BMW M2 Forum > BMW M2 CS Model > M2 CS Price for the US: $83,600 (plus $995 Destination)
      11-30-2019, 11:44 AM   #485
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
Kind of disappointed that the CS didn't shed any weight but in the grand scheme of things, once an automobile crosses 3,500lbs or so, does a few pounds here and there really matter that much..
Let's get one on an open road or track and seen how it collectively performs and if it's anything like the M4 CS, it will be in good company.
At the end of day, that's all that really matters anyways, not some number on a data sheet.
      11-30-2019, 05:52 PM   #486
drgmt
985
Drives: M4
"Developed on the ring" is absolutely laughable.
Developed in a board room at BMW to maximise profit.
      11-30-2019, 08:27 PM   #487
MinionM3
MinionM3's Avatar
Drives: 2012 E92 M3 // 2020 M2CS
All these posts from the autoshow and nobody noticed the imperfection in the roof weave!?!?! If this was my car from factory I'd be furious!
Hope the production models don't have this....
Instagram: @MinionM3
Current Garage:
2012 M3 ZCP, Mineral White, DCT: Track Build
2020 M2CS, Misano Blue, 6MT
Appreciate 4
chris7197363.50
Jarran10.50
dmboone254972.00
BigHunk269.50
      11-30-2019, 08:41 PM   #488
Supadice
Supadice's Avatar
1029
Drives: 2020 M2CS
Damn how long did it take u to find that?
Vic
chris7197363.50
      11-30-2019, 08:43 PM   #489
MinionM3
MinionM3's Avatar
I wasn't looking - it's directly above the passenger door - I was pointing out the roof weave difference to someone and BAM it's blatantly obvious
Current Garage:
      11-30-2019, 08:44 PM   #490
Supadice
Supadice's Avatar
1029
Drives: 2020 M2CS
I mean it's not that obvious. You are the only one to find it.
Vic
      11-30-2019, 08:45 PM   #491
Supadice
Supadice's Avatar
1029
Drives: 2020 M2CS
Now I know what to look for if I get one. Thank you.
Vic
      11-30-2019, 09:27 PM   #492
chris719
Drives: '08 M Roadster
I have to say, the 1x1 weave looks pretty bad too. I do understand all BMW roofs are 1x1 and it's probably not that noticeable in real life because it's the roof, but it would be nice if it matched all the other parts.
      11-30-2019, 09:46 PM   #493
MinionM3
MinionM3's Avatar
I don't think you looked at the pic - the weave is all wonky in that one spot
Current Garage:
      11-30-2019, 10:12 PM   #494
Supadice
Supadice's Avatar
1029
Drives: 2020 M2CS
They prob went for a "Checkered" flag concept. I prefer it match the rest also but It's not terrible in my opinion. I'm sure the production models will not have imperfections and they will go through quality control like any other car.
Vic
      11-30-2019, 10:14 PM   #495
Supadice
Supadice's Avatar
1029
Drives: 2020 M2CS
Originally Posted by Artemis View Post
Originally Posted by AlpsRider View Post
Let's not forget that the 763M wheels weigh approximately 17 lbs less than the 788M wheels from the M2C. That is an easy way to save some weight.
Furthermore, remember that in Europe the 2NH "M Sport Brake" are optional. Standard brakes on base M2 and M2C = ± 16 kg / ± 35 lbs less weight:
Originally Posted by hellrotm View Post
The 2NH "M Sport Brake" and the M Performance Parts "BMW M Compound Brake Discs of the BMW M Sports Brake System Red" are identical, except for the caliper color (silver for the 2NH and red for the MPP) (see Q&A here). The brake kit can be retrofitted on M2, M2 LCI and M2 Competition.
M2 Competition 2NH brakes feature the F8x carbon ceramic brake’s calipers (F&R) with 400mm/380mm steel rotors. And the F10 M5 standard brake’s front calipers are the same as F8x CCB front calipers.
