M2 Technical Topics > Track / Autocross / Dragstrip > B-street setup
      03-08-2019, 11:26 AM   #133
Karazy
Go Fast And Take Chances
Karazy's Avatar
Drives: 2020 M2C
Old Geezer, I'm curious what psi you are running with your RE's. I'm finally next on the list for a 2020. Been a long wait...
Originally Posted by Old Geezer View Post
What's the intended usage - track or autocross? I found running my '17 M2 on square 265/35-18 RE-71s with 18x9F/18x10R EC-7s using stock offsets, I had to run a few PSI more in the rear to get the car to rotate.
With my M2C running 255/35-19F & 275/35-19R RE-71s on stock rims, it rotates nicely with equal pressures front and rear.
My 2 cents is that people get a bit preoccupied with running a square tire setup. I'm not convinced its necessary. It's something of a moot point if one has to run 19's anyway. The height of the front tires effectively limits how wide you can go.
2014 Corvette Z51 Stingray 3LT, 7 M/T
2015 KTM 1290 SA
Retired- 11 BMW 335, 07 BMW R1200GSA, 04 BMW Z4, 01 BMW K1200RS, 00 BMW R1150GS
      03-08-2019, 12:34 PM   #134
Old Geezer
Drives: 2019 M2C
My experience on my ‘17 M2 was that due to the relatively stiff sidewalls, the RE-71R is tolerant of a wide range of pressures. With the square 265/35-18’s, I started at 32f/32r on the recommendation of a fellow M2 driver. Another friend of mine in a ‘18 M2 said he ran 36f/36r. I tried that and liked it, although I ended up at 36f/38r to get better rotation.
With the M2C, I started at 32/32 with the 255/35-19, 275/35-19 setup. On a low-grip surface, running 30 in back makes the rotation easier to manage. Most of my events take place at a venue with grippy but abrasive concrete. I don’t know how much more abuse the fronts will take, so I’m going to try 36/34 for my next event. I may roll the dice and try 265/285 next.
Run some events with the OEM tires. The M2C is way more throttle-steery than the base car. You need to learn how to cope with it.
More than you wanted to know?
CSBM52721.00
      03-09-2019, 10:36 PM   #135
Karazy
Karazy's Avatar
Drives: 2020 M2C
Thank you for the info! I've been running 30 psi all ends the last few years in my C7. Planning on putting RE-71 on immediately when I get the car, and just saving the stock tires for another time. I'm on the fence about also jumping to 265/285 over the 255/275. Do you think there will be rubbing / clearance issues?
2015 KTM 1290 SA
      03-10-2019, 06:14 AM   #136
GasBurnlife(landapanda)
No rubbing issues on my '18 with this setup (255/35 & 275/35) with stock suspension and PS4s.
Karazy49.50
      03-10-2019, 06:37 AM   #137
CSBM5
CSBM5's Avatar
2721
Drives: 2019 M2 Comp, 2011 M3, etc
From what I can gather from other forum posts, the 265/35-19 up front will rub due to its diameter increase. There are various posts discussing where and how severe the rubbing can be.
If we could just get 275/30-19 and 295/30-19 in RE-71R or Rival S 1.5....BFG did just release the S1.5 in 275/35-19 however.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac
2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg
2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8
Karazy49.50
      03-10-2019, 05:58 PM   #138
Old Geezer
Drives: 2019 M2C
Really don’t know if 265/35-19 in front is doable or not. The forum posts on the subject go both ways. Although the M2C might benefit from more tire in front, it desperately needs more tire in back.
FWIW, I think your Corvette can run less pressure due to the amount of camber you can get with the factory suspension. I have a friend with a gen6 ZL1 1LE Camaro, and he runs pressures similar to yours.
CSBM52721.00
Karazy49.50
      03-10-2019, 06:36 PM   #139
Karazy
Karazy's Avatar
Drives: 2020 M2C
Thanks for all the feedback guys!
2015 KTM 1290 SA
      03-22-2019, 06:20 AM   #140
Blue2
Drives: 2024 M240i
Just an FYI: the 2019 M2C has been classified as A-Stock, up from the OG M2's B-Stock classification. Somewhat annoying, but I think they lump all M Competition models in A-Stock.
      03-22-2019, 06:51 AM   #141
CSBM5
CSBM5's Avatar
2721
Yeah, I saw that a few weeks ago. It has no chance in A-street (unless Rich is driving it like his A-stock days of lore with the roller skate) I would guess. At least it is small (short) albeit wide though. Mid-range torque is insane in this car, so fitting up 305/30-19 RE71Rs in the rear would be helpful.
