M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > THE ULTIMATE Intercooler Thread - What to Look For Before Buying an FMIC
      11-15-2018, 03:23 AM   #111
F87source
F87source's Avatar
Drives: Bmw M2
Originally Posted by ChristosD View Post
use two stock m2 with just the coolers changed and do a couple canyon rips and see which cooler provides the best all round result. (probably the more stock the car is the more accurate the results will be)
It would also be interesting to put the car on the scale and see which one shifts the weight more towards the front, quite relevant for track guys.
The canyon runs would have to be back to back one car trailing the other, but I don't think you can push the car to it's limit on a public road. It's better to take it to a track, high and low speed (time attack style and auto cross). High speed to see if it can keep temps down underload on and off the gas in high and low speed corners, low speed auto x to test if it'll heat soak and if it does how fast it can drop those temps when air flow returns.
Weight balance would be nice to see (probably would be way to time consuming and not as necessary as performance), but id weight the intercoolers on it's own, as the mass is so small compared to the car it shouldn't tip the mass to the front that much more if the delta between the two coolers isn't significant.
      11-15-2018, 05:21 AM   #112
atlas
383
Originally Posted by Tiago@VRSF View Post
We have to crawl before we can walk
As of right now this is as close as we've come to any comparison between brands. If we can keep up the momentum and add a couple more brands to the list we'll have a better foundation to build and improve on.
Of course we will appreciate whatever comes of this. As others have said however, testing different scenarios would make for a great comparo and be of even more benefit for the community.
For example, logging the results of multiple 2-5 gear pulls in succession could add another dimension to the simulation, testing for potential temperature inertia.
      11-15-2018, 09:22 AM   #113
kpaso
Drives: BMW
You wouldn't need to put the cars on a scale for this.
You would just need to weigh each intercooler. You can do the rest of the math in your head to figure out which one would shift more weight towards the front.
      11-15-2018, 01:51 PM   #114
F87source
F87source's Avatar
Drives: Bmw M2
+1 especially since it's before the front axle.
      11-15-2018, 06:08 PM   #115
963mw
BMW Fanatic
963mw's Avatar
Donations should go to animal shelters around the Malibu area or to people who need it due to the fires.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      11-15-2018, 07:20 PM   #116
F87source
F87source's Avatar
Drives: Bmw M2
+1
Edit- I forgot that there was a donation involved in this comparison. But yeah those people down in Cali affect by the fires definitely could use the support.
      11-16-2018, 11:33 PM   #117
magha
magha's Avatar
93
Drives: '18 M2 AW 6 spd
So is the ER premium over the 5" VRSF worth it for primarily street application with a stage 2 BM3 tune?
18 M2 6 Spd AW - VRSF DP / CP & Race FMIC, ER TIC & GFB DV+ with BM3 Stage 2
Retired 09 135 JB4 G5 ISO w/BEF, N54 Tuning Performance DPs, BMS DCI, ER Charge Pipe
      11-17-2018, 09:26 AM   #118
mike@x-ph.com
mike@x-ph.com's Avatar
ER intercooler should be compared to VRSF Race since they are of similar size.
I would go with VRSF race
https://x-ph.com/sale/
Phone number 702-494-9435
      11-17-2018, 01:52 PM   #119
magha
magha's Avatar
93
thanks Mike! between the 5" and 6" is there a noticeable difference? i will track but perhaps a few times a year but do want to run the BM3 stage 2 tune along with a CP & DP.
      11-17-2018, 03:28 PM   #120
mike@x-ph.com
Assuming everything else is identical , 6" will easily outperform the 5"
I recommend it for any stage 2 setup
      11-18-2018, 12:11 AM   #121
magha
magha's Avatar
93
great thanks for the advice!
      11-18-2018, 01:14 PM   #122
mike@x-ph.com
My pleasure
      11-22-2018, 01:57 PM   #123
Bosozoku
Almost completely sane
Bosozoku's Avatar
Drives: '17 M2, '00 S2000
Just a quick noob question about "pressure drop": is this the difference between the input and output pressures of the FMIC?
