02-12-2020, 02:04 PM | #1520 |
Rep 4,658
Lol at 6lb weight reduction of carbon console but removing rear climate. Just keep the rear climate and make heavier carbon console. Granted, I don't sit in the rear, but would be nice for the kiddos
Kinda has M colors Last edited by medphysdave; 02-12-2020 at 02:10 PM.. |
02-12-2020, 03:56 PM | #1522 |
Rep 13,090
Then your M2 CS got dual zone airco. Same as on the M2C, except for ventilation in the rear (rear end of the center console - passengers in the backseats).
///M is art ↔ Artemis
02-12-2020, 04:04 PM | #1523 | |
Rep 13,090
As 07:42 is the lap time of the first generation Porsche Cayman GT4 (981) (manual, of course - no PDK) clocked By Sport Auto (Christian Gebhardt) in 2015, I hope that the M2 CS manages to perform that lap time. I think that it's gonna be a close call (± 07:43).
F87EVO4029.50 |
02-16-2020, 09:17 AM | #1524 |
Rep 4,658
Interesting date ranges for delivery confirmation for the countries with orders. All the way out through September. Seems to be orders in same country from April to September so maybe they are building multiple batches for each region? Makes me think US deliveries will be September or October. I may be in Munich the beginning of September. That would be neat if timing worked out.
02-16-2020, 10:43 AM | #1525 | |
Rep 6,634
02-16-2020, 10:56 AM | #1526 |
Mmmm... Bavarian
2129
Rep 1,690
Also depends on where/how though too. Unsprung versus sprung, CG etc. It does look like the official number in the Canadian documentation is 25kg lighter for the CS, without the carbon brakes. The E46 CSL was ~100+kg lighter? Not sure what the CG changes and unsprung changes were though as those matter the most if you are really after ultimate handling impact. So the CS isn't really delivering a lot on the "lighter" overall, but it may be in a few places that make a reasonable difference. Until the actual cars are out and reviewed it'll be hard to know the impact.
M2 CS
2023 CB X5 45e 2018 i3 94 2014 Cayman S |
02-16-2020, 11:03 AM | #1527 |
Remove Before Flight
6728
Rep 1,607
I agree it's a huge deal (lighter is *always* better)-- my point was that BMW did a lot more *specifically* to the CSL. On the CS, it seems it was more "flash the motor and raid the parts bin for CF to make the car lighter".
Maybe that means that the M2C is just so good out of the box that all BMW could do to improve it was a mild flash, an MP suspension and go nuts with CF? I just meant that I feel that BMW did more change work to the CSL than the CS-- hence the longer list of different parts M3/CSL v. M2C/CS. R. Last edited by flybigjet; 02-16-2020 at 11:25 AM.. |
02-16-2020, 11:21 AM | #1528 |
Rep 4,658
We take for granted how easy it is to make more power on a modern turbo motor. It still takes many hours of "auto tuning" fuel maps. Then hand tuning some other parameters for optimization. We see it as just another tune. Non turbo required headwork, new springs, retainers, valve job, intake, etc.
Lighter also translates to less liveable. The M2C super good or of the box. Is probably why the CS has the adaptive suspension. C already had the s55. These models didn't go according to plan |
02-16-2020, 12:23 PM | #1529 | |
Rep 6,634
02-16-2020, 12:27 PM | #1530 |
Rep 4,658
I've mentioned before, but will restate. In the current environment of safety standards a CSL will have to be in the design stage from the very start of a production generation. Weight savings is already built into a design by the need to improve fuel economy.
My personal opinion is that future CSL models are a gimmick. |
02-16-2020, 03:14 PM | #1531 | |
Rep 13,090
"What is the E46 M3 CSL? The E46 M3 CSL is a special variation of the standard E46 M3 coupe that features numerous lightweight components, as well as a myriad of drivetrain, chassis and cosmetic enhancements. The "CSL" moniker denotes "Coupe Sport Lightweight" and was first used on the 3.0 CSL homologation special in 1971. A total of 1,383 E46 M3 CSLs were produced to European specification between June and December of 2003 in both left-hand drive (841 built) and right-hand drive (542 built) configuration. (This figure excludes an additional series of at least a dozen pre-production M3 CSL prototypes built between September of 2002 and February of 2003.) The E46 M3 CSL is most notably distinguished from the standard E46 M3 by its various lightweight components. The largest of these is the carbon fiber-reinforced plastic (GFP) roof panel, which weighs over 13 pounds less than its conventional steel counterpart. The front bumper support is also constructed of GFP, as is the uniquely-shaped front airdam with its single intake on the left-hand side. At the rear, the lower rear valance panel is made of GFP, while the reshaped trunk lid is made of SMC (sheet molding compound). Fiberglass-reinforced plastic is used for the rear bumper supports and this material is also "sandwiched" with thermoplastics and foam to create the trunk floor and rear bulkhead. As a final weight-saving measure, the rear window glass is extra thin. BMW claimed that the M3 CSL weighed 3,054 pounds, or roughly 10 percent less than the normal model. The E46 M3 CSL is powered by a modified version of the usual 3,246-cc S54 inline-six that lacks a conventional mass airflow meter. Instead, the air draw is determined directly by the DME for quicker calculations. There is also a more efficient air intake system made largely