M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Racing Brake Fluid in Winter
      02-22-2020, 08:05 AM   #1
Anthony1s
756
Drives: 2018 Mineral Grey M2
I'm going to be doing autocross and at least two track days this season and am considering swapping the brake fluid for a hi-temp fluid. I drive my M2 year round, where we can see 0F temps or lower sometimes. Would I have to swap the brake fluid back out before winter?
ZM22810.50
      02-22-2020, 08:20 AM   #2
ZM2
Drives: 2017 LBB M2
No issues, I run SRF year round.
Generally I change it right before my first track event so it’s fresh, and that lasts me a track season and then I keep using the same fluid thru the winter.
If I’m doing a lot of events in a year, I’ll change it again mid-season. Other than that, some clubs want to see that you’ve changed it in the last 180-days as part of their tech inspection.
Anthony1s755.50
      02-22-2020, 11:58 AM   #3
Bee Pee
Bee Pee's Avatar
1774
Drives: AW M2 DCT
Generally I change it right before my first track event so it's fresh, and that lasts me a track season and then I keep using the same fluid thru the winter.
If I'm doing a lot of events in a year, I'll change it again mid-season. Other than that, some clubs want to see that you've changed it in the last 180-days as part of their tech inspection.
Ditto - I use SRF too all year round - no issues
Current '22 X3M LCI..
ZM22810.50
      02-22-2020, 12:36 PM   #4
ZM2
Drives: 2017 LBB M2
Yeah, I even declined BMW’s free brake fluid change before this past winter.
I figured used SRF was better than new OEM fluid.
      02-22-2020, 03:17 PM   #5
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
And it is! SRF here year round as well.
2017 BMW M2 German Spec
6MT, Driver's Package
--> SOLD
2018 Camaro SS 1LE. Because race car!
"Redline a day keeps the mechanics away"
ZM22810.50
      02-23-2020, 01:46 PM   #6
///Monika
Drives: '18 X3 M40i & '18 M2
Here as well ..
ZM22810.50
      02-23-2020, 01:55 PM   #7
Drop the hammer
Drives: '17 F87 M2 AW, Dct
Im in Canada and I run motul 660 year round, no issues.
ZM22810.50
      02-23-2020, 06:22 PM   #8
243Racing
1448
ATE brake fluid here, all winter no issues so far. It’s been in the single digits several times.
ZM22810.50
Bee Pee1774.00
      02-26-2020, 02:04 AM   #9
Anthony1s
756
Is there any special procedure or software needed to swap the fluid or can my regular mechanic do it?
Also how much fluid do I need?
      02-26-2020, 06:26 AM   #10
ZM2
Drives: 2017 LBB M2
I used to do it at home, but I always needed more fluid than my mechanic to do the bleed.
Plus, you’re supposed to cycle the ABS unit. I wasn’t real clear on how to do that—probably easy tho?
      02-26-2020, 08:43 AM   #11
Anthony1s
756
Not sure. TIS doesn't say anything about cycling the ABS.
https://www.newtis.info/tisv2/a/en/f...ion/1VnXDR6doh
I'm gonna email my dealership. I wonder if the service computer has to be reset after the fluid change too.
243Racing1447.50
      02-26-2020, 09:49 PM   #12
2020M2Competition
2020M2Competition's Avatar
429
Drives: Yes
There is a special procedure
https://www.newtis.info/tisv2/a/en/f...ation/GfgD7vNY
However, it is rarely done
I've confirmed this with both independent and BMW technicians
In theory, if you want to replace all of the old fluid it should be done
Whether or not it is really necessary is a matter of debate
You will also want to consider changing and bleeding the clutch fluid as it shares the same reservoir as the brakes
      02-27-2020, 09:56 AM   #13
Anthony1s
756
Am I missing something? That procedure looks exactly the same as the one I posted.
      02-27-2020, 01:55 PM   #14
2020M2Competition
429
Drives: Yes
The page in the link you posted shows the basic procedure
That page does have a direct link to the more advanced procedure, but since you mentioned not noticing anything about cycling the system I wasn't sure if you had seen it
