BMW M2 Forum > BMW M2 Competition Model > M2C manual 1st gear issues
      03-05-2019, 03:57 AM   #1
nnj3jnn
Drives: m2c
Hey everyone! I'm a brand new owner of a m2c 6mt here in canada and got a question. I'm halfway passed the break in period and one thing got me worried, sometimes the the transmission refuses to go into first gear from neutral. Like it happens about 1 to 3 times a week, usually happens at a red light I go into neutral and when im ready i clutch all the way try to pop into first but something is blocking it, most of the time if i pop into 2nd and then ill be able to go into first. However one time it refused to go into first no matter what i did
i even restarted the car ended up having to launch in 2nd gear held up traffic which was embarrassing.
Little history I'm by no means a pro racer but having driven many manual cars before mr2 turbo/s2000 never encountered this issue before so i doubt its my driving abilities. Should I be worried? its brand new car so warranty will cover everything, unless they say I mishifted and grinded the gears which I know I did not do. The m2c also had 127 km when I purchased it so it did get test driven or whatever for 37km cause i think new cars usually have 90km on odometer. Hopefully someone can ease my worries! thanks
      03-05-2019, 04:31 AM   #2
bprince7
Drives: 2019 M2 Comp
That's really odd. I have an MT M2C and I have never experienced this. I would definitely let your dealer know. Also, most of the new M2Cs have <10 miles on them at delivery so it was test driven a little more than you think. That being said, I'm not sure how this would be the result of not adhering to the break in recommendations.
      03-05-2019, 06:42 AM   #3
CSBM5
CSBM5's Avatar
2717
Drives: 2019 M2 Comp, 2011 M3, etc
No problems of any sort like that here.
Definitely have it looked at. Couple of possibilities are the clutch is not fully disengaging (slightly dragging with pedal fully depressed), and it may need to be bled (air bled out of hydraulic line) or it's got mechanical issues. Another is the 1st gear synchro is not well.
My car had 9 miles on it when I bought it, and since I had given up my allocation locally to purchase it out of state back in September, I'm pretty sure that dealer gave someone one test drive in it (I bought it the 2nd day the dealer had it).
Current Stable:
2024 G20 M340i Melbourne Red/Cognac
2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg
2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8
      03-05-2019, 09:18 AM   #4
sobek305
sobek305's Avatar
Drives: xxx
I’ve had the same problem a couple of times, M2c - do you have any upgrades or tune on your car?
      03-05-2019, 09:30 AM   #5
Soren535
Soren535's Avatar
29
Drives: 2019 M2C HS
I have had this happen to me once in a while on my previous M235i and on my current M2c. Even my friend with an F80 M3 reports the same issue.
My F80 friend says going to 2nd and back to 1st works for him. As for myself, double pumping the clutch always seems to open up 1st again.
3 manual transmissions all exhibiting the same quirk, I just assumed it was normal at that point. But I am curious as to why it happens.
devo755.00
      03-05-2019, 09:36 AM   #6
ashtaron14
ashtaron14's Avatar
Hong Kong
1123
Drives: G80 M3
For me it's a BMW thing, because I have the M2C in 6MT and also an E90 M3 in 6MT and they both sometimes don't want to get into 1st, or 3rd.
      03-05-2019, 09:58 AM   #7
M3GymNut
Drives: 2021 M3Comp
My F80 6MT once in a blue moon has issues going into 1st as well. When it does the next time I try going into 1st I gotta give it more noogie for it to go in.
      03-05-2019, 10:07 AM   #8
sobek305
sobek305's Avatar
Drives: xxx
Bet you’ll get a lot more responses/interest in the specific topic if you edit the title to something like “M2C Manual 1st gear problems”
We can really see how many people are having the same deal
      03-05-2019, 12:29 PM   #9
AlpsRider
AlpsRider's Avatar
2865
I haven't had a problem going into any gear. One thing that I've noticed is that after almost 5k miles the shifting is just getting better and better.
Try letting the clutch out in neutral and gunning the engine a bit and then press the clutch all the way to the floor and gingerly shift into first. If it doesn't want to go in then I would have it checked out. That is not normal.
