M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Quickjack for lifting
      04-16-2020, 10:25 PM   #23
shadow135i
shadow135i's Avatar
Drives: 2020 M2C
I use mine for aftermarket installs and routine maintenance (oil changes mostly). I love it because I can get my car up in the air in about 2 minutes. It's so effortless now that I don't hesitate to put it up in the air if it'll make a job easier. I leave it down and pushed together underneath the car and just park over it when I pull in my garage everyday. That's also another big benefit for me since there is less to put up when I'm done with a job.
2020 M2 Competition 6MT
2018 M550i xDrive
2009 135i
      04-21-2020, 02:25 PM   #24
dtmurf
dtmurf's Avatar
482
1996 BMW 318is  [4.75]
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
Use mine for everything including washing and drying the car. It's a life saver if you have back or knee issues.
'17 M2 DCT Long Beach Blue
jefe2000739.50
      04-21-2020, 02:31 PM   #25
Nezil
Nezil's Avatar
1404
Drives: LCI '18 6MT M2
I do use it from time to time to remove the wheels to clean them fully as well as the callipers and arch liners.
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods:
      04-25-2020, 05:32 PM   #26
CLH
CLH's Avatar
Drives: 2018 M2 LBB 6MT
I use mine for wheel/tire changes (stock wheels to auto-x set and back), oil changes, cleaning, etc.
I took a similar approach as one of the folks above and mounted heavy-duty hooks to a 2x6 bolted to wall studs and just hang them up when they aren't in use.
Cheers
Chris H. - In the sunny PNW!
My handy Speed-in-Gears calculator
bentom2335.50
dtmurf481.50
Mark 1M348.50
      05-15-2020, 01:03 PM   #27
tenkies
Drives: 2017 M2 LBB 6MT
For Anyone looking to get one. Costco is having a $200 off sale that ends today. I just picked one up
      06-07-2020, 07:32 PM   #28
Commanderwiggin
Commanderwiggin's Avatar
2050
Drives: M2C - X3M - Turbo E46 M3 - 45E
I ended up getting a 5000slx 12V Quickjack the other day as Costco had a deal and I got a pricematch.
Now time to swap over the RE71R's and get started on suspension parts one of these days. Still waiting for my coilovers. Maybe two weeks if shipments start rolling through.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration
1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder
dtmurf481.50
      06-08-2020, 04:26 PM   #29
tenkies
I just received mine last Thurs. They seem to be on backorder and took an extra two weeks for delivery. I got all the hoses and such attached and set up. Just waiting on my new air compressor and Hydraulic fluid. Set up so far was fairly easy.
      06-09-2020, 02:34 PM   #30
Detoxified
Drives: M2C HS
Set mine up recently as well. FYI you can use a bike pump instead of a air compressor. Also I noticed the air tanks loose pressure over time as expected and should be check prior to using each time.
jefe2000739.50
      06-09-2020, 03:05 PM   #31
tux2005
234
Drives: 2017 M2
Actually, the air cylinders are only really needed when you are bedding in the QuickJacks. I had also been frustrated with 1 frame never holding air for longer than 24 hours while the other would usually hold for a week or so, when I reached out to support they told me to not bother with them anymore. For the last 2 years of use I haven't checked or filled up the air cylinders anymore, they are only needed for getting the frames to fully lower/collapse and the frames do completely lower for me without issue.
Also, quick tip, if you ever struggle to connect the hydraulic lines into the pump unit because the quick-connects are solid, just press the "down" button on the remote. Usually after disconnecting the lines there'll still be pressure built up in the pump unit that makes reconnecting the lines very difficult so simply release it with the remote.
      06-12-2020, 03:59 PM   #32
tenkies
Good to know. Unfortunately I only have a crappy $3 ball pump and that's not going to cut it. I need the compressor for the air tools and small paint jobs so not a big deal.
      06-12-2020, 04:24 PM   #33
JustinHEMI
Not great. Not terrible
JustinHEMI's Avatar
7445
Drives: 2024 BMW X3 M40i
I bought the 7000ext for my Challenger and truck. I'm looking forward to using it with my M2.
Current: 2024 BMW X3 M40i.
