11-18-2023, 12:00 PM | #45 |
Rep 8,972
Yes oe discs are aluminium bell and iron disc with pin fixing to allow movement for expansion.
11-18-2023, 02:48 PM | #46 |
Rep 8,972
Black Friday...
Uk, genuine bmw discs £400 each great price. https://www.mlperformance.co.uk/prod...oaAtb8EALw_wcB Pads £250 genuine, https://www.mlperformance.co.uk/prod...9&_ss=e&_v=1.0 Sensor £16. Caliper bolts (single use) £30. 2 hours to fit - at most. Good indy £150, or fit your own , I did. £1250 total. Last edited by doughboy; 11-18-2023 at 02:54 PM.. |
timchump57.50 |
11-18-2023, 03:41 PM | #47 | |
Rep 71
Meaning you can’t put new pads on them So suggested waiting until the pads are worn… Not sure how true that is ?…….. |
11-18-2023, 05:15 PM | #48 | |
Rep 71
ML Performance seems to be the best price in the UK I’m not sure if I’d go for OEM pads again, as others have said they are harsh on the discs My pads still have loads of meat on them, surprised the pads have outlasted the discs tbh But it does seem to back up the opinion the stock pads are harsh |
11-20-2023, 11:55 AM | #50 | |
Rep 71
How many sensors do i need ot buy to change the fronts |
11-21-2023, 12:43 AM | #52 |
Rep 8,972
Yes left (uk nearside) front.
I bought them when i did all my brakes, but they hadn't worn at all so I didnt actually need them, sent them back. Better to have one just in case though, depends how worn your pads are. |
timchump57.50 |
11-21-2023, 12:26 PM | #53 |
Rep 4,690
For sure. I swapped pads recently. Got distracted and didn't remember to unhook the connector from the pad. They snap pretty easily. It would have been fine for another pad swap had I been paying attention. I use a little flathead to rotate and pop them off.
11-21-2023, 01:50 PM | #54 |
Rep 71
Does anybody have any opinions on this ……? Thanks…
11-21-2023, 03:31 PM | #55 |
Rep 337
I'm curous about this as well. If you think about it we only have pad wear sensors and that is what tells the dealer to do brakes. I have about .13mm left on my fronts with 32.6k on them. I'm not changing anything until my pads need replacing.
timchump57.50 |
11-21-2023, 03:48 PM | #56 | |
Rep 71
If I didn’t change discs until my pads sensor indicated I’d get to at least 40k maybe more. To be honest I’d be ok with changing at 40k ish miles, but at a relatively low mileage doesn’t sit well with me, especially considering the cost. The independent said when the discs get below the minimum they’re not going to explode or anything, I’ve also read the minimum thickness is related to how far the pistons would have to push. So if you have a fair bit of meat on the pads I’d think it would be ok Last edited by timchump; 11-21-2023 at 03:53 PM.. |
11-21-2023, 03:55 PM | #57 |
Rep 8,972
That makes sense in that nobody would measure disk thickness until they changed the pads as brake maintenance check is dictated through pad wear (for users following dash service info anyway).
Certainly BMW don't just measure disks for no reason, they only do what the computer tells them to do.... unless of course they were touting for unnecessary work..... Last edited by doughboy; 11-21-2023 at 04:03 PM.. |
timchump57.50 |
11-22-2023, 03:27 PM | #58 | |
Rep 71
This BMW dealer did a similar thing to me with my OGM2 said the pads needed doing very soon, spoke to another dealer who said get them done when the indicator comes on. A year later I sold my OGM2 in that time the sensor still had not come on. Trouble is the dodgy dealer is 5 minutes walk from my house, very convenient for me |
11-22-2023, 04:12 PM | #60 |
Rep 71
11-22-2023, 04:21 PM | #61 |
Rep 8,972
11-22-2023, 04:36 PM | #62 | |
Rep 71
Oh does it change over time ? I thought it was static like it said 45k miles when new….? The pads do look like they have a lot of meat left on them Last edited by timchump; 11-22-2023 at 04:56 PM.. |
11-22-2023, 04:56 PM | #63 |
Rep 2,876
My god, 3 pages of 'how cheap can I get with my maintenance' on an M-car. Just sell it so that somebody who really cares can take her in and start to treat her right.
11-23-2023, 02:03 AM | #64 |
Rep 71
I have absolutely no problem in getting the maintenance done when it needs to be done
But there are a lot places out there that will take advantage of people with a car like this For example my local dealer said the rears needed to be done to I have had an Indy measure the discs and check the pads, they are less than 50% worn. For the rear brakes service I was quoted £1800 so approx $2160 The front service was quoted at £2645 so approx $3200 My car at the time had 25.5k on it Does that sound right to you ? Every 25k miles All M2 Comp owners are advised to spend $5.4k having brakes serviced Jesus the e90 rod bearings problem is nothing if you have an m2 with 2nh brakes Crank hub fix I don’t know what fuss is about cheap compared to the 25k mile brake service Thanks for the contribution though I can introduce you to my local dealer if you want I’m sure they would love to meet you Last edited by timchump; 11-23-2023 at 02:30 AM.. |
11-23-2023, 02:48 AM | #65 | |
Rep 8,972
If you think you have to be shafted like that to be a "real M owner" then you carry on. |
timchump57.50 |
11-23-2023, 03:17 AM | #66 | |
Rep 8,972
Do you do a lot of town / mway driving? Usually on the made-of-cheese BMW discs the cracking or scoring / rusting will force replacement before wear. My OE discs were scrap at 4yrs / 16K due to bad edge corrosion / flaking and cracks between the drill holes. Last edited by doughboy; 11-23-2023 at 03:23 AM.. |
