04-02-2020, 12:01 AM | #23 |
Rep 1,484
i thought the bottleneck to our cars was the turbo inlet size not the intake size?
Current Ride=2008 BMW 335xi
2017 BMW M240 Xdrive 2017 BMW M2 N55 6spd 2018 Infiniti Q60 Redsport AWD 2008 BMW 335ix |
04-02-2020, 08:17 AM | #24 |
Rep 699
JTO245276.00 nothingman522.00 |
04-03-2020, 12:27 PM | #25 | |
Rep 660
I figured with all this time on my hands I might as well make my car sound and look bit different I will be installing a turbo inlet pipe in the future as well, so it's worthwhile to me to remove any restrictions anyways. |
04-04-2020, 01:44 PM | #26 | ||
Rep 1,484
04-04-2020, 03:39 PM | #27 |
Rep 660
04-06-2020, 02:53 PM | #28 |
Rep 4
Hey guys,
I have the Turner Carbon Intake as well, i ordered it black friday and it took almost 3 full months to arrive.. I called a bunch of times and they kept telling me I was at the beginning of the list to be sent out so that was frustrating.... But now that I have had it installed for 2 months now, I can confirm there is a bottle cap sound and it's SO LOUD.. At first, I wasn't sure if this was normal and at the time there were no posts about it so I called.. AGAIN.. and they said they had it on their shop car and didn't have that issue and no one had complained about it, so I'm glad to hear it's a common thing. For a cheaper price i could have bought the Dinan, but I didn't want to cut the brace and the open filter looked cool. But for a daily driving car, this whistling sound is not for me... I can hear it consistently even with cruise control on, over my music sometimes since it's so high pitched. Thinking about selling it and going Dinan. |
JTO245276.00 |
04-06-2020, 03:38 PM | #29 | |
Rep 309
04-06-2020, 05:38 PM | #30 | |
Rep 1,484
JTO245276.00 |
04-07-2020, 12:37 PM | #31 |
never could compete with Lloyd Braun
5276
Rep 5,380
Yea I'm living with the bottle top noise for now as I've gotten used to it but we'll see how I feel when I'm driving back and forth to work again every day (WFH at the moment)
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
04-07-2020, 06:24 PM | #32 | |
Rep 4
I wonder where the noise is coming from.. I didn’t have this noise on my n55 335i e92 with bms intake and my brother’s 435i also had the bms intake. Must be something M2 related. Anyone have any ideas? |
04-08-2020, 07:48 AM | #33 | |
5276
Rep 5,380
04-08-2020, 06:21 PM | #34 | ||
Rep 1,484
04-09-2020, 12:36 AM | #35 |
Rep 660
Just installed it today. I had an extremely hard time getting the intake pipe to fit in to the OEM pipe (with the clamp) since the angle the pipe went in was very constrained, as you had to put the filter-end of the pipe through the hole where the filter is first. After I applied a very light coat of silicone grease to the clamp area, it finally popped in.
Additionally, the vacuum hose adapter seems much closer to the engine than the OEM adapter is, thus placing a large amount of stress on the adapter due to the extremely stiff vacuum pipe. A few minutes after I installed the vacuum pipe, the vacuum adapter broke right off with a big cracking sound Luckily, it just seemed that the bond between the adapter and the carbon fiber was not sufficient, as there was extremely little epoxy/glue in that area. I sanded it down and applied a ton of JB weld, let it cure for 24 hours and put it back on, this time it did not break. I also put some aluminum foil between the vacuum T-pipe section and another plastic section to push the vacuum hose further back into the engine bay, thus relieving some of the stress on the vacuum adapter. Hopefully it won't crack this time, and I'll think of a more permanent solution later. Regarding the whistling sound, I only hear it when I'm at partial to high load around 1700-2100 RPMs, otherwise I do not hear it at all. When my music is on, I don't hear whistle at any RPM. Overall, it looks great, but it was definitely not very plug and play for me. I detailed my install (or rather, my struggle) here: View post on imgur.com Last edited by eeyang92; 04-09-2020 at 12:42 AM.. |
4
04-15-2020, 06:01 PM | #36 |
Rep 386
Just installed mine too and loving the sound and look! I can concur with others that there is a "blowing over an empty 2Litre soda bottle" noise at 50% load at around 2k RPM (I had the aFe open intake on my M235i years ago and made no such noise). It doesn't bother me enough (had to live with exhaust drone last two years from my other car so this isn't so bad) and music usually masks it anyways.
Install was easy, and fits just right and tight. The vacuum line did take some adjusting to get it to fit right on the intake without putting any stress on it. Happy with product. |
eeyang92318.50 |
04-16-2020, 04:28 AM | #37 |
Rep 660
Does anyone know the cleaning procedure for these filters? Or rather, what filter comes with the intake? Unfortunately I'm not at my car to check the logo on the filter itself.
The closest visual match I've found online is the aFe filter: https://afepower.com/afe-power-24-40...-5r-air-filter (also listed on turner's store: https://www.turnermotorsport.com/p-340581-tms340581/) That would mean this would be the correct kit: https://www.turnermotorsport.com/p-1...oiled-filters/ EDIT: Got confirmation from turner that is indeed the correct kit. Last edited by eeyang92; 04-16-2020 at 05:02 PM.. |
StarMan351.50 |
04-16-2020, 09:02 AM | #38 |
Rep 4
Hmmm, I wonder what you guys are doing differently that you aren't hearing the sound as much as i am. on the lightest of throttle i hear it, at any RPM. I accelerate lightly and shift at 1.8k. Maybe i'll take it apart and mess around with my install. I know that when I installed it, i put my hand inside the carbon tube and cut my hand up with all the sharp edge inside. I originally had thought that could cause the whistling.
04-16-2020, 09:11 AM | #39 |
Rep 4
My wife drives our M2 with this intake about 60 miles a day to work and back, she loves the sound. We also have the Dinan resonator delete, which was way more of a PITA to install than this intake was. We love it and had zero issues.
The noise is not bad at all, I’ve heard intakes that were way louder. I have an integrated engineering carbon intake on my S3 and am quite disappointed with how quiet it is. I think we would have been highly disappointed with the dinan intake as I feel it would have been too quiet |
04-16-2020, 05:11 PM | #40 | |
Rep 660
My thinking is it's either the vacuum attachment point being right off the main tube (kind of like blowing across the top of a bottle), or as you said, imperfections on the inside causing some sound. If you do fiddle around with it, let us know While I don't spend much time at 2k RPM, it would be nice if it was 100% gone. |
04-16-2020, 10:27 PM | #41 | |
Rep 309
04-17-2020, 06:01 AM | #42 | |
Rep 386
Did you ask\or know if the aFe filter is the correct replacement? |
04-17-2020, 11:58 AM | #43 | |
Rep 660
I will look at the logo on my filter to confirm it is indeed the aFe filter, but I think it's pretty safe to say it is. |
04-17-2020, 12:59 PM | #44 | |
Rep 386
Part#: 024146TMS01 Site: https://www.turnermotorsport.com/p-3...intake-filter/ |
eeyang92318.50 |
