M2 Technical Topics > Track / Autocross / Dragstrip > M2C in AS
      02-03-2020, 07:42 AM   #45
CSBM5
CSBM5's Avatar
2721
Drives: 2019 M2 Comp, 2011 M3, etc
Update #2:
We had a CCA Sandlapper chapter autocross at the Performance Center yesterday, and once again Mike and company laid out a wonderful, fast and flowing course using essentially all of the PC's real estate. To recap - stock M2C with OZ stock width and offset wheels and 255/35-19, 275/35-19 RE-71Rs. I've got many runs on roughly the same track layout over the past 13 years but either in my E39 M5 (sold now) or my E90 M3, so I was a bit weary of really laying into the M2C right off the bat given the nature of the S55 (worry for naught in hindsight) torque.
I set some very good times but still leaving some on the table in various spots. I ended up switching to Sport+ and adapting to its response since in the faster corner exits (generally much faster than a typical autocross), Sport just felt too dull and delayed getting it done. Since forever when driving an event (autox or track) and always when instructing others, I've been a firm believer in non-sport throttle settings, but that is on older gen normally aspirated cars where all it does is (in many cases) interfere with fine weight transfer control via a jumpy throttle.
Hence I needed the response of Sport+ to get as much power as fast as possible on some of these higher speed corners coming off the apex. The car could really suck up the power into the 275 RE71Rs with only minor drift angle and/or appropriate throttle management out to the track out area. Sport+ really helps build boost faster (obviously) when coming off zero to minor maintenance throttle at the apex. Clearly I need a LOT more experience driving this car on a venue like this to get used to the engine response. That said, the overall power curve once you're into boost fully (WOT) is very linear feeling all the way up over 7k rpms.
I tried all day to keep pressures at 34-35, but I also needed to fool around with those (ran equal front/rear all day). I think I bled out about 15 psi total from the fronts. Fronts get very hot from the brakes too on this course (85.6 second runs), and you get right back in line for your group of ~15 cars, so not too much cooling off time between runs.
One other post-event thought that only late in the day occurred to me. The starting line is on a straight with a sideways sloping camber; hence in my past experience, when you launch hard (typical LSD) and get just the right amount of wheel spin, you get some sideways movement of the car as expected. I didn't really get any of that with the M2C. I had trouble getting a really good hook since if I just barely missed that window of slip, the rear would wheelhop, but a few times I got it just right and it hooked hard and laid down smooth rubber through most of 1st with proper throttle management. No sideways road-camber-induced drift that I can think of in retrospect.
I'm curious now if the programming of the Active-M LSD clutch engagement is responsible for this awesome outcome. After all it has inputs from everything, so if knows the car is on an angle, it knows your steering input angle, throttle intentions, etc, and it also knows the derivatives of all of those (rate of change of each), all in continual real time. Hence its very well possible it is managing rear lock-up amount in order to keep the car headed in the intended path under full throttle slight wheelspin launch conditions. Maybe?
Nonetheless to this old analog guy, I'm not used to this stuff, but I'm learning albeit a bit slowly. I sure love the open nature of the LSD on corner entry as this thing just turns in with abandon as opposed to pushing like a plow with some static LSDs (i.e. equal ramp angle like OE LSDs) do in something like the E39 M5. Corner entry is actually one (maybe only) good aspect of the Visco-LOK LSD in the M3 too as it has very little to zero locking on slow corner entries and allows the car to turn-in nicely.
I hope to get more seat time in a couple of months with a proving grounds autocross huge course on the schedule. Lots to learn...
Current Stable:
2024 G20 M340i Melbourne Red/Cognac
2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg
2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8
      02-03-2020, 03:49 PM   #46
Whit45
Drives: '08 E90 335i/'10 E92 M3/'13 Is
Congrats on the second FTD of the day at PC autox; thats flying! I think Mike was around a 84.5 in the M5 Comp. I was able to drop 5 seconds by the end of the day, and realize I need a lot more seat time in the M3.
Is the learning curve worth it with the Firestone 500's i'm running ,or should I just suck it up and purchase the RE-71R"s?
CSBM52721.00
      02-03-2020, 07:18 PM   #47
CSBM5
CSBM5's Avatar
2721
Thanks, I actually had FTD (other than Mike's runs). Richard's best was 90.xx something, so not sure where they ended up showing the time for him; he and I talked all day about what he could work on. I think he was perhaps one that Mike drove his car perhaps (or timing issue; in one of my final runs I go timed at 75 something which was clearly in error).
I think the 500s should be fine for learning. If you really want to zoom upward and therefore practice good habits, taking an Evolution autocross school (Phase 1 and Phase 2) is the way to go. Fantastic schools. I think there is one weekend with both coming up this spring in Bristol TN.
Current Stable:
      02-03-2020, 08:58 PM   #48
Whit45
Registered for Saturday and Sunday; thanks for the info
      02-04-2020, 05:07 AM   #49
CSBM5
CSBM5's Avatar
2721
I just checked their schedule, and it looks like both phase 1 and 2 are on the same day, so perhaps it's not a two day affair like I thought? I had just glanced at their calendar and assumed it was one each day. In the distant past these were usually setup to allow students to do 1 on Sat and then 2 on Sunday. Sorry if I screwed up something. Mike will surely let you cancel one registration -- he's a great guy and runs a fantastic school.
Current Stable:
      02-04-2020, 06:58 AM   #50
Whit45
Thanks for the heads up; hoping its just a typo, as some of the other locations are 2-3 weeks apart.
      02-08-2020, 08:51 AM   #51
Whit45
They are doing 1&2 on Saturday the 25th. I'm going to take phase 1 on Saturday, then do they SCCA solo 3 on Sunday, also in Bristol.
CSBM52721.00
      02-08-2020, 12:01 PM   #52
CSBM5
CSBM5's Avatar
2721
Sounds good, you'll enjoy it!
Current Stable:
      02-08-2020, 01:42 PM   #53
toy4speed
Drives: bmw m2
I guess you guys heard the M2C is in BS now for SCCA? Going to be interesting comparing tire setups and course dependent results!
CSBM52721.00
      02-08-2020, 03:16 PM   #54
CSBM5
CSBM5's Avatar
2721
Thanks, no haven't followed rules updates. I've only autocrossed it in CCA events so far, but that's great news.
Regards,
Chuck
Current Stable:
      02-09-2020, 11:35 AM   #55
toy4speed
Drives: bmw m2
Last year I went from SCCA B-street with my '18 LCI, to BMWCCA autocross events in the AAA class with front camber plates and really enjoyed the more balanced front end. Too bad the M2 isn't in STU for SCCA, but there is a new SCCA class this year call Xtreme Street, basically full mods on street tires (200 tw), so the M2 models would be in XS-A. There is XS-B for lighter cars. Much like what CAM class did for American cars. I am not competitive in any class (driver limited) but do enjoy the car more with front camber.
CSBM52721.00
      02-10-2020, 10:06 PM   #56
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
Adding neg camber on the front of any M car helps a ton. Around 2.9-3.1 for 200 tires and around 3.4 to 3.6 for Hoosiers...
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
