02-22-2019, 07:22 PM | #1 |
Rep 749
S55 CS Tune Options
Like many I am considering adding a bit of power to my m2C. The CS level tune seems to fit the bill for our cars IMO. Obviously this tune is designed for an m4, and an m4 with a different oil capacity.
It appears that BM3, BPM, VF, and Alpine offer a CS tune. I’m wondering if these are loose replicas of the OEM software, or actual CS software that has been adapted to the oil capacity of our cars. I spoke to BPM briefly and he assured me that their tune is “factory.” Not sure about others. Obviously I’d prefer as close to OEM as possible as opposed to CS like. Apparently the OEM CS map is dialed in very nicely. I’m no expert and simply seeking input and suggestions as I am close to completing my 1,200 mile break in. |
02-22-2019, 07:38 PM | #2 |
Rep 3,659
Drives: 981 Cayman GTS
As far as I know, only BM3 and BPM offers oem CS map. I also know BPM modifies certain parameters so that it takes the different oil level into account. Haven't read much about how BM3 handles the different oil level situation but I assume they take care of this as well. I haven't bought a tune from any vendors and I'm not affiliated with any of them but I would either go with BM3 or BPM.
02-22-2019, 11:33 PM | #4 | |
Rep 1,759
02-23-2019, 12:12 AM | #5 | |
Rep 3,659
Edit: I think the right word is 'quantity' not 'capacity' but regardless M3 CS and M4 GTS seem to have a higher oil quantity than the rest of the S55 family. Last edited by M-Pilot; 02-23-2019 at 12:19 AM.. |
02-23-2019, 04:52 AM | #6 | |
Rep 1,759
If the M3 CS needs 7L of oil with filter then I would assume the M4 CS would be the same otherwise there would be 2 versions of CS tune. I don't think the 0.5L would account for much in terms of potentially screwing up the oil level warning mechanism but looks like BPM already did some adjustment to account for it. Not sure about BM3 yet https://f80.bimmerpost.com/forums/sh...447224&page=22 |
03-04-2019, 03:56 PM | #7 |
Rep 422
As i looked into realoem and compared both M2 Comp oil stuff and Mx CS oil stuff, i feel that there are three differences between them.
Mx CS (or GTS) has different oil pan (by different part number) than M2 Comp (and other similar S55 variants) Mx CS (or GTS) has different oil level sensor (by different part number) than M2 Comp (and other similar S55 variants) Mx CS (or GTS) has spacer ring and o-ring (by different part number) than M2 Comp (and other similar S55 variants) Part numbers for CS oilpan: 11137838706 oillevel sensor: 12618638755 spacer ring: 11137857266 o-ring: 11139909334 Part number for M2 Comp oilpan: 11137854463 oillevel sensor: 12618608780 spacer ring: na o-ring: na |
03-07-2019, 07:52 PM | #10 |
Rep 151
People seem to throw around the acronym “OEM” when talking about these aftermarket tunes, but I’m not sure everyone knows what that actually means. Neither BM3 nor BPM is an “Original Equipment Manufacturer” to BMW.
Are these tunes exactly the same tune as that used by BMW, or are these simply each tuner’s effort to create a map that’s as close to the BMW version as possible? I’ve researched but can’t find a clear answer. It seems like these are more like an approximation rather than actual CS tunes, correct? Last edited by Fenerbahce; 03-07-2019 at 09:19 PM.. Reason: Typo |
03-07-2019, 08:23 PM | #11 | |
Rep 2,505
What if BPM or BM3 take an actual M3 CS flash backup on that car and restore this flash backup to a non CS M3. Will this be considered an OEM CS tune? Hopefully BPM or BM3 can answer these questions.
03-07-2019, 09:11 PM | #12 |
Rep 1,015
Drives: Porsche GTS 4.0
I assumed it was the real cs map, but now yall got me worried
03-07-2019, 09:33 PM | #13 |
Rep 749
I’m aware that neither are OE providers. But are they simply copying or replicating the tables from a cs? Or taking the actual file and modifying the oil capacity? At this point, l’ll probably wait for the m2 cs to come out and see if that tune becomes avail.
03-08-2019, 12:39 AM | #14 | ||
Rep 3,659
03-08-2019, 02:28 AM | #15 |
587
Rep 898
BMW DME files can be dumped by having ISTA+ programming files.
What these tuners do is take the Calibration data of the tables that matter apply it it to your car with the SWFL versions appropriate for your car so it doesn’t trigger FSC checks. So essentially it’s as close to OEM as possible. |
SeanWRT3179.00 |
03-08-2019, 07:52 AM | #16 |
Rep 1,015
So, for clarification, does BM3 adjust the oil capacity with the CS map?
In you all's opinion, is it 100% safe to run the CS map on our M2Cs? |
03-08-2019, 09:17 AM | #17 |
Luxury at the redline :)
9105
Rep 7,563
There are still a lot of unknowns with aftermarket tuning. There are 200 parameters that needs to be adjusted per vehicle. I sincerely doubt the aftermarket tuners addresses all of them..
Yes, you do get more power because they do alter the appropriate channels to address boost load and timing but at what long term cost to the motor's efficiency.. Alls I'm saying is proceed with caution with these tunes.. |
03-08-2019, 10:32 AM | #18 | |
Rep 151
2019 M2 Competition 6MT - ED October 5, 2018
2018 Honda Accord Sport 1.5T 6MT (daily driver / family hauler) |
03-08-2019, 10:52 AM | #19 | ||
Rep 3,659
03-08-2019, 11:01 AM | #20 | ||
9105
Rep 7,563
Good point. It has not been confirm how they generate these numbers because they don't share trade secrets.. I respect that but it's pretty obvious they just copy the factory parameters and make changes to certain channels to increase the boost load, etc - and voila - 'CS tune..' With a turbo-charged set up that is software driven, anyone with a laptop and half a brain can add power when the ECU's firewall is unlocked. Think of it like a DJ at the party remixing your favorite song by speeding it up and lowering then tempo.. Same base tune but a different beat i.e. 'CS remix..' |
03-09-2019, 12:11 AM | #21 | |
587
Rep 898
03-09-2019, 12:35 AM | #22 | ||
9105
Rep 7,563
I guess I stand corrected.. |