Standard M2/M2C brakes (blue) (source: see here):
  • blue front caliper - 4.890 kg or 10.78 lbs
  • blue rear Caliper - 3.600 kg or 7.94 lbs
  • 380x30mm front rotor - 11.300 kg or 24.91 lbs
  • 370x24mm rear rotor - 9.300 kg or 20.50 lbs
    = 58.180 kg or 128.26 lbs
2NH M Sport Brakes (silver) - M Performance Parts Brakes (red):
  • silver/red front caliper - 7.540 kg or 16.62 lbs
  • silver/red rear Caliper - 4.310 kg or 9.50 lbs
  • 400x36mm front rotor - 13.870 kg or 30.58
  • 380x30mm rear rotor - 11.300 kg or 24.91
    = 74.040 kg or 163.23 lbs
Extra weight of the optimized silver/red brakes compared to the standard blue M2/M2C brakes = 15.86 kg or 34.97 lbs
In a recent BMWBlog podcast, BMW M CEO Markus Flasch said: "Bottom-line, the car is pretty much the same weight [...] The reason for the car being the same weight [as] the [M2] Competition is the additional stuff that we've put in." (listen here - it's told in the first part of the podcast + see here).
What are these additional things that make up the weight saved for the light weight parts of the car?
Vic
      12-01-2019, 02:35 AM   #496
chris719
No, I definitely saw it, I was just commenting that the weave doesn't match the other parts on the car even when it's not defective.
      12-01-2019, 02:37 AM   #497
chris719
The only known parts are the adaptive dampers. I can't see how it weighs the same unless the measurement changed in terms of standard equipment. He may just be generalizing, because +/-100 lbs sprung weight is not a lot.
      12-01-2019, 02:53 AM   #498
Artemis
Artemis's Avatar
29655
Drives: BMW M2 Competition
Enjoy: https://www.boredpanda.com/irritatin...d-imperfection
Choices, choices...
///M is art Artemis
MinionM3493.50
      12-01-2019, 02:57 AM   #499
mbanck
Drives: BMW E46 320ci, BMW F34 330dx
Not sure about the new seats, but certainly the HK stereo being standard now is also adding to the weight, as well as possibly some other comfort features.
      12-01-2019, 11:34 AM   #500
bigjae1976
bigjae1976's Avatar
1579
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
A particular weave is used for strength/structural righty optimization, not aesthetics.
Generally, a 2x2 weave is used in part build up (middle layers). A 2x2 weave has slightly higher resin consumption which equals more weight.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      12-01-2019, 11:38 AM   #501
bigjae1976
bigjae1976's Avatar
1579
2004 BMW M3  [4.50]
I find the CS models interesting.
I view the E46 M3 CSL as the car that these CS cars are based on. That car had no AC standard which would be intolerable to most M3 drivers.
Not sure why BMW doesn't go all out and make a CF monocoque and then up the price. That car would be special, cool, and legitimately lighter.
Shaving off a couple of lbs here and there on a street car is a mostly pointless exercise that just makes some numbers sound better.
      12-02-2019, 10:55 AM   #502
///M2NYC15
Drives: M2 LBB LCI
I was reading up on this article from BMW blog which I found interesting. They Weighed the car at 1,532 KG which translates to 3,377 lbs this includes CCB. Here is the link.
https://www.bmwblog.com/2019/11/09/b...ts-and-r8-v10/
      12-02-2019, 12:55 PM   #503
stylinexpat
stylinexpat's Avatar
415
Drives:
I saw that car at the LA Auto show. Beautiful car and great seating position. I hope they ironed out the bounces though from the suspension with this new CS
      12-02-2019, 04:51 PM   #504
izzyM2
izzyM2's Avatar
735
Drives: 24’M2/21ID.4/21’MacanGTS
Originally Posted by elitt13 View Post
I used my allocation too and ordered the Hockenheim Silver with Black Rims M2 CS with M Drivelogic.
What does this mean. Like dealer just give you an allocation just like that?
      12-02-2019, 05:07 PM   #505
M3 Adjuster
Albania
7909
" What we do know is that it featured the six-speed manual transmission and the Michelin Pilot Sport Cup 2 tires. And the recorded times are quite interesting. Let’s start with the BMW M2 CS time as published by Auto Bild – 1:34.98 – which is just a bit over half a second faster than the M2 Competition on the same track.
M2 - 1:37:65 12/2016 - Audi TTRS vs BMW M2
M2C - 1:37.56 11/2018 -
M4 - 1:37:22
M4 C - 1:36.13
M2C - 1:35.67 ????
M2 CS - 1:34:98 12/2019
M4 CS - 1:34.01
M4 GTS -1:33:17
25K for 0.7 seconds...
I found three tests... I did not find the test indicating the M2 C was just 0.7 back.... perhaps another comparo or a super test?
Sedan_Clan25186.00
      12-02-2019, 05:11 PM   #506
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25186
Drives: '22 Chalk Gray Porsche C2S
25K for 0.5 seconds...
Ouch!!!!