In other words, if the turbo is producing X psi and the throttle body is seeing Y psi,
is the FMIC's "pressure drop" simply X - Y?
Thanks!
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace)
      11-22-2018, 04:17 PM   #124
R0ME0
"The Midas Touch"
R0ME0's Avatar
519
Drives: F87 LBB ///M2
2017 M2  [10.00]
2008 Z4M - SOLD  [0.00]
Originally Posted by FaRKle! View Post
I really hope these tests include enough runs for statistical significance and will replicate actual conditions end-users will experience on the street and track. If a test isn't relatable to actual use cases, then it's pretty meaningless (other than for marketing purposes, which isn't to the end-users' benefit).
Importantly for the track will be how do the reduced IATs translate to speed, which is the ultimate metric being chased.
Sourcing would ideally be from a blind retail channel.
@Tiago@VRSF If you're looking for a tester still let me know. This thread is exactly what the people need to see when making a decision on their intercooler. Been wanting to better understand the better product between CSF and VRSF race intercooler. I'm running a BMS Intake, FI Exhaust, VRSF catless downpipe and on BM3 stage1 ready to move to stage 2. Let me know if you still need testers!
      11-24-2018, 06:16 AM   #125
ChrisM4
ChrisM4's Avatar
1619
Drives: 2024 M4 Comp X-Drive
Great thread and love seeing the vendors willing to do a comparison and donate to charity.
I'd like to see data between the stock intercooler and aftermarket plug and play (no mods needed to the car to install) intercooler on the stock turbo.
Cheers,
Chris
2024 Dravit Grey M4 Competition X-Drive
      11-24-2018, 06:14 PM   #126
Anthony1s
756
Drives: 2018 Mineral Grey M2
Anyway the testing will be done before black friday sales are over? LOL
963mw331.00
      11-24-2018, 11:49 PM   #127
Anthony1s
756
Thanks!
Well, yea, but I don't think that's an issue. I think the car would just let more boost in to make up for it.
If you bring this up because of turbo lag due to a larger intercooler, it isn't pressure drop that causes that. It's that the larger intercooler takes longer to fill before passing the air to the engine.
Bosozoku693.50
      11-25-2018, 08:04 PM   #128
kristobias
kristobias's Avatar
293
Drives: M2CS
Recommendation for the following-
Stage 1 car (tune for 94 octane)
Intake
12+ track days per year. 22-30min sessions. Hot weather in the summer. High speed track (Mosport)
Other mods are bbk and sticky tires. Experienced driver who wants to run the entire sessions with no heat soak
Car is a DD outside of track days
17 X5D
70 2002
      11-25-2018, 10:26 PM   #129
mike@x-ph.com
Intake
Wagner EVO I Competition or VRSF 5" High density
      11-26-2018, 11:45 AM   #130
Bosozoku
Bosozoku's Avatar
Thanks Just wanted to clarify the meaning of "pressure drop."
      12-06-2018, 02:47 PM   #131
atlas
383
So is this wager still on or what?
      12-06-2018, 03:09 PM   #132
Anthony1s
756
Looking for a recommendation. Currently undecided between the Wagner Evo 1 and Evo 2 Competition. Want tube and fin for light weights.
Mods:
Stock turbo (probably never gonna upgrade)
Stock downpipe (maybe will upgrade to sport cat one day, but fear the noise)
MPE
Eventuri Intake
Bootmod3 Stg 1 or Stg2 93 octane
I'm gonna experiment with both tunes. I know it says Stg2 needs a downpipe, but I plan on flashing it and looking at the logs to see what's up. Also may switch back to stock tune for winter. My driving is mostly street and some woodsy curvy roads for fun. I live in Pennsylvania and 1-2 months per year we will see 100f somedays, so I'm not in a really hot climate.
