BMW M2 Forum > BMW M2 CS Model > M2 CS Racing in person at Daytona
      05-22-2020, 03:07 PM   #67
Megator
Megator's Avatar
518
Drives: M2 Competition
Originally Posted by AlpsRider View Post
Does that kit change the oil pan or just tap into it. I believe the GT4 holds just slightly more oil than the M2C S55.
There are 2 capacity oil pans for the S55.
A higher capacity one on the F80/F81 CS/GTS cars
https://www.realoem.com/bmw/enUS/par...&q=11137838706
Which I thought the GT4 would share but not according to real OEM
https://www.realoem.com/bmw/enUS/par...&q=11137854463
The "normal" pan is the one used for the motorsports cars.
The dipstick replaces the oil level sensor so im sure the car will throw all sorts of error codes if you fit a manual dipstick.
As shown here https://www.realoem.com/bmw/enUS/sho...70#11137854463
      05-22-2020, 03:16 PM   #68
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
Hard to tell from drawings but it appears as if you were to machine out the center of the dip stick piece you could use it to replace the #9 11137857266 spacer ring and bolt the sensor through it as if the dip stick part were the spacer.
So who's going to do the $600+ experiment?
      05-22-2020, 03:28 PM   #69
Megator
Megator's Avatar
518
Ill save someone the cash
The spacer is used on the CS/GTS only not the other S55s.
CS/GTS
https://www.realoem.com/bmw/enUS/sho...19#11137838706
Part 9 has a part number associated to it
Other S55
https://www.realoem.com/bmw/enUS/sho...19#11137854463
Part 9 has a no part number associated to it
Edit: A tuner should be able to code the oil pan level as the GTS/CS one...
      05-22-2020, 03:34 PM   #70
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
CS/GTS
Other S55
Hummm...does that mean #9 is optional on M2C? I have to remove the belly pan to find out, right?
~ $441 delivered + machining to create the hole for the sensor.
      05-22-2020, 03:38 PM   #71
Megator
Megator's Avatar
518
For an M2C you would also need custom oil level SW (the sensor won't be in the same place).
or the CS pan and spacer etc. and a "CS" tune.
      05-22-2020, 03:39 PM   #72
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
It "appears" that they created the dip stick by drilling a hole in the side of spacer and welding the dip stick tube on.
      05-26-2020, 03:46 PM   #73
AlpsRider
AlpsRider's Avatar
2865
It's a nice thought but it sounds like way too much trouble and expense just to add a dipstick.
      09-23-2021, 04:53 AM   #74
M13RSD
Drives: BMW M2 CS
Wondering where these grilles can be ordered and if they fit the CS?
M2CS
