03-07-2019, 12:30 PM | #1 |
721
Rep 364
Bootmod3 M2 OTS map update - Version 5.6
So I finally had some extra time with an M2 DCT to get some 100-200km/h times.
I ended up getting 8.8-9.1 seconds on 93OCT (98RON) with catless downpipe and intercooler. So I decided to update the OTS maps with the newfound changes for this car All maps are updated, including the E30 and Racegas map! Version 5.6, March 7 2019: - Power increase - Revised boost control - Revised ignition advance Power is increased (not dynod) only dragy and vbox. Approx half a second faster 100-200km/h Boost control is changed so the M2 turbo can give a big midrange punch and still make power at high RPM. Ignition advance is slightly improved at high RPM for the 93OCT maps over stock. Last edited by Halim@HCP; 03-07-2019 at 01:20 PM.. |
12
BostonM235xi130.00 ZM22810.50 nioh_lbbm21716.50 M-Supra394.50 akkando5863.00 JKen_0115176.50 SeanWRT3179.00 JTO245274.50 JackyStuntin154.50 FSociety3812.50 Fuman23.50 Thevesh30.50 |
03-07-2019, 02:06 PM | #2 | |
Rep 415
I plan to revisit the same dyno to get a new power figure and compare the delta 👍🏻. I wouldn’t be surprised if a quicker time is possible on the 93 map. Comparing to other cars that run 8.4-8.6s 100-200kph, from 100-170kph the times are exactly the same. My car just falls a little short over the last 30kph, might need to experiment with shift points etc. Everyone will enjoy going from v5.5 to 5.6 👍🏻 |
ZM22810.50 |
03-07-2019, 02:08 PM | #3 | |
Rep 6,635
Nice! Should I expect anything on the Stage 1 91 octane map? |
03-07-2019, 04:31 PM | #4 |
24160
Rep 190,725
Nice!
03-07-2019, 05:55 PM | #5 | ||
Rep 309
03-07-2019, 05:57 PM | #6 | |||
Rep 6,635
03-07-2019, 07:18 PM | #7 |
Rep 1,899
I just flashed stage 2 91 5.6.
I previous was v5.5 but I only had it for about 1 day so I couldn't notice a difference power delivery wise. Only thing I immediately noticed was that burbles seemed more mild. Not sure if that was touched or not. If v5.5 was a 6/10 v5.6 seems like its a 4.5 or 5/10 (aggression-wise in my personal opinion) I went to custom burbles to bring it back to as close as I could to v5.5 Maybe Halim@HCP Can comment if it was changed or maybe I'm just crazy lol |
03-07-2019, 08:54 PM | #8 | |
756
Rep 2,149
nioh_lbbm21716.50 |
03-07-2019, 09:33 PM | #9 | |
Rep 1,899
I put aggression at 5.8 and it seems to be pretty close. Might be a tiny bit stronger but hard to tell like you said sometimes when its colder it's really aggressive. I put duration at .7 seconds on sport and 1.2 secs on sport+ just as a personal preference. I think default OTS is 1.0 secs? |
03-07-2019, 09:48 PM | #10 | |
756
Rep 2,149
Since the accident, I had my car for a total of 2 weeks. I couldn't even tell the difference after the coilovers and swaybars were installed haha. And I don't wanna drive too hard without the Xpel cause all the gravel they put on our roads for winter. |
nioh_lbbm21716.50 |
03-08-2019, 07:23 AM | #11 | |
Rep 2
I Had Duration to 2 sec sport and 3 sport plus and aggression to 5 in sport and 6 in sport plus . any suggestion on how bad it can be if longer duration ? im getting some made pops and bangs |
03-08-2019, 08:57 PM | #14 |
Rep 523
First impressions are where have the burbles gone! throttle is a lot more responsive and that's how comfort should've been but tbh I do find it to be too aggressive in sport.
Engine keeps revs up off throttle more than v5.5 or it could be the lower burbles that are causing me to be sensitive to the revs staying up. My 6 yr old daughter noticed the car being louder and wasn't too impressed She does pull better up to red but I was only able to pull second and that too traction limited being -5C outside with a crap load of salt on the roads. Will mess around with burbles to get them back All in all I do like it and it does make you want to push her even more. Not that she needed any more of that characteristic
18 M2 6 Spd AW - VRSF DP / CP & Race FMIC, ER TIC & GFB DV+ with BM3 Stage 2 Retired 09 135 JB4 G5 ISO w/BEF, N54 Tuning Performance DPs, BMS DCI, ER Charge Pipe |
03-08-2019, 09:40 PM | #15 |
Rep 3,695
Tried it with my Dinan turbo tonight. Feels good. Midrange def feels stronger.
Burbles are less, will give it a couple days to adapt and crank them up under Custom if the burbles don’t come back. Will work on a 2H version of v5.6 after I put on a sport cat. Last edited by ZM2; 03-08-2019 at 09:49 PM.. |
03-08-2019, 09:53 PM | #16 |
Rep 1,899
I tried doing custom burbles and something happens to comfort mode to where comfort mode burbles are super loud compared to sport. I don't know why comfort even has these burbles. deleted the tune and re-downloaded and did custom burbles once again and same thing. Something is definitely off with v5.6
I went back to v5.5 |
03-08-2019, 10:16 PM | #17 |
Rep 25
E30 similarly improved? Feels good either way.
It's not conclusive but at the same time as flashing I changed sport burbles to zero and sport+ to 5.8. Bubbles didn't work at all on either settings, dragged sport up to match sport+ and does work now but not as aggressive as before flash. Last edited by Fatkat; 03-09-2019 at 03:43 AM.. |
03-09-2019, 09:58 AM | #18 | |
756
Rep 2,149
03-09-2019, 07:59 PM | #20 |
756
Rep 2,149
Even with the changes, burbles were still weak. So I went to the Stg2 Agg 93 tune and they are similar to the Stg1 93 v5.5 burble again (though I think still a little less aggressive)
03-09-2019, 08:04 PM | #21 |
Rep 10
Anthony, can you log in again and see if your map has the 'has update' flag? Curious to know if you flashed the same version as me and hence have an update, or if you flashed the updated version.
03-09-2019, 08:16 PM | #22 |
756
Rep 2,149
Yes. v5.6 Stg1 93oct has a "has update" next to it for me. But the Stg2 93oct and Stg2 93oct AGG do not.
