M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > 6MT Transmission fluid change
      01-13-2020, 09:08 AM   #1
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Hi all,
I'm wanting to get my 6MT tranny fluid drained and filled. Wanting to hear everyone's thoughts if you've had this done and if you went with the OEM BMW 75w80 fluid or went with something else like Redline MTL.
Thanks in advance!
      01-13-2020, 01:05 PM   #2
M Fifty
844
Drives: M2 & 330CI
Noting that before Long Life fluids were introduced, BMW appear to have recommended changing the fluid every couple of years, your car which is filled with Long Life fluid - is unlikely to need a change for some time.
Obviously, if you believe the "Lifetime Fill" message, it will end up being a self-fulfilling prophecy, but you still shouldn't need to touch it for several years.
But, it's your car, so change it when you feel like doing so.
HTH
nioh_lbbm21716.50
      01-13-2020, 01:51 PM   #3
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
I'm sticking to BMW stuff on the M2, but I used Redline and SyncroMax on my Mustang before.
Both were better for high temp use, but struggled at low temps in the cold months. In the end I went back to what Ford recommended and that worked well enough on track (though it had that mushy feeling on track) but was baby smooth on the street and at low temps.
2017 BMW M2 German Spec
6MT, Driver's Package
--> SOLD
2018 Camaro SS 1LE. Because race car!
"Redline a day keeps the mechanics away"
nioh_lbbm21716.50
      01-13-2020, 02:03 PM   #4
nioh_lbbm2
nioh_lbbm2's Avatar
1717
M Fifty
I personally don't believe it and even the early year M3/M4 had the tranny fluid changed as part of the run in service but then BMW stopped.
Don't want to turn this into a debate about necessary or not but rather the most suitable fluid
      01-13-2020, 02:06 PM   #5
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Awesome! I was thinking of going with the BMW fluid too. There must be a reason when their fluid is so much more costly vs the redline.
Might be overkill but personally I'll drain and fill my tranny every 30-50k miles
5.M0NSTER3353.50
      01-13-2020, 02:31 PM   #6
M Fifty
844
Drives: M2 & 330CI
Originally Posted by nioh_lbbm2 View Post
M Fifty
Like I said, it's yours. So whenever and whatever works for you.
nioh_lbbm21716.50
      01-15-2020, 10:00 AM   #7
123Britt
Drives: 15 M235i AT
Oem fluid vs redline
My prior 335i was a 6MT and yes I did change the fluid (so easy) and while researching the OEM fluid (way more expensive) I came up with these thoughts:
1. OEM Fluid is way more expensive than Redline Fluid
2. Redline Fluid was recommended by Mike Miller & Bimmerworld
3. Most users of the Redline Fluid (MTL & MT-90) Found Smooth Operation
4. BMW OEM is made to last Lifetime (say 100k miles)
5. Redline Tranny Oil is recommended to be changed (say 30K miles)
I was afraid to move away from OEM and paid big bucks for the OEM Fluid at 50K miles but then at 100K I changed to Redline (I mixed MTL with MT-90) and along with the Clutch Delay Valve delete -- I was amazed how smooth the gears shifted (BMW tech even commented how good the gears shifted).
nioh_lbbm21716.50
      01-15-2020, 10:22 AM   #8
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Thank for this insight. I completely forgot about Mike Miller's guide and you're correct. He does recommend redline MTL! Sounds like that's what I will try. Recently my tranny has been a bit more notchy than it used to be. I'm at roughly 20k miles
      01-15-2020, 12:53 PM   #9
M Fifty
844
Drives: M2 & 330CI
Hmm... unlikely to be the stock fluid breaking down, but looking forward to hearing how you get on.
      01-15-2020, 02:57 PM   #10
nioh_lbbm2
nioh_lbbm2's Avatar
1717
I'm attributing it to gunk and flakes in the oil rather than the oil itself going bad. My hypothesis is that since the fluid wasn't changed during break in there's a lot of stuff floating around in it.
For sure I know the diff has a bunch of crap in it at the 1200 mile drain and fill. I'll update this thread if I remember to after I do the tranny fluid change
      01-15-2020, 03:35 PM   #11
Altra
Drives: 2016 AW M2
Looking forward to your update (if you remember to ). I'm wondering if a diff+transmission fluid flush would improve the gear changes, not that it's bad right now. But there are days where it's incredibly notchy/crunchy.
      01-16-2020, 12:21 AM   #12
windnsea00
Drives: M2 CS
At the 1,200 mile service I had my friend's shop change the transmission oil as that use to be part of the M break-in service back in the day, cheap piece of mind.
Used the factory oil, I figured BMW took the time to test it and certify it, they probably found it the best option/compromise to use.
2020 M2 CS AW 6-spd
Previous M Cars: M2C, M2, F80 M3, E46 M3, Z3M Coupe, E36 M3...and some other fun rides.
