M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Drain plug - S55
      01-24-2020, 06:29 AM   #1
Got f1?
Got f1?'s Avatar
Drives: 06 E46 ZHP, 20 X3M, M2CS
Drain plug - S55
Anyone have 1st hand experience with getting a replacement drain plug? I was looking for a good magnetic one and ran across the ones in the link below but I find some conflicting info on the size. I think it is M12x1.5x16 but would prefer not to guess.
https://drainplugmagnets.com/cars/bmw/
This company claims to have magnets that are rated to 300 degrees.
      01-24-2020, 12:54 PM   #2
Anthony1s
756
Drives: 2018 Mineral Grey M2
RealOEM says it's a M12x16. It's item #4 in this list.
https://www.realoem.com/bmw/enUS/sho...diagId=11_5919
If you order it and for some reason it doesn't fit, I bet you can return it...
Got f1?681.00
      01-25-2020, 09:22 AM   #3
Got f1?
Got f1?'s Avatar
Thanks, I presume the extra 2mm in length won't make a difference. 16 vs 18
      01-25-2020, 11:43 PM   #4
Anthony1s
756
No problem. Let us know if it works out.
How do you plan to clean the plug if there is metal on it? Seems like it'd be a PIA.
      01-27-2020, 10:25 AM   #5
AlpsRider
AlpsRider's Avatar
2865
I think a dry paper towel would work fine.
      01-27-2020, 01:23 PM   #6
ROASTM
Drives: '20 M2C; '06 M3; '07 JKU
I will forever stick to OEM drain plugs after a bad experience with installing an aftermarket magnetic one in my e46 M3 - the plug ruined the threads in my oil pan and required a heli-coil/insert to fix. Unfortunately it still drips a few drops of oil whenever it sits, post-helicoil... will eventually replace the oil pan when doing rod bearings.
      01-27-2020, 01:26 PM   #7
Conissah
Conissah's Avatar
1576
Drives: 2018 M3
I had a magnetic drain plug snap off in a pan before, head sheared right off. A (seemingly) cast aluminum plug with a defect in it. It took very very little torque before the snap, not even enough to flatten the copper crush washer. Since then, I've done nothing but OEM.
ROASTM163.50
      01-27-2020, 01:34 PM   #8
Got f1?
Got f1?'s Avatar
Wow, both scary horror stories. Thanks for letting me know.
