01-23-2021, 04:30 AM | #67 | |
Rep 9,709
OE wise, the F80/2 carbon driveshaft weighs in at 7.76kg vs around 8.85 for a steel one. I would expect an aftermarket CFDS to be lighter than an OE CFDS, maybe 7.0 dead? So marginally bigger gain for the aftermarket version. I really don't understand the delay in moving this project forward. The manufacturer is surely only limiting a batch size to 15 to cover his R&D figure. If 10 are interested, then just group the 15 cost together and be done with it. Or collectively buy 15 and put the excess ones in the for sale section. Many folk would like to buy one, but know the flaky nature of group buys, so won't get involved. Different proposition to a ready to roll item. Alternatively, go local and get an aluminium one done. Similar weight, smaller cost. |
DrKevM52273.50 |
01-23-2021, 07:45 AM | #69 |
Dom
1078
Rep 1,714
That would be quite helpful. I honestly didn't do it because I wasn't trying to spam it all over the place. Thank you.
02-04-2021, 05:35 PM | #70 |
@333m2c
229
Rep 177
Drives: 2020 M2c f87 S55
Im in. Just making sure this works for DCT; never changed a drive shaft before.
@333m2c / Willing to sell my soul for parts..
Build thread: "Going for Broke - a Saga" https://f87.bimmerpost.com/forums/sh....php?t=1805010 |
ebisu81078.00 |
02-09-2021, 06:39 AM | #72 | |
Rep 744
To the ppl saying this is so amazing and your really gonna feel it. I call BS. Why cause 1) the EU spec M3/4 acceleration did not change when they went from a CF to steel drive shaft due to the OPF and 2) I could barely feel a 10kg rotating mass reduction on my 130 engine hp 1 ton Miata. Will it make you faster? in theory yes, accelerations will be .01% faster. Should it be high up on your list of weight reductions? No, I dont think so, similar amounts of rotating mass can be removed from the wheels/brake discs which also help reduce un-sprung mass. That is all. ebisu8 hope you find your last buyer and good luck delivering the product.
DrKevM52273.50 |
02-09-2021, 07:29 AM | #73 | |
Dom
1078
Rep 1,714
BUMP for the last spot and I welcome anyone else that wants to get in on this as I know some of the already committed will de-commit on this group buy. |
02-10-2021, 02:36 AM | #75 | |
Rep 744
BTW mass is only part of the story, the aim is to reduce the moment of inertia. https://en.wikipedia.org/wiki/Moment_of_inertia The equation for moment of inertia for a hollow cylinder is I = 1/2 M*(R1^2 + R2^2), where R1 and R2 = the radius of the cylinder (inner + outer) or (1/2m*r^2 for thin walled cylinders) https://efcms.engr.utk.edu/ef151-201...lass-4-3&p=mmi Note that the radius terms are squared!!! so not only should the drive shaft weight go down but the diameter/radius of the drive shaft must stay constant. If the radius goes up the moment of inertia change might be a wash with the weight loss. Doing some back of the napkin calculations a 1kg weight reduction (10 to 9 kg) for a 10mm radius increase, results in a mini increase of the moment of inertia...
