07-21-2021, 10:22 AM | #45 |
Rep 221
Not sure why you guys want all the shock running through your driveline when you pack gears on a 6MT - thats the job of the CDV. Great device, most manual drag cars and track cars run them.
Guess this is a good mod if you baby your car and putt around? |
07-21-2021, 01:34 PM | #46 | |
Rep 5,369
1) Buy a new from BMW for $5000 2) Buy a remanufactured one from BMW for $3000 3) Find a used one With all that said, the CDV does impact driving with these 6MTs. I've been driving manuals for three decades and I find the CDV very frustrating after 5.5 of ownership. It's my biggest issue with an otherwise amazing driving M235. The CDV makes smooth take offs and shifting the 1-2 and 2-3 somewhat difficult. You can feel the CDV's annoying operation by simply shifting and releasing and holding the clutch pedal just to wear it starts to catch While holding the clutch pedal in the same position, all the fluid finally pushes through CDV and the clutch engages while the pedal has not moved. It's odd and inconsistent flow of fluid is why the clutch pedal catch point can vary somewhat thus why it makes smooth driving difficult.
F87source7245.50 |
07-21-2021, 01:56 PM | #47 | |
Rep 7,422
The worst part is no serviceable parts.
07-21-2021, 08:54 PM | #48 | ||
Rep 485
07-21-2021, 10:05 PM | #49 |
Rep 7,422
Nope, no synchros, no gears, no input or out put shafts nothing. Just drain and fill plugs and the shifter carrier and maybe linkages but nothing in regards to the internals.
Maybe someone can contact zf and see if they'd be willing to sell some stuff.
09-16-2021, 05:38 AM | #50 |
Rep 553
A few days ago I removed the CDV and have to say I'm pleasantly surprised with the level of improvement (as most have described). The bleeding issues were the main reason I'd held off but after recently seeing a diy video on how to easily remove the CDV while leaving the slave cylinder in situ and being in lockdown I thought I would give it a go.
Once the car was on stands & splash panel off it was literally a 15min job to disconnect line from slave cylinder, remove the CDV & re-connect the line. The video is linked elsewhere on this forum but here it is again: My first effort to bleed with a Motive Pressure Bleeder failed with a lot of air getting in the clutch line. I independently fill the reservoir (rather than waste expensive racing fluid going through the Motive that I also have to clean up afterwards) & didn't appreciate how small the clutch chamber is inside the brake reservoir!. I then filled the reservoir to top of the fill neck, with pressure bleeder at 10-12psi released bleed nipple just enough to get fluid flowing then closed it when (I guessed) reservoir level was down to around the 'max' mark. Repeated that process 4 times and I had a perfect pedal. If only I had done this 1st time This is without doubt the best mod for $ spent that I've done to this car. |
4