      06-22-2020, 03:00 PM   #34
tenkies
Just finished putting together my QuickJack this weekend. 3 things that people that get one should know
1. Bleeding air out will take a couple of times to do
2. Make sure you have the same amount of air pressure in both canisters if one is off a bit from the other they will not raise and lower at the same rate
3. Remember to keep the valve screw open on the pump reservoir when operating the unit.
jefe2000739.50
      06-24-2020, 05:45 PM   #35
Midtown2020
Drives: 2020 M2C (6MT) & X3MC
Unhappy
When you try it out on your M2, can you confirm for me that it works in the normal orientation, just like you use it on your Challenger? I was under the impression that it would be too long to fit between the tires and that the lifts would have to oriented perpendicular to the normal orientation, meaning one lift dedicated to L&R Front lift points and one lift dedicated to L&R Rear lift points.
I've been looking to get a 7000 because it is the only one that works with an X3M, but I wasnt excited by rotating it 90 degrees to use on my M2
      06-24-2020, 06:05 PM   #36
JustinHEMI
JustinHEMI's Avatar
7445
Will do! I want to swap brake pads so it will be soon.
      06-24-2020, 06:38 PM   #37
Midtown2020
I hope I'm wrong and it fits. It appeared to me that it was very tight but may just work...
      06-25-2020, 03:04 PM   #38
JustinHEMI
JustinHEMI's Avatar
7445
Out of curiosity, I measured the QJ at 76" then measured between the tires at the points where I think I would need room to fit it and there's 83"-84" so it should work fine assuming the car's lift points are within the range of adjustment of the QJ which I don't see why they wouldn't be.
Definitive test possibly tomorrow afternoon, but definitely this weekend.
      07-09-2020, 07:18 PM   #39
JustinHEMI
JustinHEMI's Avatar
7445
I realized that I forgot that I owed an update on the 7000EXT.
It fits! That said, the lift blocks have to both be at their minimum spacing, but plenty of contact on the cars pads.
Don't know if the pictures show up well, this is all from my phone in the garage right now.
bentom2335.50
      07-09-2020, 08:07 PM   #40
j0oftheworld
j0oftheworld's Avatar
109
Drives: 01 S2k, 20 M2C
Love mine! Works on my S2k and M2 well.
      08-13-2020, 07:24 PM   #41
Mavallone
Mavallone's Avatar
Drives: BMW 328Xi, Tesla Model 3
Originally Posted by chief1richard View Post
Originally Posted by aeroglava View Post
I've seen a few threads on here about the Quickjack system and how everyone likes it. However, I'm trying to see the reason for using it? Obviously on most vehicles it would be good for rotating tires, but on an M2C there's no need for that. For oil changes, I already have some nice race ramps for that. If someone has or uses the Quickjack for their M2, what are you using it for on a regular basis (not just a one time need)? Thanks!
Used mine for Down Pipe and Charge Pipe install as well as Intercooler install. Have used it for oil changes, and switching out Oem to Track Pads. Will use it soon to install Autosolutions Short Shifter, which requires removal of Stiffening Brace and Drive Shaft and Exhaust. Worth it in my experiences. I feel much safer under car with this lift. and allows a good amount of room to work with. Would love to have a full lift in my garage, but there is no headroom for one.
Chief-
I came across your post by accident, but was very intrigued by your comments on a self install of the Auto Solutions short shifter kit. Your post was a while back, did you do the install? Was it difficult?
      08-13-2020, 09:19 PM   #42
chief1richard
chief1richard's Avatar
2018 M2  [0.00]
Originally Posted by Mavallone View Post
Chief-
Yes, I did the install with my Quick Jack.The Auto Solutions install was not very difficult. Just a lot of work overall.Intermediate mechanic skill should be all it takes. There is a lot of information, and video on how to do it on the M2 Forum. Anyone with good wrenching skills can do it.Taking off undercarriage panels and partially removing Drive Shaft are half the work. Not difficult at all. It was by far the best Mod I did with my M2. Everytime you shift you can appreciate the effort of installing it.
At a Point above 7,000 RPM.
      08-13-2020, 09:40 PM   #43
chief1richard
2018 M2  [0.00]
Quick Jack
Anyone who owns one should realize that it has lube holes that need to be oiled regularly. If not they will seize due to rust and prevent jack from coming down all the way to floor.
      08-14-2020, 02:41 AM   #44
Mavallone
Mavallone's Avatar
Chief-
Thanks for the feedback. My car arrives in 3 weeks. It is one of the fist mods I will do!
