02-10-2018, 03:32 PM | #1 |
4490
Rep 1,862
Drives: powered by bootmod3
bootmod3 Offline Flasher Release ***
Hey guys, really happy to announce the OFFLINE Flasher is now out of closed beta for any existing registered/unlocked users that have an S55, N55, N20 or N26. Only exception is Dual DME cars (N63tu/S63tu) that are still in beta for a couple days. This applies to any existing and already unlocked BM3 users.
Overall impressions from beta have been very positive. Flash times are the fastest out there we've seen at just 40secs for a map switch, maybe even a touch quicker. Offline flasher also incorporates a preconditions analysis check we believe is unique to bootmod3 in the aftermarket along side BMW's own factory flash tools. Some of these were there before but now have been redesigned and further expanded. This should help prevent any issues for those out in the wild while flashing further solidifying the flash process. In case any the following preconditions happen, flash will not begin: - engine running - immobilizer system not unlocked - gear box input speed not zero - gear box output speed not zero - vehicle speed not zero - ignition needs restart, ignition off-on is required - programming voltage insufficient - ignition off (clamp 15 is off) - vehicle's electrical system voltage too low - temperature too high - temperature too low Flash button in the app now defaults to OFFLINE flashing. The old method which used an internet connection to the servers is still there but going forward will most likely be removed for the DME. S55 TCU flash will continue to use the internet connection method, for now. We'm working on incorporating some progress bars for the flash progress screen now and that'll be in the next update very soon. OBD Unlock closed beta testing is going really well as well and we're hoping to have that released in the open very soon as well. Let us know if any questions. |
02-11-2018, 07:09 AM | #2 |
Rep 2,354
Here is how it works
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
03-02-2018, 12:46 PM | #4 |
Rep 2,577
Tried offline today. Worked fine!
Who has and would share a log of latest OTS on N55 EWG STG2 93OCT? Want to check and compare.
Lemania 2320
03-02-2018, 03:44 PM | #5 | |
IG @bmwF9xG80
3812
Rep 7,593
His version was on 0.9.48 and we're now on 0.9.76 thought you would be making one for the M2 folks
60-130mph 6.5s X4M #HCP
03-05-2018, 11:10 PM | #7 |
IG @bmwF9xG80
3812
Rep 7,593
Its out already see their FB Group its in closed-beta but its working my friend abirmaher just did it on his stock M2 in FL a few days ago
03-06-2018, 12:17 AM | #8 |
Rep 752
03-06-2018, 07:32 AM | #9 |
IG @bmwF9xG80
3812
Rep 7,593
You and another 1000s have message them lol vs 2 of them imagine that
https://www.facebook.com/groups/1995370330682747/
03-06-2018, 07:49 AM | #10 | |
Rep 4,203
FSociety3811.50 |
03-07-2018, 01:41 PM | #13 |
Rep 105
The website is stating that OBD bench unlock is no longer required on both the bench unlock service page and the bootmod3 product page for N55 platform. Is this the case or is it still just in closed beta? I know it's already been asked, but I'm just curious as to the language on site. I would rather hold off until it's freely available before I place and order for a license.
Separate question: I know that during beta testing it's required that you have a Windows laptop. If/when its out of beta, is it possible to use an iOS laptop for flashing/logging, or is it only available for iOS mobile app?. Thanks in advance. |
03-07-2018, 01:48 PM | #14 | ||
IG @bmwF9xG80
3812
Rep 7,593
Only thing they HIGHLY HIGHLY recommend for First Time is Battery Charger Hooked up because S55 especially drain the battery while in ignition. So if you're in a cold climate or barely drive your car its highly recommend to have your car battery hooked up to a minimum 20amps charger
03-07-2018, 01:54 PM | #15 | |
Rep 105
I have an M2, so N55. Is this still the case with the external battery charger? |
FSociety3811.50 |
03-07-2018, 03:04 PM | #16 | |
IG @bmwF9xG80
3812
Rep 7,593
03-07-2018, 04:46 PM | #17 | ||
Rep 2,363
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
FSociety3811.50 |
03-07-2018, 05:34 PM | #18 | |
Rep 2,577
Always always have a power supply when you flash, even if you don't bother plug it in.
Lemania 2320
03-08-2018, 08:30 AM | #20 |
Rep 1,467
I have the "BMW advanced charging system" charger. Will that work? Its a 4 amp trickle charger i believe.
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
03-08-2018, 10:00 AM | #21 | |||
Rep 2,577
Log it anyway. I may have a look if you don't mind
Lemania 2320
03-08-2018, 10:03 AM | #22 | ||||
Rep 2,363
Follow my builds:
Tags |
bm3, bootmod3 |
