10-15-2021, 10:35 AM | #89 |
Rep 504
buckybadger1389.00 rwemersonrw535.00 |
10-16-2021, 03:32 PM | #90 |
Rep 115
There were several m2/m2c/m2cs/m2csr on summit point main circuit with BMWNCC. We took advantage on club racing weight and actually compared the weight difference between m2s.
Big surprise is m2cs is only 80lbs lighter than m2c. Both stock manual and about half tank gas. 3587lbs: DCT M2C (no stock seats, Half cage, bucket seats, Apex ec-7 wheels, half tank gas) 3563lbs: Manual M2C (everything stock, half tank gas) 3479lbs: Manual M2CS (everything stock, half tank gas, no picture) 2845lbs: Manual 135i (no interior, no stock seats, bucket seats, half cage, half tank gas) I'm in the black m2c and documenting on/off track. Ins: @blackonblack_m2c. |
D22M21372.50 JustDrifting232.00 |
10-24-2021, 02:43 PM | #91 |
Rep 636
Drives: f32 430ix & 982 GT4 PDK
GT4 RS MR with the cf bucket seats, 3200 lbs or so
04-18-2022, 01:50 PM | #92 |
@333m2c
229
Rep 177
Drives: 2020 M2c f87 S55
Have successfully taken a little more than 200 lbs out of the car.
Antigravity battery No rear seat Recaro pole position seats (driver and passenger) AP racing brakes (front only) suveneer aluminum hood AA Single mid pipe / remus exhaust I also track at 1/2 tank of gas or less going out at full tank makes no sense to me. Getting to the 300 lb + weight reduction isn't going to be cheap unfortunately. I'll be fully gutting behind the b pillar soon. Looking at carbon trunk and carbon fender options as well its just expensive as shit.
@333m2c / Willing to sell my soul for parts..
Build thread: "Going for Broke - a Saga" https://f87.bimmerpost.com/forums/sh....php?t=1805010 |
4
04-27-2022, 12:37 PM | #93 |
Rep 699
Check out the new apex wheels VS5RS 19s. I ordered a set, shaves around 25lbs in rotational mass over stock.
2021 M2C HS DCT
2007 Wedge 335i E92 FBO, Stage 2 LPFP,VTT STG 2+, VTT Shotgun E50 w/ Inlets MT-SOLD |
dead.pixel103.00 |
01-29-2023, 11:05 PM | #94 |
Rep 436
I would think that even if you dont feel the difference your car components will. Brakes, engine, tires working less means a slighting better life expectancy haha
09-19-2023, 11:14 PM | #96 | |
Rep 1
Drives: 19' M2C
I might take out the rear seats as a DIY, and also to replace the oem front seats with recaros then I will focus on upgrading the brakes and suspension Then, I would save up for more weight reduction mods with getting a CS hood, AA EL midpipe + backbox, and a set of Apex wheels later |
09-20-2023, 02:14 PM | #97 | |
Rep 2,505
09-20-2023, 02:16 PM | #98 |
@333m2c
229
Rep 177
No issues it just needs to be coded in properly
09-20-2023, 02:32 PM | #99 |
Rep 2,505
Coded meaning you have to register is properly or you mean you have to code it in expert mode, or normal mode using BimmerCode, etc.?
2011 BMW M3 Sedan Alpine White Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD** Last edited by chmura; 09-20-2023 at 02:49 PM.. |
09-20-2023, 02:46 PM | #100 |
Rep 929
Means just registering it using BimmerCode or similar apps
have to switch it to Lithium option and input appropriate spec numbers of the battery (amp hrs etc) - very easy to do, just pick the right options
and dont use the same charger for the batt as the one for stock! Need lithium charger
09-20-2023, 04:29 PM | #101 | |
Rep 2,505
Thanks!
09-21-2023, 05:10 AM | #102 |
Rep 1,333
09-21-2023, 09:32 AM | #103 |
Rep 2,505
Got it, thats what I thought there is no option for lithium so then its not coded in properly?
09-21-2023, 12:47 PM | #104 |
Rep 4,668
Which liteblox model are you using?
09-22-2023, 10:15 AM | #105 |
Rep 1,333
LB28XX
Before buying Liteblox battery I tried an M4 battery without IBS, it doesn't work, with LiteBlox I don't have any problems. Last edited by Track/S; 09-22-2023 at 12:09 PM.. |
medphysdave4555.50 |
09-22-2023, 11:28 AM | #106 |
Rep 2,189
Hello, I am using the Antigravity 80Ah (H8) battery in my F87 M2C and have no issues with battery warnings. The reserve capacity is sufficient for infrequent use.
In conjunction with 18" forged wheels, AP front brakes, and a rear seat delete, the combined ~150 pound weight reduction transformed the responsiveness of the car. The difference in braking and acceleration are most obvious; the engine does not need much boost to accelerate briskly around town. |
09-22-2023, 11:43 AM | #107 | |
Rep 4,668
EDIT: looks like AG batteries not included. MAP items excluded. I'm noticing more than one battery group and size being recommended for our cars. Is there a cross reference? H7 group 94R, H6 Group 48, H7 group 48.
09-22-2023, 01:14 PM | #108 | |
Rep 2,505
09-22-2023, 01:18 PM | #109 |
Rep 2,189
09-22-2023, 01:19 PM | #110 | |
Rep 2,189
