02-02-2020, 01:50 AM | #441 |
Rep 1,485
i barely fit my 5.5inch csf intercooler in my m2...i think a 6inch would be really pushing it, no way a 6.5inch would fit without removing the front braces.
02-10-2020, 08:18 AM | #442 |
Rep 19
Question...I am planning on my M2 daily use, stage 1 (currently stock) and will most likely only get an exhaust system (not even downpipe)..Will you recommend to upgrade IC and charge pipes?
If so,which brand, size and why? Car is 28k km, I live in Italy so I get the chance to fuel with 98/100 octanes |
02-10-2020, 11:16 AM | #443 | |
24095
Rep 190,633
02-11-2020, 10:27 AM | #444 |
Rep 19
02-11-2020, 10:48 AM | #445 |
Rep 699
02-11-2020, 11:05 AM | #446 | |
24095
Rep 190,633
Both these options are 5" , high quality intercoolers. Other options include VRSF 5" & Active Autowerke
02-12-2020, 05:08 AM | #448 |
Rep 1,389
Litchfield tuners in the UK use the forge intercooler, it's not a stepped design. I think it relies more on increased fin density than anything else and better flow design but don't quote me on that.
02-12-2020, 07:12 PM | #449 |
Rep 1,644
02-12-2020, 07:28 PM | #450 |
24095
Rep 190,633
Either one would work. If you live in a warm weather are, i would get the EVO II
03-03-2020, 12:38 PM | #451 |
24095
Rep 190,633
VRSF F chassis Intercooler
03-03-2020, 07:45 PM | #453 |
24095
Rep 190,633
03-03-2020, 11:54 PM | #456 |
24095
Rep 190,633
it depends on your mods, if you are running stage 2 maps I recommend a 6" intercooler
03-04-2020, 06:28 AM | #457 |
1448
Rep 1,414
03-04-2020, 07:58 AM | #458 | |
Rep 4,130
ER - the prior best intercooler. You don’t hear about it much anymore, but I’ve never seen anything bad about it, or anything compared to it really. VRSF 6.5 and/or Race - Not sure this is the same, but these just get things done. They are old school. No rounded end ranks, or fancy design. It’s straight up big and that’s how the job gets done. It’s also cheaper. ATM/CSF - I’ve read a ton. The most track worthy, holds records for fastest N55 (until recently I believe - I’m tired, I was up all night reading) the ATM should flow better and have less lag than the CSF, both are better than the Evo 2 from every test I’ve seen. Also cheaper. Why not: AA - too small. (Goes for all 5”cores) eBay - Garbage Wagner - Evo 3 has no test, the Evo 2 is outright inferior to the others mention in absolute cooling. Even the claimed faster recovery doesn’t measure up on the track where it heats up quicker and higher than the rest, and it’s smaller meaning it’s absolute ability to hold heat is lower. Do88 - same as the Wagner. It’s better in terms of absolutes keeping temps, but it was 5* vs 10* or so for the ATM/CSF. No reason to buy this over the other more capable options. |
243Racing1447.50 |
03-04-2020, 08:19 AM | #459 | |
1448
Rep 1,414
03-04-2020, 08:59 AM | #460 | |
Rep 4,130
243Racing1447.50 |
03-04-2020, 09:18 AM | #461 | |
Rep 3,695
I’ll also make the same comment here that I did on the F30 board. Point is, the best IC for someone is the one that has the best blend of characteristics for their use, not just cooling capacity. For me, a 10F IAT improvement isn’t going to make much of an impact for guys running Emixes on track. I wouldn’t trade to a 5-10lb heavier IC with worse throttle response to gain what would only be a few hp on an Emix tune on track. If you run 93 octane on track, then the 10F difference will be noticeable on hot days. To get a 20F+ difference over the Evo 2 Comp we’re talking about needing a massive IC, all of which are going to be 30lbs+. I haven’t seen that any of the massive bar/plate IC’s have that kind of performance gain without making lag even worse. Apparently the Evo 3 achieves all these things from Wagner’s data, but no one knows why it will fit the M235i and not the M2. Last edited by ZM2; 03-04-2020 at 09:36 AM.. |
243Racing1447.50 |
03-04-2020, 10:17 AM | #462 | |
2093
Rep 43,350
Please stop spreading mis-information. The VRSF 6.5" Competition HD along with the 6.5" Race FMIC were both designed using CFD analysis and both incorporate incredibly efficient cast end tanks. The fin packs were specifically engineered to provide the best balance between external cooling and internal flow. There's nothing old school about our intercoolers
The VRSF 6.5" Race will outcool EVERY intercooler you've listed and it's currently featured on both the fastest N55 powered car along with the highest horsepower. It's less expensive because we don't slap on a BMW tax like the other brands mentioned. Quote:
Here's another set of logs from a customer who upgraded to the VRSF 6.5" Race FMIC from the Wagner Evo 2. He was seeing a 75 degree increase (37F - 112F) with the Wagner Evo 2 on a 2-5 gear pull where the VRSF only saw a 39 degree increase (50F to 89F). Last edited by Tiago@VRSF; 03-04-2020 at 10:37 AM.. |