of GFP and routed through larger manifolds to the circular opening in the front airdam. Further changes include modified camshafts and exhaust valves, plus a lightweight exhaust system constructed of thinner steel. The CSL-spec engine is rated at 360 hp (DIN) at 7,900 rpm and 273 lb-ft of torque at 4,300 rpm. The M3 CSL is equipped exclusively with the SMG II transmission featuring a special launch control mode that automatically shifts at the optimum point for maximum acceleration. This is mated to the standard E46 M3 final drive and M Differential Lock. Finally, the DSC system of the M3 CSL can be switched to M Track Mode via the steering wheel-mounted button. This raises the threshold at which the system intervenes to allow for some degree of wheelspin. The suspension of the M3 CSL is based closely upon that of the standard E46 M3. However, it does incorporate a number of changes, including front coil springs that are shorter by one winding, different spring and shock rates (for both rebound and compression), plus larger anti-roll bars in the front (30.8 mm) and rear (22.5 mm). In addition, the normal aluminum front control arms (shared with the standard E46 M3) are joined by aluminum rear suspension links with stiffer ball bushings. Rounding out the chassis upgrades are a quicker steering rack (overall ratio: 14.5:1) and larger 13.7-inch cross-drilled front brake rotors. Finally, the M3 CSL rides on lightweight cross-spoke alloy wheels measuring 8.5x19-inches in front (0.5 inches wider than the normal M3) and 9.5x19-inches in the rear. These are shod with special Michelin Pilot Sport Cup tires sized 235/35ZR19 (front) and 265/30ZR19 (rear). (Conventional tires mounted to the 19-inch forged M Double Spoke II wheels from the standard E46 M3 were also offered as a no-cost alternative.) In addition to the aforementioned lightweight body components and unique wheels, the exterior of the E46 M3 CSL is further distinguished by a special "CSL" insert in place of the usual "M3" model designation within the decorative intake grilles on either fender. In addition, there is an "M3 CSL" badge on the trunk lid. Exterior colors were limited to Silver Grey metallic (A08) and Black Sapphire metallic (475). Though the interior of the M3 CSL retains the standard E46 M3 dashboard (with Titan Shadow trim), instruments and general controls, it differs significantly in most other areas. The minimal door panels are constructed of lightweight GFP and lack the usual side airbags. Likewise, the center console surrounding the parking brake is also made of GFP and contains the power mirror switch that normally resides on the driver-side door. The deeply-bolstered front seats (similar to those found in the M3 GTR) have GFP backings and are upholstered in a combination of Anthracite "Reflex" cloth and Amaretta (synthetic suede). The two special individually-shaped rear seats are also covered in the same materials. The Alcantara-wrapped M three-spoke steering wheel contains only the M Track Mode switch in place of the usual audio and cruise control buttons. The parking brake handle is similarly fashioned from Alcantara and both door sills contain unique trim plates. In keeping with the lightweight, driver-focused manner of the M3 CSL, standard comforts were limited to just power windows, an auto-dimming rearview mirror, central locking and the on-board computer. The short list of extra-cost options included only an anti-theft alarm, green-tinted windshield stripe or climate comfort windshield, velour floor mats, bi-Xenon headlights with headlight washers (washers excluded on UK-spec examples), Park Distance Control, rain sensor with automatic headlight control, automatic climate control and various cassette/CD/mini-disc radios. There were also three no-cost options available: deletion of the rear "M3 CSL" badge, a "smokers package" that included an ashtray and cigarette lighter, plus the fitment of the forged M Double Spoke II alloy wheels with conventional tires from the standard M3 in place of the CSL's cross-spoke alloy wheels with Cup tires. One final factory option was the removal of the standard 155-mph top speed limiter." (source: here) Interested to know all the differences between the 450hp 550Nm S55 engine in the M2 CS and the 450hp 550Nm S55 engine in the M3C/M4C.
02-16-2020, 05:02 PM | #1532 | |
Rep 3,842
02-16-2020, 05:41 PM | #1533 |
Mmmm... Bavarian
2129
Rep 1,690
03-01-2020, 09:24 AM | #1535 |
2528
Rep 1,908
Damn, BMW really nailed the front end aesthetics on the M2C/CS, including incorporation of the iconic kidney grille.
Some things just should not be tampered with . . . could someone please let BMW executives know change for the sake of change is not a good idea. ///AVM |
03-01-2020, 10:07 AM | #1537 |
Rep 4,658
I certainly like the look of a lower stance, but I can tell you that having a practically high ride height has saved my carbon lip from being destroyed by parking curbs. I'm also kinda tired of getting in and out of a 2dr sports car, but it's my DD. Probably non issue for weekend fun car.
03-07-2020, 06:48 AM | #1539 |
Rep 4,658
Man, the news has dropped to nothing. Either these things aren't selling, or the folks buying are tired of being called idiots and not talking about it. I'm getting bored of refreshing the BMWUSA website.
03-08-2020, 04:14 AM | #1540 | |
Rep 2,809
If I had committed to one I’d be shouting about it daily until it turned up. |
