M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > OFFICIAL: M2C Exhaust Options MegaThread
      03-12-2019, 03:56 PM   #45
Dav3
Dav3's Avatar
949
Drives: G87 M2/E89 35is/F21 M140i/GT4
More of Remus (OPF) by Joe Achilles
      03-12-2019, 05:01 PM   #46
Karlosm2c
Karlosm2c's Avatar
291
Drives: M2 Competition
I can't say I'm a fan of the note on this, even with valves open. I know you'd hardly ever see it as it's under the car, but I also don't like the look of the rear muffler cans either. They're just a bit plain looking. I have held one of these Remus mufflers though and they are quite light. I'll give it that.
2019 HS DCT M2 Competition with Essex AP Racing Radical Pro5000r front and rear BBKs, Bilstein B16s and 763M wheels with Cup 2s
      03-12-2019, 05:27 PM   #47
G80BSM
G80BSM's Avatar
283
Drives: 2023 M2
Originally Posted by _RS4_ View Post
Add the Milltek
Miltek sounds the best compared to other exhausts. If I ever change the exhaust, Ill go with miltek exhaust.
KevM2721.50
      03-12-2019, 05:50 PM   #48
mike@x-ph.com
mike@x-ph.com's Avatar
I like it
https://x-ph.com/sale/
Phone number 702-494-9435
      03-12-2019, 05:52 PM   #49
Dav3
Dav3's Avatar
949
With OPF limitation, there's only so much you can do. Pretty much all of the listed exhausts in this thread take the stock sound and make it a bit different but not enough to make it sound like something new.
I think Remus gets close to Lightweight with darkness in growl and overrun pops and burbles. Eisenmann is the most conservative but also the smoothest which for those who hate the crackling is a big pro.
I'm still very undecided on which one I'll end up pulling the trigger on.
Karlosm2c290.50
      03-12-2019, 06:11 PM   #50
Karlosm2c
Karlosm2c's Avatar
291
With OPF limitation, there's so much you can do. Pretty much all of the listed exhausts in this thread take the stock sound and make it a bit different but not enough to make it sound like something new.
I'll have my Lightweight exhaust fitted on 20th April at their HQ in Fleisbach. I'm looking forward to hearing it on my car in person after hearing the various sound clips on the internet. I really hope I'm pleased with the end result 🤞🏻🤞🏻 I should probably code out ASD in the cabin too.
      03-12-2019, 07:13 PM   #51
Dav3
Dav3's Avatar
949
I think you'll be very happy with it.
Turning ASD off is definitely suggested when mounting an aftermarket exhaust.
Don't know if they updated the bimmercode app but last time I used it and coded ASD out, there was no option to revert it back on.
If you want to tinker with it when ON/OFF, I suggest installing this ASD bypass harness. Takes around 5 minutes to install.
      03-12-2019, 10:10 PM   #52
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Not really fair that car has aftermarket DP's too
Dav3948.50
epic133.50
      03-13-2019, 02:15 AM   #53
Karlosm2c
Karlosm2c's Avatar
291
Thanks for this. How does the product work? I can't make sense of it from its description.
      03-13-2019, 01:01 PM   #54
Dav3
Dav3's Avatar
949
It's just a physical bypass which blocks and mutes ASD from playing from the speakers.
Install is just a matter of removing a few plastic rivets in the trunk and placing the cable between the amp and another cable.
Can't really give you the technical side of it but all I can tell you is that it works flawlessly!
Karlosm2c290.50
      03-13-2019, 01:03 PM   #55
Karlosm2c
Karlosm2c's Avatar
291
I will have to see if it's available in the UK. If not then permanently coding out ASD it is
      03-13-2019, 10:03 PM   #56
KevM2
KevM2's Avatar
BMW M2 Competition  [0.00]
  [0.00]
What is the diameter of the stock midpipes?
      03-14-2019, 05:04 AM   #57
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
I had ASD coded out and it ain't ever coming back as long as I am in the car.
Exhaust sounds great without the ASD, so much more natural. For those Comps without the OPF, you don't need these exhausts as acoustically they are just minor variations of the stock exhaust noise and don't really sound better. Change for looks but don't expect a better quality soundtrack.
      03-14-2019, 05:19 AM   #58
M2C89
M2C89's Avatar
Drives: 2020 M2 Competition
I think the best sounding one is the aFe by far, followed by the AA. Both have a single mid pipe and this makes the biggest difference, in a good way! All the others just sound like just another raspy variation of the stock sound.
This is all based on videos, obviously.
KevM2721.50
StavsM2C119.00
      03-14-2019, 09:50 AM   #59
Dav3
Dav3's Avatar
949
True but here in Europe you have to work with what you got
Most people care about warranty, so a mid-pipe is not really an option
I recently made a bunch of people listen to stock and all of the listed aftermarket exhausts
Half of the people actually detested the cracks and pops and ended up preferring stock and/or the eisenmann exhaust.
This said, none of the exhausts, including the one's with the mid-pipe, where given anything above a 7-.
It is what it is.
I'm leaning towards eisenmann now. Hope to hear more if it soon.
      03-14-2019, 10:10 AM   #60
KevM2
KevM2's Avatar
  [0.00]
It is what it is.
Would a single midpipe void warranty?
Dinan's exhaust should be coming out soon and it sounds promising!
      03-14-2019, 10:47 AM   #61
Dav3
Dav3's Avatar
949
In Europe indirectly yeah, because with a mid-pipe you'd have OPF issues so you'd need the dme flashed to avoid limp mode
With a non-flash related solution to car running limp mode as a result of OPF removal, it could also be problematic with BMW reps
You're kinda force to leave the device installed for the car to not run a CEL and BMW reps will most likely investigate what's wrong. Not sure what they can do or say but it could create complications with eventual warranty work. (For good and bad reasons)
If you're in the US, where OPF doesn't exist, midpipe shouldn't void warranty. Probably only warranty related to the exhaust.
      03-14-2019, 03:35 PM   #62
M2C89
M2C89's Avatar
I think that's so funny, how people's perspectives are so different. For me, the burbles and pops sound amazing. That's the best part I think.
      03-14-2019, 03:59 PM   #63
epic
M Comp
epic's Avatar
I'm also in this unpopular camp. I just want them louder and deeper in sport mode so I'm patiently waiting to hear MPE and any others before picking one.
'19 M2 Competition | '07 Heads/Cam/Stall C6 Corvette | '17 Ford Escape Titanium
Past: '14 M235i, '07 335i xDrive, '06 GTO, '02 Trans Am Firehawk, '99 Grand Prix GTP
      03-14-2019, 04:52 PM   #64
Juicehead
Drives: Raptor
Does anyone know a milltek vendor on the boards who sells in the US?
StavsM2C119.00
      03-14-2019, 04:54 PM   #65
mike@x-ph.com
I'll check if i can source it
      03-14-2019, 05:30 PM   #66
mike@x-ph.com
pm me which system you need, i can get it for you
