09-25-2021, 11:01 AM | #1 |
Rep 147
Black hexagon mesh from customcargrills.com.
Then our own 3D printed snorkels from commander Wiggins. I'll throw up some after pics when the sun is better this afternoon. Pics should be in reverse order |
9
(K)1278.00 .Slug447.00 Foggins1334.50 Kingpin4386.50 RocketBoots1860.00 Commanderwiggin2050.00 Detoxified204.50 GreyRS57.00 inTgr8r2431.50 |
09-25-2021, 03:23 PM | #4 |
Remove Before Flight
6822
Rep 1,611
Wait. Hold on a sec.
I was juuuuuust about to hit the link for the mesh material that some peeps have used, and now I'm seeing this. Looking at the website, I don't see any links for BMW, so I'm assuming you're using generic mesh and putting some edging around it? If that's correct, which edging and mesh pattern did you use? And? Pictures from the front of the grill? TIA-- holding off on my Amazon purchase because of this! R.
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
Dr.Mark84.00 |
09-25-2021, 04:01 PM | #5 | |
Rep 95
Drives: BMW M2C
09-25-2021, 06:28 PM | #6 | |
Rep 147
For the bottom 3 grills I mounted with zip ties from the inside to the OEM grills. 4 for each side grill. 6 for the middle. You can't see them unless you really stick your head up close. For the kidney grills, I actually drilled 4 small holes each side in the back half of the grill in between the slats and in the appropriate places since the grill is not flat but has a bend/twist to it. Again almost invisible from the front. Interestingly from a distance, you can't see any of my hard work. Annoying but really what I wanted. I'm headed to the track in 3 weeks so I think the screens are necessary. The total for the screens was about 2 hours. I was meticulous with fitment. You can PM me if you want any more specifics. I've never done anything like this before but jumped in and am proud of how it turned out. Very doable. |
09-25-2021, 06:35 PM | #7 | |
Rep 147
09-26-2021, 07:01 AM | #10 |
Rep 147
09-26-2021, 09:04 AM | #13 |
Rep 62
09-26-2021, 12:08 PM | #14 | |
Rep 147
I made the grill cutouts just slightly smaller then the opening. The rubber edging adds about 2mm. So then when I zip tied it down, there's no chance the edging could work it's way off. And secondly the metal grill can't rattle or scratch anything! |
09-28-2021, 09:20 AM | #16 | |
Rep 249
Looks great! |
09-28-2021, 08:56 PM | #17 | ||
Rep 147
ROASTM163.50 |
