M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > *** Boost/Torque by Gear (% Reduction) - New Map Configuration option - bootmod3 ***
      08-16-2018, 01:52 PM   #1
proTUNING Freaks
proTUNING Freaks's Avatar
4490
Drives: powered by bootmod3
Thumbs up *** Boost/Torque by Gear (% Reduction) - New Map Configuration option - bootmod3 ***
Hey guys, this one's been in the works for some time and we're happy to release it with the 0.10.029 system update.
Many of you can attest to being very hard to effectively put down power even with a Stage 1 OTS map even after going with great tires and setting up suspension and alignment right. We've come up with a simple and easy to use way to help you reduce boost (torque) for any given gear so you can better put it down. 1st and 2nd gear are most often the ones that need some help but we've exposed gears 1-6 for it. Some may even use it to create a low boost map using it as a simple boost tuner
Update is up on bootmod3.net and the Android app store has the update. iOS version is in review as usual and hopefully live in the App Store in the next 24-72hrs.
Let us know if any questions at all
      08-17-2018, 05:36 AM   #2
MTWO
Yasssssss iOS app is up on the App Store!
Tags
bm3, boost by gear, bootmod3
