02-19-2020, 08:00 PM | #23 |
2006 TIME Person Of The Year
9720
Rep 6,445
Sweet ride.
Surely you code the airbags back on when you use her on the street. Riiight?
02-19-2020, 08:21 PM | #24 |
Rep 88
02-19-2020, 08:24 PM | #25 |
Rep 1,239
That's how you properly mod
a car. 👍. Perfect pairing of the GS1R and the Essex AP BBK. I also think you should put your thread here. https://f80.bimmerpost.com/forums/sh....php?t=1682520
2016 Hellrot F80 M3|JRZ RS Pro with Swift Springs 550/750 spring rates l AP Radical 5000R 9668/9449 lSpiegler SS LinesI DS1.11I Eisenmann DP|MPE Catback|18" Forgeline GS1R 18x10 et 22 and 18x11 et 44 NT01 275/35/18 and 305/35/18| Forgeline GTD1 18x10et43 SquarelM Performance Lip/Splitter|IND aesthetic mods|Dinan Toe Link|Fall Line mono ball conversion kit and upper link kit| Aim Solo 2DL Smarty Cam|Simpson Hybrid|Stilo Offshore helmet.
02-19-2020, 08:34 PM | #26 |
///M
6654
Rep 3,683
Life is too short...enjoy your life
///M |
Imperial328i277.00 |
02-19-2020, 09:49 PM | #28 |
Fitness Gene
1113
Rep 2,413
Drives: 2018 M4
Garage List 2006 bmw m5 [10.00]
2016 bmw z4 35is [8.33] 2000 bmw m5 [10.00] 2018 BMW M4 [10.00] 1987 BMW 325 Conver ... [10.00] |
Nice and subtle
Post some track times!
Effective 11 Min Home Workouts????? No equipment????? 20 years of experience Spartan Race winner PROtrainer! Click the link?? https://www.youtube.com/c/FitnessGene |
02-19-2020, 10:59 PM | #29 | |
Rep 1,263
https://f80.bimmerpost.com/forums/sh...light=euro+mdm He programmed a few things for me including: GTS EPS (Electronic Power Steering) *Stiffens steering for better control/handling with more advance power assist. GTS Traction Control *Givens more slip in MDM and allows better traction control settings (you can select this or euro MDM not both) GTS Differential *Allows for better take off from the line and better control on turns. He charged $100 and did it remotely.. Great guy and work!
02-20-2020, 06:22 AM | #31 |
Rep 737
How did you mount your inside lap belts for the 6 point and 3 point? Can you put up a photo?
harmonster23.50 |
02-20-2020, 08:47 AM | #32 |
Rep 6,759
Very cool...
And speaking of cool, is there a specific reason you upgraded the cooling on the car? It’s the one aspect I’ve never had an issue with, no matter the ambient temp.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
02-20-2020, 09:07 AM | #33 |
Rep 247
larry.beck217.00 |
02-20-2020, 09:09 AM | #34 | |
Rep 247
Someone asked about the airbags - only the seat airbags (and associated warnings) are turned off. The front airbags are still on for street use. |
02-20-2020, 09:11 AM | #35 | |
Rep 247
I'm a big fan of overbuilding everything. I always start with the prep work before the performance work. |
02-20-2020, 09:14 AM | #36 | |
Rep 247
I used floor mount adapters from VAC Motorsports (https://store.vacmotorsports.com/rac...-m2-p4788.aspx) along with their belt mount kit for both the lap belts and the sub belts. On the inside bracket, the factory plug is attached. Honestly though, it's not the best setup for the factory belt as I can't fit the plug on the inside of the seat. This car doesn't really get driven much on the street, though, so I'm not overly concerned. I might pull the factory belts at some point and just use the 6-points only. Edit: actually, I have a pic on my computer at work. You can kinda tell from the pic how the mounts work. Last edited by QuickOne; 02-20-2020 at 09:18 AM.. Reason: Added pic |
02-20-2020, 09:22 AM | #37 | |
Rep 737
According to a NASA (the space people), an 8mm bolt with 1/2” depth in 6061 aluminum has a pull out force of 4000lbs. Per my calculations, that’s good enough for a 70G crash. But I’m still not crazy about the mount being on top. This is the passenger side. My driver side is actually 10mm closer to the tunnel and the seat is absolutely perfectly centered to the wheel. I use a 2016 X5 rear seat buckle with an adjustable seat belt extender for the last belt. I added rubber bumpers to keep the slider from smashing into the lap belt mounts. Slider travel is limited for both sides but probably enough for someone up to 6ft. I’m only 5-8. |
02-20-2020, 09:25 AM | #38 | |
Rep 247
I had similar issues centering the seats as well. Agreed that the drivers side is closer to the tunnel as well. Was a little disconcerting when putting that in as it "felt wrong". Eventually I got it worked out as it's the shape of the center console and tunnel. Whatever - thanks for making it harder than it needed to be, BMW. Still, though, the M2 cockpit feels enormous next to my GT3RS. However, my '06 STi race car feels cavernous compared to both. |
02-20-2020, 09:32 AM | #39 |
Rep 737
Are yours on top like mine? Or under the floor adapter? Or were you able to get under the factory Torx bolt? A photo would be great still!
I started with VAC side mounts but I was just a bit short of center to the wheel. These side mounts are the Sparco QRT specific mounts and they were bent at a perfect 90 unlike the VACs. I think that is why I was able to get further over to center the wheel. When my roll cage guy finally gets me in, I’m gonna have him drill through the floor/tunnel and give me real anchor points for the 6 point. Last edited by bimmerboyE92; 02-20-2020 at 09:40 AM.. |
02-20-2020, 09:52 AM | #40 | |
Rep 247
I'll get better pics of the belt mounts themselves tonight. |
02-20-2020, 11:37 AM | #42 |
Rep 247
I haven't spent a ton of time on them due to the current temps plus r-compounds, but they are extremely well built and utilize high-quality components. With the limited amount of driving I've done on them, they feel well controlled and balanced - though fairly stiff. I really need temps to be above 45 to test them out, however.
I'll swap the factory wheels/tires back on at some point and shake the car down a bit. However, traction is always limited in this little machine and it makes it hard to really push this suspension on the street. I don't feel like I'll get any hard evidence until I get it on track in the spring. |
02-20-2020, 11:38 AM | #43 | |
Rep 867
02-20-2020, 01:41 PM | #44 |
Rep 247