Current Stable:
      04-05-2019, 09:59 PM   #142
Wisco M3
Drives: 2018 Alpine White M2
I’m interested to see what happens. I’ve got a Dinan front bar on full soft, and 285 x 18 in front, 275x18 in back. The last event of last year I tried 265x18 in front and 275x18 in back and it was a pushy pig that was somewhat frustrating to get to do what I wanted. Now, the tires were virtually dead, but I felt the car needed a lot more front grips not just rear grip.
If this turns out to be too over-steer-e I should be able to dial it out with the front sway. If that doesn’t work I can always go to wider 19’s in back. The car should be able to get plenty of tire to be a freakin’ riot. Last event last year it was freakin’ frustrating.
2011.5 E92 M3 - Gone but not forgotten
2018 F87 M2 - The new hotness
      04-05-2019, 10:21 PM   #143
Old Geezer
Drives: 2019 M2C
Just out of curiosity, what M Engine Dynamics setting are you using?
      04-06-2019, 06:17 AM   #144
CSBM5
CSBM5's Avatar
2721
Sport or Sport+ (M2C).
Current Stable:
      04-06-2019, 07:43 AM   #145
Old Geezer
Drives: 2019 M2C
Finally tried Sport at my last event, and found the car much easier to control than with Sport+.
CSBM52721.00
      05-01-2019, 09:18 PM   #146
boony1968
boony1968's Avatar
18
At Sunday's autox the nanny's kicked in on me on the last run of the day. I was in Sport with the DSC completely off. The car told me my pressures were too low about 2 minutes before pulling off to the start line, . I pulled them up and the car had them all at either 32 or 33 lbs. I had been bleeding down to 35 lbs all day with a borrowed gauge - it was likely showing a lb or two lower than actual. A timing issue delay must have given them enough time to drop temps and pressure. The car was cutting power within the first 10 seconds of the run and continued to cut power throughout whenever I began to load up a corner. Miserable...
Running Re71R's. 275/35/18's and 305/30/19's.
Has anyone tried to run with pressures in the lowish 30's range with success? I was surprised, frustrated and disappointed at the intrusiveness.
      05-01-2019, 09:41 PM   #147
Old Geezer
Drives: 2019 M2C
I had that happen a few times with my ‘17 M2. What I found helped was to reset the TPM before the first run, but after setting my initial tire pressures. This was running 32/32, w/square 265/35-18 RE-71Rs.
      05-01-2019, 09:41 PM   #148
rwalker
Drives: the wheels off
I don't see the Comfort Mode forcing until I'm under 29psi.
Your issue may be due to pressures dropping while the car's running. I think you might be able to get around this with a TPMS reset at the lower pressures.
Good luck. Coding folks, please weigh in with a real solution.
      05-01-2019, 09:44 PM   #149
Old Geezer
Drives: 2019 M2C
Just a hunch, but I don’t think it’s related to a specific value as much as how much the pressure has changed relative to what it was when the TOMS was last reset.
      05-01-2019, 09:44 PM   #150
boony1968
boony1968's Avatar
18
Has anyone tackled the camber correction knuckles that are available? The claim is an additional -.5 degrees of camber. From what I can see the job looks straightforward enough. What I can't see is what concerns me as I'd prefer to do the install myself. $700 is steep but -1.7 or so negative camber would be helpful and might pay for itself in tires alone over two to three seasons.
'18 M2 - Alpine White - 6M
      05-01-2019, 09:49 PM   #151
rwalker
I wish. There's no way to reset past a sub-27psi pressure in my car, and I've screwed around with the DSC pressure settings a bunch to no avail.
      05-01-2019, 09:51 PM   #152
boony1968
boony1968's Avatar
18
Thanks, this potentially makes sense. The warning caught me of guard and didn't think much about it at the time. I piddle with a lower reset value and see what happens.
      05-01-2019, 09:59 PM   #153
boony1968
boony1968's Avatar
18
27 is a pretty low target, much lower than I'd need with my tire sizes. 27 was borderline too low on my Corvette GS with correct tire to wheel sizes running BFG Rivals. I normally run 35 to 36 lbs but this particular lot was sealed asphalt, lower pressures should have been somewhere in the okay to optimal range.
      05-01-2019, 10:04 PM   #154
Old Geezer
Drives: 2019 M2C
You could be right. I’ve never gone that low. In my experience, the RE-71Rs tolerate a fairly broad range of presures. I’ve found I prefer the way the car drives towards the high end of the range; the shoulders on the front tires last longer as well.
Karazy49.50
