M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > *** M2 Competition (S55) support now available with bootmod3 ***
      05-30-2020, 01:44 AM   #1013
808elise
808elise's Avatar
Drives: CB E46 and SG E92 M3s
With new tires and more grip im tired of stg2. Finished last of bolt ons today. Time for turbo upgrade and Paul Johnson tune through bm3.
      06-01-2020, 07:42 PM   #1014
n8dgr84
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
174
Drives: M2C - 6MT - Flex Fuel
You are an animal!
What tires did you get?
      06-01-2020, 09:21 PM   #1015
Lotus99
Lotus99's Avatar
628
Drives: 19 M2C & 18 X3 M40i
Originally Posted by S.111 View Post
I was having some issues with the iDrive so when I took my car in for the 25k service, I asked my SA and the shop foreman to look into that. I specifically told them not to update the DME but the service tech decided to just do it anyway, even though it was mentioned on the worksheet. Anyway, my SA was really apologetic. She's been my BMW SA for the last 5 years and I've never had any issues. I asked them to revert it to the older version and they looked into it but apparently they can't so.
I'm thinking about racechip or JB4 but I'm not too sure about running a piggyback.
P.S: That blinker issue is really common. I've had both my tail lights changed. They haven't malfuntioned ever since.
Isn't ProTuningFreaks in your backyard??? Why don't you just drop in and have them bench flash you?
      06-01-2020, 10:55 PM   #1016
808elise
808elise's Avatar
You are an animal!
Toyo R888R
n8dgr84173.50
      06-05-2020, 04:13 AM   #1017
MTWO
Toyo R888R
Other than needing some heat these have been awesome for me!
      06-09-2020, 02:51 AM   #1018
msdss
msdss's Avatar
Drives: Alpine White 2020 BMW M2C
They can only do it if I get the DME off the car and take it to them. I’m not so comfortable with the idea of taking the DME off the car to get it bench unlocked.
you aren't alone...
G80BSM282.50
WVUDrJay262.00
      06-10-2020, 02:01 AM   #1019
Dutch Devotion
Dutch Devotion's Avatar
123
Drives: F80M3 - M2 comp ETA 14.10.2019
When you like to have double security that your stealer (dealer) does not reflash your ecu (thus blocking it) you could install the AK Motion display. You have to physically lock the device (with a PIN code) to allow for OBDII access. So if you don't lock the device, the OBDII access is not grantes and the dealer could no longer reflash. It will have other implications with the dealer, but the no reflash is guaranteed unless you lock the AK motion display.
m20e30871150.00
G80BSM282.50
      06-10-2020, 11:58 AM   #1020
Mdkcrf250r
Can't the dealer just unplug it?
      06-11-2020, 04:52 AM   #1021
Dutch Devotion
123
It's hardwired into the canbus connectors, not a plug in the OBDII connector.
The block goes via the display's signal to/from the ecu, where the display is now in between. Quite clever if you ask me
      06-11-2020, 11:17 AM   #1022
msdss
msdss's Avatar
Then they just void your warranty for modifying the ECU. Lol
G80BSM282.50
      06-12-2020, 01:38 AM   #1023
Dutch Devotion
123
Interesting. I had no idea that we could use the AK Motion display for this.
I am finally going to get the DME unlocked tomorrow and I still have 12000km before my 55k service so I have some time before the next dealership visit. Hopefully the next time I visit the dealership they won't update the software. If they do, I'll think about the AK motion display.
Me neither, till I saw this topic and an additional mail message from Ak irt peepz who've been at my the dealer who had issues with OBDII access.
I do not know wether it is the solution, as I understood there will be no means of access at all meaning no error code look up etc. The dealer will for sure start complaining. But since that is what they always do, why not, I could live with that although it was not the focus for me installing AK (i did it for the OPF delete in the future)
G80BSM282.50
      06-12-2020, 10:01 AM   #1024
Detoxified
Drives: M2C HS
That would be hard to argue. I too installed the AK motion display. It is an in-line wire connection but it does not flash your ecu in any way. Think, exhaust valve controller, same concept but with more features and data reading. You also hook up the M performance LED steering wheel the same way, in line wire connection to the CAN-Bus.
msdss497.50
G80BSM282.50
      06-14-2020, 05:40 PM   #1025
MKParris
MKParris's Avatar
Drives: M3CX
So will BM3 work on a 2020 M2C or is the DME still locked?
Sold: 2008 335i, 2015 M3, 2018 M3, 2020 M2 Comp
Current: 2022 M3 CompX, 2024 M2 6-Spd
      06-14-2020, 06:02 PM   #1026
hAxel
Drives: 2020 M2 Competition, 2002 M3
It works, but you need a bench unlock first. DME is locked, but can be unlocked (just not at the OBDII port.)
      06-16-2020, 12:39 PM   #1027
MyM2See
Drives: 2020 M2C
So I finally got the DME bench unlocked. I had some issues with flashing the car but thanks to the amazing customer support from PTF and the guys at the tuning shop, the issue was resolved within 20 minutes.
The process itself was pretty straightforward. Only the top mount intercooloer needs to be moved aside to access the DME connectors and then the DME can be patched/unlocked via computer. My only concern was that the guys working on my car did not put any covers on the fenders while working on it. The left fender has a few scratches. Nothing that a polish can’t fix.
How much did you pay for the DME bench unlock? Someone local quoted $300, i dont know how far off the prices are.
      06-16-2020, 01:09 PM   #1028
mobile23
mobile23's Avatar
24
Drives: BMW
Where can I find more info and purchase that AK Motion display? Thanks
      06-16-2020, 02:21 PM   #1029
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Local shop here wants 250, seems a bit steep to me for 30-45 mins of work.
      06-16-2020, 03:40 PM   #1030
MyM2See
Drives: 2020 M2C
Agreed. Thank you!
      06-17-2020, 02:44 AM   #1031
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
$250-300 is a bit high for less than an hour of work.
...the indy shop I use quoted $250 for the removal and installation of the DME so $300 for everything was not too bad.
Exactly, it's not just an hours labour you have to consider - it's their skills and costly equipment, local competitors and how much alternative options cost and what they think its worth to you.
G80BSM282.50
      06-17-2020, 04:01 AM   #1032
fordnox
Drives: n54
http://datadisplay.store
      06-17-2020, 02:15 PM   #1033
mobile23
mobile23's Avatar
24
Drives: BMW
Originally Posted by fordnox View Post
Thanks... But unfortunately they don't ship to where I'm
      06-17-2020, 11:29 PM   #1034
Detoxified
Drives: M2C HS
I ordered mine through burkhart engineering. Maybe try them?
Edit: I'm located in the US and there were no customs issues for me. Not sure about Canada..
Tags
bm3, bootmod3, m2 competition