      03-05-2019, 01:52 PM   #10
FalconUSAF
FalconUSAF's Avatar
Drives: 2019 M2C, LBB, all options.
Most of my past MTs had same issue occassionally
      03-05-2019, 02:13 PM   #11
nnj3jnn
Drives: m2c
Thanks for all the replies, I was going go wait until the 2k km service but i think ill just bring it in now so they can look at it and if it happens again they can look again during the 2k km service. The regularity of it happening atm is kinda unacceptable on a brand new car to me. Ill let everyone know what the dealership says!
      03-05-2019, 02:20 PM   #12
AlpsRider
AlpsRider's Avatar
2865
Originally Posted by cntzl View Post
^This. My M4 used to do that rarely and my NB Miata does it occasionally as well. When it's resisting to go into 1st, just put it in 2nd then back into 1st. This method has always worked for me. No such issue with my M2C though.
You kept the Miata!
M-Pilot4859.00
      03-05-2019, 02:28 PM   #13
M-Pilot
M-Pilot's Avatar
Drives: 981 Cayman GTS
You kept the Miata!
I did lol. Don't wanna hijack OP's thread but as you know, the Miata was supposed to fill the gap for me after I sold my M4. I was planning to sell it once the M2C arrived but I just couldn't Love that car and will probably never sell it unless I have to.
AlpsRider2865.00
      03-05-2019, 02:57 PM   #14
M Fifty
844
Drives: M2 & 330CI
It's normal for a MT - take it back into 2nd then forward into 1st, or re-engage the clutch and try again.
Basically the cogs aren't lined up, so won't engage.
Appreciate 7
devo755.00
BlkSVT388.50
AndrewC198910910.50
dr3wzilla138.00
smknjoe234.00
      03-05-2019, 03:02 PM   #15
sobek305
sobek305's Avatar
Drives: xxx
Let us know what happens!
      03-05-2019, 03:35 PM   #16
devo
Drives: Bimmers & Porsches
This ^^ and whomever else may have replied.
My previous 335 and my wife's 328 exhibited this behavior. Going to 2nd and back to 1st has always cured the issue on the first attempt for us. I have not yet had this issue on my M2C.
'19 M2C HS, 6-Spd, Slick Top, MComp Wheels
'18 GT3 White, 6-Spd, Buckets, PCCBs
      03-05-2019, 03:35 PM   #17
KevM2
KevM2's Avatar
BMW M2 Competition  [0.00]
  [0.00]
It's normal. All MTs can do this from time to time.
      03-05-2019, 03:36 PM   #18
cpxchewy
Monkey
119
Drives: 2020 M2C
Do you know if the transmission is still cold? On both of my Miatas (ND and NC) that I've owned the same thing happens until the transmission oil warms up. First gear gets really hard to get into after stopping and I need to get into 2nd then first. However, after the transmission oil warms up, it becomes much smoother.
I've never driven a BMW manual so I'm not sure if it's relevant though.
      03-05-2019, 03:52 PM   #19
M2C89
M2C89's Avatar
Drives: 2020 M2 Competition
Sounds like it's either a BMW or MT thing. Still waiting on my M2C, but back when I had my E46 330Ci, it did the same thing occasionally.
      03-05-2019, 03:53 PM   #20
grinch
Drives: 330d
I have had several bmw with manual gearbox (330, M2, M2C) and the step from second to first gear is strange
      03-05-2019, 04:00 PM   #21
nnj3jnn
Drives: m2c
I probably would've thought the same if 2nd to 1st worked everytime, but that one time I tried everything, 2nd to first, 6th to 1st 5th to first, clutch disengage re engaged, restarted car nothing worked. I eventually launched in 2nd. If it showed these signs about few years down the road I might've been less worried
but a brand new car to me is unacceptable unless its because its not broken in and the problem goes away. I've had the car for less than a month and its happend twice a week seems excessive.
      03-05-2019, 04:01 PM   #22
M2C89
M2C89's Avatar
I would still take it in and have them look at it, you have nothing to lose.
