M2 Technical Topics > Track / Autocross / Dragstrip > Removing/Reinstalling Seats Reusable Bolts?
      05-17-2022, 07:31 PM   #1
geofff87
I'm removing + reinstalling my seats to install a half cage/roll bar in my OG M2 this weekend. My understanding of the process is to remove the bolts for the sliders, disconnect the battery (and block off the trunk from closing), then disconnect the seat wiring. For reinstall, it seems like it's the opposite.
Does anyone know if the bolts used to mount the sliders are one-time-use, or reusable? If one-time use, does anyone know the part number for them?
I think I read the torque spec on them is around 32 ft-lbs.. is that right?
Thanks!
      05-18-2022, 07:08 AM   #2
CoffeeLife
Coffee Every Day
CoffeeLife's Avatar
397
Drives: 2021 M2C
2021 BMW M2C  [10.00]
I dont have the part number handy but they are BMW M10 x 28 bolts. I reused mine but eventually swapped them out for stainless steel M10 x 30 bolts with a 1T washer. That way I could tighten down with a wrench & socket vs T50 torque bit
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter
-TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox
-Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter
-Remus Race + BR EL Mid
      05-18-2022, 07:11 AM   #3
CoffeeLife
Coffee Every Day
CoffeeLife's Avatar
397
Drives: 2021 M2C
Thats what I did.
-Remove rear two bolts
-Slide the seat center with the door for easier removal
-Disconnect battery
-Remove two front bolts
-lean / tip seat backwards to disconnect harness
- pull seat out
Dont close the trunk while your battery is disconnected
-2021 M2C, HS, 6MT
      05-19-2022, 04:33 PM   #4
geofff87
Thanks!
