar
Drives: Bmw M2
That's what I'd use along with PPE 5w40.
300v is way too expensive and overkill just for 1-3 track days a year.
Motul xcess gen 2 5w40 should be more than sufficient for 1-3 track days a year. It has a pretty high hths at 3.8, solid additive package, and Porsche a40 certification which edy has told me is the crazy nurburgring endurance test to see if there oil oil break down. So yes it should be absolutely fine for those occasionally track days, and since it has a decent additive pack it can also go for longer intervals between oil changes.
If you track alot more like zm2 does then yeah you should go with an even more stout oil like 300v.
M2RAW121.00
      09-17-2021, 11:44 PM   #118
M2RAW
M2RAW's Avatar
121
Thank you guys!
      09-18-2021, 05:06 PM   #119
edycol
Drives: 2011 328i xDrive
^This!
300V is OK, but has to be used on the track more so than not. Additives in 300V are designed to work beat at very high temperature for prolonged period of time. It is basically racing oil which means there will be oxidation too.
X-Cess is compromise, but so is M2. It is nit racing car, it is super fun, super capable street car that comes with all those "goodies" like catalytic converters etc. That means one is limited to oil that can work with all that emissions equipment etc. 300V is designed to work in street cars unlike oils like Mobil1 0W30/50 Racing, Valvoline VR1 etc. that have huge amount of ZDDP that actually it is dangerous for emissions equipment.
Another really, really good oil for dual street/track use is Mobil1 0W40FS. It has all stuff engine needs on track. High amount of ZDDP, state of the art base stocks. It has HTHS of 3.6, but that is ok. Problem in N/S55 is very high amount of additives and sulfated ash and phosphorus. Now, BMW has probably best PCV system in industry and carbon build up should not be an issue, but this oil is not particularly friendly to direct injection engines. Also, if M2 is under warranty, M1 won't do it. Manufacturers like MB and Porsche thinks that is ok, but amount of SAPS in that oil is just ridiculous. However, that makes also that oil best cleaning oil by far.
F87source7226.50
M2RAW121.00
      09-19-2021, 03:19 PM   #120
M2RAW
M2RAW's Avatar
121
How about oil filter? Oem should be just fine?
      09-19-2021, 03:55 PM   #121
edycol
OE, MANN, Mahle or Hengst.
M2RAW121.00
F87source7226.50
      09-19-2021, 04:07 PM   #122
F87source
F87source's Avatar
Drives: Bmw M2
I personally use the OEM Mann hu8011z, this is the same part number they use in the m2 and s55 powered cars minus the m logo.
I'm sure the hu 816x is fine too but the 8011z pn was only a couple cents more so why not to satisfy my ocd.
M2RAW121.00
edycol1501.50
      09-19-2021, 05:34 PM   #123
PackPride85
Mann 8011z comes with the drain bolt crush washer as well which is a big plus. Found that out after I ordered a bag of 10 already lol.
M2RAW121.00
      09-20-2021, 09:57 AM   #124
blitzyo
Drives: 19' M2C
Anyone using Rowe synt rsi 5w-40?
It's priced well where I live.
      09-20-2021, 10:28 AM   #125
edycol
[IMG]
View post on imgur.com
[/IMG]
Budget option, doesn't look that good.
Pour point of -36 indicates strictly Group III. MUCH, MUCH better oils out there.
blitzyo53.00
      04-15-2022, 01:21 AM   #126
terrywang
terrywang's Avatar
94
Drives: OG F87 M2
2016 BMW M2  [0.00]
Originally Posted by Tiss'er View Post
My manual for the 2018 LCI only states 0w-30 as the approved viscosity. For this reason I have ordered German Castrol 0w-30. I am questioning this being in AZ though as maybe I should try LiquiMoly 5w-40
Interesting, AUDM (2016 Oct) doesn't have any specific viscosity, instead it tells owners to contact relevant service partner... BS...
2016 F87 M2 DCT LBB
      04-15-2022, 07:51 AM   #127
edycol
Viscosity is irrelevant, approval's are what matter.
When it comes to protection, AGAIN, viscosity is irrelevant,HTHS is what matters.
He ordered Castrol 0W30, but that is not oil BMW had in mind when they put 0W30 as BMW TPT 0W30 is FE oil with HTHS around 3. Castrol Edge is so called heavy W30 oil with HTHS above 3.5 and possibly very close to LM 5W40. Reason for such high HTHS is really good base stocks Castrol uses in their 0W30.
F87source7226.50
      05-14-2022, 10:39 AM   #128
edycol
Guys,
New Castrol Edge 0W40 is out.
According to Castrol it is LL01. But there is dramatic increase in pour point from -60 to -45. That means significantly less PAO.
Not sure how HTHS looks now, but based on pour point it doesn't seem as stout as before.
F87source7226.50
      05-14-2022, 06:09 PM   #129
F87source
F87source's Avatar
Drives: Bmw M2
Originally Posted by edycol View Post
Guys,
Nice! Hope it comes in 5L jugs so it's cheaper to buy.
Do you have any links I couldn't find any.
      05-14-2022, 06:59 PM   #130
edycol
Guys,
It is on general Castrol web site. API SP now.
F87source7226.50
      05-14-2022, 08:22 PM   #131
F87source
F87source's Avatar
Drives: Bmw M2
For some reason I still don't see it, could you link me to it?
      05-15-2022, 10:25 AM   #132
edycol
https://msdspds.castrol.com/bpglis/F...5882F0048BFEF/$File/wepp-cdtt2a.pdf
Copy past it. For some reason it is broken when I paste it.
F87source7226.50
